All Pro 3" Leaf Pack, Toytec Shim, Centerpin extension??
Discussion in 'Suspension' started by 00Jimmy00, Jan 2, 2012.
  1. Jan 2, 2012 at 3:24 PM
    00Jimmy00
    00Jimmy00 [OP] Well-Known Member
    Long Island
    08 SupWht OR
    Hi Guys,
    I just lifted my 08 dblcab offroad with Icon Extended travel on front and Icon rear + All Pro Standard Leaf. I am really happy with the height and feel except I have the vibes, shimmers etc.
    hopefully you guys can help w/questions.
    1. Will the Toytec 3 degree leaf shim leave me with enough room for the Nub on the bottom of the leafs to pop back into place with a safe amount in the hole?
    2. If not, and I need to take out the centerpin, is there enough length to add a spacer sleeve to extend the centerpin nub? The Allpro nub is 3/8" and the left over thread on top of the leaf is 3/8". Also, what size spacer is needed? 3/8"?
    3. Can I take out the centerpin without taking everything apart. Can I just take off U bolts and drop and slide axle away with enough room to pull the centerpin?
    thanks 00
  2. Jan 2, 2012 at 3:32 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I would try dropping the Carrier Bearing first.
  3. Jan 2, 2012 at 3:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If the AllPro pack is anything like the Dakars , the centre pin stud is not quite long enough to allow you to insert the axle shims and still have any stud length to seat the leaf pack into the axle .
    You need to add a centre pin collar , generally 3/8" .
  4. Jan 2, 2012 at 4:00 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I would have bought the Dakars (ARB) - there is a huge difference between the quality and research that goes into the two.
  5. Jan 2, 2012 at 4:09 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    I dropped the carrier by about 1/4" already. Small change in vibe if any at all.
  6. Jan 2, 2012 at 4:11 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    Allpros drop in nicely and hold secure... Where are the vibes coming from? Front or rear and are they always there or just when pulling away from a stop
  7. Jan 2, 2012 at 4:13 PM
    OZ-T
    Peter North
    British Columbia
    With shims ?
  8. Jan 2, 2012 at 4:19 PM
    hard2kill
    Rhinebeck NY
    Nope no shims needed.... I'm running expos and several of my local guys no one needed shims...
  9. Jan 2, 2012 at 4:21 PM
    jflan
    Vancouver, WA
    The center pin extension is about 3/16" long which seems to be enough for a 3* shim.
    Here's another option for the CB drop :
    http://www.streetacos.com/Products.html
  10. Jan 2, 2012 at 4:22 PM
    OZ-T
    Peter North
    British Columbia
    Let me rephrase the question .
    How far does the centre pin project out of the leaf pack , 3/8 - 1/2" ?
  11. Jan 2, 2012 at 4:22 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    Before the lift I had a high frequency vibe from 20-25 and another at 62mph.
    After the lift with torque applied from start and while slowing with no brake applied.
    I am not really worried about the vibes necessarily... I have not replaced wheels and tires yet and have not aligned. I do understand that I have alignment vibrations etc but not all the vibes are coming from the alignment issue. Wheels and tires are coming by this weekend!
    Will Shim fit?
    Can I pull the center pin without taking off the entire rear leaf?
    Help?
  12. Jan 2, 2012 at 4:23 PM
    OZ-T
    Peter North
    British Columbia
    mine was 3/8"
  13. Jan 2, 2012 at 4:24 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    There is 3/8 projecting out fromt the bottom and 3/8 of thread on top as per telcon w/AP.
  14. Jan 2, 2012 at 4:25 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    I am running Standard not the expo's
  15. Jan 2, 2012 at 4:25 PM
    jflan
    Vancouver, WA
    Should be able to.
    Keep an eye on you brake lines as you lower the axle for clearance.
    You may have to disconnect.
    Get clamps on the leaf pack.
  16. Jan 2, 2012 at 4:27 PM
    OZ-T
    Peter North
    British Columbia
    You will need extension collars to run shims
  17. Jan 2, 2012 at 4:27 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    Does anyone know if the centerpin is threaded all the way through to the nub? If so, can I space with a simple nut?
  18. Jan 2, 2012 at 4:29 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    Can I reuse the stock centerpin? Is it long enough?
  19. Jan 2, 2012 at 4:30 PM
    jflan
    Vancouver, WA
    Mine were threaded all the way down.
  20. Jan 2, 2012 at 4:30 PM
    OZ-T
    Peter North
    British Columbia
    OP , check out this thread , it is Dakars but applies to you situation as far as the collars go
    http://www.tacomaworld.com/forum/showthread.php?p=2839336
    If you extend with a nut , you need to make sure the nut head will fit in the slot of the axle shim .
