all.on.black build/built page
Discussion in '2nd Gen. Builds (2005-2015)' started by all.on.black, Feb 9, 2011.
  1. May 31, 2011 at 10:17 AM
    #161
    all.on.black
    all.on.black [OP] Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Thanks. It got a little stormy but luckily didn't rain.
  2. May 31, 2011 at 10:33 AM
    #162
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    whats up with the LT kit?
  3. May 31, 2011 at 10:35 AM
    #163
    all.on.black
    Auburn, WA
    It's still on the truck.
  4. May 31, 2011 at 10:36 AM
    #164
    PLC721
    Patrick
    Chandler, Az
    decided to keep it?
  5. May 31, 2011 at 10:43 AM
    #165
    all.on.black
    Auburn, WA
    Yeah, I'd be taking too much of a hit on it so I'm keeping it for now.
  6. May 31, 2011 at 10:57 AM
    #166
    PLC721
    Patrick
    Chandler, Az
    Let me know if you decide to let it go
  7. May 31, 2011 at 10:59 AM
    #167
    all.on.black
    Auburn, WA
    It'd be a pain to install on a 6" lift. How much are you looking to spend?
  8. May 31, 2011 at 11:04 AM
    #168
    PLC721
    Patrick
    Chandler, Az
    I'm taking the 6" off and welding in a new cross member. As of right now I honesty can't say as I'm planning on re doing the rear suspension first. Since all it is, Is a lift block and add a leaf. I'm getting the all pro expo pack and foxes and will crank down the front coilovers as much as possible tim I save up to do the front
  9. May 31, 2011 at 11:12 AM
    #169
    all.on.black
    Auburn, WA
    Good plan. My truck will be staying together as it is for now. I plan on redoing the front and rear suspension but not for a while. Once you're ready to buy you can try to see if I'll sell the kit.
  10. May 31, 2011 at 11:13 AM
    #170
    PLC721
    Patrick
    Chandler, Az
    That works for me! I'm shooting for spring time or about a year from now
  11. May 31, 2011 at 11:18 AM
    #171
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    What are your plans for suspension? SAS? Different set up of LT?
  12. May 31, 2011 at 11:25 AM
    #172
    all.on.black
    Auburn, WA
    I'm leaning toward independent suspension front and rear. I'll be using a bigger stronger differential in the front to handle 37's. I'm not too big into rocks so I don't see the need for SAS. I'm mainly interested in the ground clearance for snow and rutteded out trails up here. I'll be doing a long travel independent rear as well. Kind of going with the H1 idea but with more travel.
  13. May 31, 2011 at 11:28 AM
    #173
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Will you be doing it yourself or Fab-Shop?!..Assuming you've seen the IRS that Solo Motorsports built, it is a beautiful machine!
  14. May 31, 2011 at 11:31 AM
    #174
    all.on.black
    Auburn, WA
    Yes, I will be doing the fab work myself. I'll outsource anything I need machined but the rest I'll be doing myself.
    Do you have a link to the IRS build? Is this the H3 build?
  15. May 31, 2011 at 11:35 AM
    #175
    theduck911
    Max
    Locked and Geared!
  16. May 31, 2011 at 11:46 AM
    #176
    all.on.black
    Auburn, WA
    It's an awesome build but it looks like they lost some ground clearance in the rear. I'm looking to gain some. It'd be sweet to see some videos of it. They did a great job on the fab work.
  17. May 31, 2011 at 12:17 PM
    #177
    theduck911
    Max
    Locked and Geared!
    Yea it's an awesome build!
    Yea I'd love to see it rip through the desert and down some trails, I'll see if I can find any!
  18. May 31, 2011 at 7:08 PM
    #178
    jacob_wood
    Jacob
    2010 SSM DCLB
    Oh wow very interesting. Definitely a sweet and unique concept. What is the advantages of doing this compared to what is available for the rear now? I'll look more into the H1 idea that is there.
  19. May 31, 2011 at 7:25 PM
    #179
    SCHMEGGA
    SCHMEGGA Token Gas Passer
    Shawn
    West Texas
    08 PreRunner TRD Off-Road
    That is one SICK truck, dude!
  20. May 31, 2011 at 10:16 PM
    #180
    all.on.black
    Auburn, WA
    The differential can be tucked up higher than an axle (unless it's a portal axle). So you would gain clearance that way but you don't get as much flex. Personally, 13 inches of flex front and rear is plenty for me. I don't do any hardcore rock crawling. I just want to be able to run 37's and have 17" of ground clearance for snow wheeling and deep rutted trails around here. You get a much smoother ride with independent suspension.
    Thanks.
