All Pro 3" Leaf Pack, Toytec Shim, Centerpin extension??
Discussion in 'Suspension' started by 00Jimmy00, Jan 2, 2012.
  1. Jan 2, 2012 at 4:30 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Yes
  2. Jan 2, 2012 at 4:31 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Hmmmm....
    3/8" would be better.
    You got those locally ?
  3. Jan 2, 2012 at 4:32 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  4. Jan 2, 2012 at 4:58 PM
    00Jimmy00
    00Jimmy00 [OP] Well-Known Member
    Long Island
    08 SupWht OR
    Thanks for that thread, I was looking all over for that spacer part #/website. Guess I don't know how to search.
  5. Jan 2, 2012 at 5:06 PM
    00Jimmy00
    Long Island
    08 SupWht OR
    Ok, thanks for the help guys.
    so lets check off
    1. I have to use a spacer so the nub seats safely. check!
    2. I can use a nut as long as it fits in the toytec shims. Check
    3. I am still unsure if I can take off the centerpin with everything virtually installed? Anyone sure I can or can't do this?
  6. Jan 2, 2012 at 5:08 PM
    OZ-T
    Peter North
    British Columbia
    This I am unsure of .
  7. Jan 2, 2012 at 5:13 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    I would try a cb drop first if ur alignment doesn't fix ur problems
  8. Jan 2, 2012 at 7:56 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Get some 3/8" lock washers and stack them until the head will seat fully in the rear axle. You may need to bore out the shim hole to the OD size of the lock washer. My 2* shim required 3 lock washers on the center bolt.
    Other option, if the shim is steel why not bolt it right up with the leaf pack. Them you dont have to worry about any of this. The u bolts are what hold this stuff together anyways.
  9. Jan 3, 2012 at 7:07 AM
    00Jimmy00
    Long Island
    08 SupWht OR
    All right! Great, thanks for all the help guys. I think that answers all my questions.
    I am going to put the new wheels and tires on plus align this weekend before shimming. I had a longer drive today and I think most of the vibes are coming from the alignment/tires. I will post my results and pics of the New Icon's lift with AP leafs +Wheels/Tires.
    Thanks
    00
  10. Jan 3, 2012 at 12:21 PM
    hard2kill
    Rhinebeck NY
    I had bad vIbes that were all fixed with good tire balencing and alignment..
  11. Jan 3, 2012 at 7:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yes you can remove the center pin while springs are still installed, get some good C clamps & tightly clamp where applicable. I've done this a couple times
    still trying to wrap my head around the whole extended pin thing though...
  12. Jan 3, 2012 at 7:08 PM
    OZ-T
    Peter North
    British Columbia
    Doug , check out the thread link I posted
  13. Jan 3, 2012 at 7:14 PM
    OZ-T
    Peter North
    British Columbia
    Anthony's thread :)
  14. Jan 3, 2012 at 7:20 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ahh ok OZ, got it !! & yeah the axle pins i get from ORW are about 6"-7" long & are threaded all the way down so you could get another nut & run it all the way down to the "head" , tighten & use a bench grinder to take the nut down to the same diameter as the spring pin head & theres your extended axle alignment pin.
    I've shimmed a few axles in my time & that seems to be quite an extreme amount to shim up to correct drive angle, did you drop the carrier yet ?
  15. Jan 4, 2012 at 3:58 AM
    #35
    00Jimmy00
    Long Island
    08 SupWht OR
    Yes, dropped it by 1/4". I will report back after my aligment and shim if necessary
  16. Jan 7, 2012 at 4:12 PM
    #36
    00Jimmy00
    Long Island
    08 SupWht OR
    I received my toytec 3 deg shims today and I was surprised to see they came with and extended center pin. It was threaded all the way down and I didn't need to rig it with a nut because the kit came with spacers too. Sweet.
    We disconnected the U bolts and pushed the axles to the side and shimmed it up. Slapped it back together and took it for a test drive. Most all the vibes disappeared. The driveshaft angles into the pinion look good now.
    Alignment is next so hopefully this takes care of the rest of the vibrations.
  17. Jan 7, 2012 at 4:15 PM
    #37
    OZ-T
    Peter North
    British Columbia
    Nice :thumbsup:
  18. Jan 7, 2012 at 4:23 PM
    #38
    hard2kill
    Rhinebeck NY
    Good deal buddy glad all worked out
  19. Jan 9, 2012 at 4:59 PM
    #39
    TacomaChris
    TacomaChris Well-Known Member
    Bad advice...don't do this. Measure your angles to see where you need to decrease your angles before you do anything
  20. Jan 9, 2012 at 5:01 PM
    #40
    TacomaChris
    I'm also running expos but I needed the ToyTec shims as my pinion angle was too extreme (delta of about 7 degrees). Shims fixed her right up...no more vibrations
