All over road, Wanders with new tires.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 10, 2009.
  1. Feb 10, 2009 at 3:37 AM
    ballon78
    ballon78 [OP] Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    after the bf goodrich mud-terrains, my truck drivse bad, it pulls to the right if you let go of wheel even when crown in road is going left. it was fine with my worn out stock tires..:mad: i had two different shops do an alignment, and it feel so sloppy driving on the highway. What kills me is that i hve had these tires on many truck and they always are awesome, last forever! Should i swap out these for all-terrains instead?
  2. Feb 10, 2009 at 3:41 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    should have gone with the bridgestone A/T revos
    if you dont do a lot of mudding:)
  3. Feb 10, 2009 at 3:43 AM
    David Tarantino
    N.J.
    08 tacoma
    you may have somthing else going on as well if the front end maybe
  4. Feb 10, 2009 at 3:44 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think theres something wrong elsewhere as well
    as to what...i have no idea
  5. Feb 10, 2009 at 3:48 AM
    David Tarantino
    N.J.
    08 tacoma
    those tires have to sing like mad on the road
    all the ones we have installed have
    just to much noise for me
  6. Feb 10, 2009 at 3:49 AM
    David Tarantino
    N.J.
    08 tacoma
    but i dont go off road
  7. Feb 10, 2009 at 3:51 AM
    JimBeam
    JB
    2015 Tundra
    i honestly didnt notice that much noise coming from them...but that could be because i cant hear it over the engine/creaks/squeeks/rattles
    plus i've had Trxus MTs...and those make almost as much noise as a bogger or an irok
  8. Feb 10, 2009 at 4:03 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Is the truck already lifted? If so, do you have aftermarket UCAs?
  9. Feb 10, 2009 at 4:17 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    the truck is stock, had TSB rear spring a week ago so the back sits a little high. Im wondering if when i put the 5100's on it will level out the truck and make it better. Could it be the angle in the spindles are tipped forward because the rear of the is so high.
    I dont think there is anything wrong with the truck as it was perfect befor the new tires, drove like a dream.
  10. Feb 10, 2009 at 4:19 AM
    Delmarva
    Tucson, AZ
    hmm... maybe try to have the tires rebalanced then... I don't think that the rake you currently have is going to cause that issue... Chris should be here soon though... :D
  11. Feb 10, 2009 at 4:26 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    Tires are balenced awesome, zero virbration and thats hard for a mt...they spent hours balancing them. I'm only setting th 5100's to 1.75 when i get them on friday, i hope that it doesnt add to my problem. I went with the 5100's because i thought it was the best way to level truck wit the TSB springs, dont want to much of a lift. Thats why the 265/75-16 is wahat i went with. I dont want to run into drivablity issuses like weird UCA angles and so on. I dont want to spend 650.00 on UCA just to level the truck.
    After searching on here i notice alotof people complained about the wandering with and without stock tires. But no one seem to end the tread wit what they did, and if it helped.
  12. Feb 10, 2009 at 4:27 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    It just looks so BAD-ASS with the Mud-Terrain!!!
  13. Feb 10, 2009 at 4:30 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
  14. Feb 10, 2009 at 4:35 AM
    David Tarantino
    N.J.
    08 tacoma
    after you have the 5100s installed have the alignment done/or ck you may need to have it done iam almost 100% sure you will
    and if the pull does not stop rotate the tires and see if that
    helps keep us posted it could be in the tire it self :)
  15. Feb 10, 2009 at 4:36 AM
    David Tarantino
    N.J.
    08 tacoma
    ps nice truck:D
  16. Feb 10, 2009 at 4:45 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    Ya friday after work ill toss the 5100's on. Hopfully it helps. Have people been ok with out doing UCA's on just 1.75 lift, its so little that it would suck to spend another 650.00. I see lots off people with 3 inch lift and dont have UCA's it must handle like ride on tractor like that!!
  17. Feb 10, 2009 at 4:52 AM
    Delmarva
    Tucson, AZ
    it rides OK with a 3" lift and stock UCAs... you just get a wandering feeling in the steering...
  18. Feb 10, 2009 at 6:39 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Had issues with mine at first, same as what you talked about. They could not get the alignment in. Did the re-balance, and rotate, helped a little.
    What helped the most and fixed the problem was new U.C.A.'s, yea it blows spending more $$. Now it drives straight as an arrow, but for me it did take awhile getting use to the lift/bigger tire deal.
    Hope it works out for ya.....
  19. Feb 10, 2009 at 7:02 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    My truck wanders with my 265/75/16 goodyear mtrs, I just deal with it. I also have the billys at 1.75. there is only one solution and that is uca's.
  20. Feb 10, 2009 at 7:26 AM
    yote38
    yote38 Member
    New Mexico
    09 DC 4X4 TRD Off Road
    None
    Ballon78, Keep us posted on the results of installing the 5100's. I have an '09 and was thinking about installing the 5100's to level out my truck. I was thinking about this route over installing new coilovers because of all of the issues others have experienced when lifting their trucks. I don't want to solve one issue and create several more in the process. White trucks rule!!
