All lights and cruise control.
Discussion in '1st Gen. Tacomas (1995-2004)' started by qtyrel, Jul 15, 2016.
  1. Jul 15, 2016 at 2:25 PM
    qtyrel
    qtyrel [OP] Member
    Ty
    Oregon
    01 2.7 4x4
    Stock lifted 33 12.5 toyo mt
    Hello, a little over a year ago I was driving with my Cruise control on the headlights and cruise control and all lights turned off. Since then no CC and the all lights will shut off after 25 minutes of driving. Replaced both switches and nothing changed. Still no cruise. No light on dash. Lights still cut off. It happened at the same time. I'm out of ideas since all fuse are new. Can't find a bad ground. Maybe 2 separate issues? This is a 2001 2.7l
  2. Jul 15, 2016 at 3:13 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Any kind of alarm or remote start installed?
  3. Jul 16, 2016 at 7:52 AM
    qtyrel
    qtyrel [OP] Member
    Ty
    Oregon
    01 2.7 4x4
    No alarm or remote start. I've been looking around I'm going to see if the door switch is out they don't shut off when I open the door after shut off.
  4. Jul 16, 2016 at 7:59 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sounds like a relay problem
  5. Nov 1, 2016 at 9:44 AM
    qtyrel
    qtyrel [OP] Member
    Ty
    Oregon
    01 2.7 4x4
    Still the same/ Wilcam47 I have replaced the relays and the switch. also the fuses just to make sure. Been told it the body control module... This i can not locate. Best guess is it the fuse block inside the kick plate? The dealer tells me I don't have a BCM.. Just stuck at this point ECU seems to be fine dont know how to diag it. With the parts i have put on it there has been no change.
  6. Nov 1, 2016 at 9:59 AM
    wilcam47
    Will
    Bourbon state
