All of you LT guys, I want your opinion...
Discussion in 'Long Travel Suspension' started by silver taco, Jan 8, 2012.
  1. Jan 8, 2012 at 8:40 PM
    silver taco
    silver taco [OP] Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    After much debate between LT and mid-travel, I've decided to just do mid-travel. My reason for posting in the LT forums, is because I figure most of you went this route before upgrading. I'm looking to do this in about 6 months, but want to get the planning over so I can stop obsessing!
    I am planning on Icon extended travel remote reservoirs up front with camburg 1.25" uca's. For the rear, Icon 2.5" rear reservoir shocks with most likely All-Pro leafs. To top it off I want to get the LR Jounce bump stops on all four corners.
    I would like to hear your opinions, both positive and negative. Any suggestions to improve on this would be appreciated.
  2. Jan 8, 2012 at 8:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    I personally don't have this set up or long travel. But it sounds like your making good decisions with this mid travel set up. The new icon stuff is sweet. I'll be running those 2.5's and have only heard good things about them
  3. Jan 8, 2012 at 8:58 PM
    silver taco
    Los Angeles
    07 4X access cab
    Christian, are you talking about the cv axles? If so I hadn't thought about that. What would you recommend? And on a side note, good avatar.
  4. Jan 8, 2012 at 9:03 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    no need for new axles...
  5. Jan 8, 2012 at 9:09 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I love mine!
  6. Jan 8, 2012 at 9:15 PM
    97yota4wd
    Eric
    Mesa, AZ
    a different axle will still bind in the same spot. the inch of trravle isnt enough to make the axels bind. the only time you might break one is if your like rock crawling and your front tires get stuck between some rocks or something.
    never heard of mid travel making axles break
  7. Jan 9, 2012 at 5:44 AM
    PLC721
    Patrick
    Chandler, Az
    I have!
  8. Jan 9, 2012 at 5:49 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    You don't need to upgrade axles.
    Sounds like a pretty solid mid travel set up.
    Don't forget to gusset your spindle at the minimum, coil bucket/UCA, and alignment tab gussets are nice to have as well.
  9. Jan 9, 2012 at 7:10 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    why ?????? the front axles are stong and cycle just fine with no issues. the tierod will bind before the axles will ,in droop. so unless your running 37" tires it is a pointless mod and a very expensive one at that.
