All known 2016 Configuration Photos
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jul 24, 2015.
  1. Aug 8, 2015 at 5:14 PM
    #221
    tubesock
    tubesock Well-Known Member
    All Tacomas (including the TRD off road) have an auto-LSD technology (powered by the brakes) for traction control on normal road surfaces. It isn't as helpful off road. It sort of works in 4-Hi, but you need a lot of wheel spin to get it to kick in. There are some videos of regular traction control working off road. But it does not activate in 4-Low.
    The TRD-OR gets the locker, as has been mentioned, and it gets A-TRAC. This is different from regular traction control, although it fundamentally does the same thing. Active traction control (a-trac) is designed for off road use only and can only activate in 4wd, I think it might even be restricted to 4-low only. It cranks up the wheel sensor sensitivity so it operates at lower wheel speeds and more aggressive about applying the brakes to control wheel spin. It requires an electronic-hydraulic brake booster so it can operate the brakes effectively at low engine speed.
    So if you're talking about off road traction control you should be looking for mentions of A-TRAC or active traction control. The regular traction control will sort of work off road, but not nearly as well because it is designed for on-road traction control. Also worth mentioning is the TRD-OR gets crawl control, which relies on A-TRAC.
    Keep in mind I am basing all this on how the 2nd gen works, but I am assuming it will be a lot of the same for the 3rd gen.
    stbear likes this.
  2. Aug 8, 2015 at 6:59 PM
    #222
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
  3. Aug 8, 2015 at 7:22 PM
    #223
    Mavric31
    Mavric31 Well-Known Member
    2016 DCSB TRD Sport Super Awesome Edition
    So if there is only a $1000 difference from the DCSB SR5 and DCSB TRD Sport then besides the wheel upgrade what else is upgraded from the SR5?
  4. Aug 8, 2015 at 7:26 PM
    #224
    TacoJonn
    Jon
    Laramie, Wyoming
    Is there a tow/haul mode that comes with the towing package?
  5. Aug 8, 2015 at 7:28 PM
    #225
    Mavric31
    Does anyone know what $2400 additional gets you when upgrading to the TRD Sport?
  6. Aug 8, 2015 at 8:35 PM
    #226
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Tow Package, Transmission oil cooler, Engine oil cooler, hood scoop, heavy duty alternator, Trailer Sway Control and some other odds and ends.
  7. Aug 8, 2015 at 8:37 PM
    #227
    Mavric31
    So if I'm going to tow a camping trailer it sounds like TRD Sport package is a must. Agree?
  8. Aug 8, 2015 at 8:47 PM
    #228
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Also dual climate control. TRD grade seats with accent stitching. Led lights. Navigation. heated seats.7 inch display vs 6.1 inch radio display. Anti theft system. 17 inch wheels instead of 16 inch wheels
  9. Aug 8, 2015 at 8:48 PM
    #229
    tubesock
    The tow package is a stand alone package with any V6. You could get an SR or SR5 V6 with the tow package and be fine for towing. But i think the tow package is included with a TRD sport or off road package as far as I've ever seen. I think you'd have to go out of your way to find a TRD that doesn't have a tow package.
  10. Aug 8, 2015 at 8:57 PM
    #230
    TacoJonn
    Jon
    Laramie, Wyoming
    Tow haul mode for auto? Anyone know?
  11. Aug 8, 2015 at 11:04 PM
    #231
    sqa4life
    sqa4life Well-Known Member
    2017 SR5 4x4 DCLB MGM
    Can you tow (light weight) with a 2WD DCSB TRD sport, if needed?
  12. Aug 8, 2015 at 11:07 PM
    #232
    TacoJonn
    Jon
    Laramie, Wyoming
    Usually 2WD's are rated to tow more than 4WD.
  13. Aug 8, 2015 at 11:14 PM
    #233
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Those do not come with the Sport. Most of what you listed only comes with the Premium & Technology package on any model
  14. Aug 8, 2015 at 11:15 PM
    #234
    Z50king
    Eric
    Southern California
    Stock and loving it
    They brought back the ECT Power button for the 3rd gen
  15. Aug 8, 2015 at 11:34 PM
    #235
    Mast3rSkywalk3r
    Mast3rSkywalk3r Well-Known Member
    Bakersfield CA
    2013 Toyota Tacoma PreRunner Trd OffRoad
    wheres white???
  16. Aug 9, 2015 at 12:00 AM
    #236
    tubesock
    Tow ratings are largely independent of drive system*. For the 2nd gen, any tacoma with any engine or drive line is rated to tow 3500lbs. If you have the v6 with the tow package it goes up to ~6500 max. The 3rd gen should be the same if not a bit higher.
    *I mean in the sense of their classification by Toyota, not that all drive systems in any vehicle can tow equally well.
    sqa4life[QUOTED] likes this.
  17. Aug 9, 2015 at 8:27 AM
    #237
    Herniator
    Edmonton
    Sorry, I am going by the Canadian order guide. I forgot the American version is equipped slightly different.
  18. Aug 9, 2015 at 9:35 AM
    #238
    TopherWV
    TopherWV Well-Known Member
    Christopher
    OH
    16' DCLB OR Inferno
    It's called a TRD Pro
  19. Aug 9, 2015 at 9:42 AM
    #239
    TopherWV
    Christopher
    OH
    16' DCLB OR Inferno
    And they'll sell every last one of them.
    Herniator likes this.
  20. Aug 9, 2015 at 4:06 PM
    #240
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
