All pro 3" leaf spring and SAW coilovers in the front
Discussion in 'Suspension' started by cr250mw2, Nov 29, 2010.
  1. Nov 29, 2010 at 6:42 PM
    cr250mw2
    cr250mw2 [OP] Active Member
    Sacrmento
    08 tacoma 4x4
    Sway-A-Way 3" lift - DC-1 Rims - K&N Intake
    I have a set of sway away 3" coilovers for my 08 tacoma and am thinking I am going to buy a 3" leaf package for the rear. My question is will the rear sit alot higher than the front?
  2. Nov 29, 2010 at 6:50 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    sway aways are adjustable yes? the rear should settle down but every truck is different
  3. Nov 29, 2010 at 6:53 PM
    jandrews
    '09 FourDubDee TRD OR
    You want 1 to 2" of rake. 3" leaf pack with 3" coilovers should be around 2" of rake.
  4. Nov 29, 2010 at 6:54 PM
    malander
    max
    01 limited trd 4x4
    does he now :rolleyes:
  5. Nov 29, 2010 at 6:56 PM
    cr250mw2
    Sacrmento
    08 tacoma 4x4
    I was hoping to that it would level out but I was not sure because of the way the tacoma sits stock.
  6. Nov 29, 2010 at 7:01 PM
    jandrews
    Level will sag in the ass if you put a load in the bed.
    Once again, strongly recommend some rake.
  7. Nov 29, 2010 at 7:06 PM
    cr250mw2
    Sacrmento
    08 tacoma 4x4
    Cool man thanks for the advice I will go with it and see how it works out
  8. Nov 29, 2010 at 7:18 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    It will look stock..maybe worsei
  9. Nov 29, 2010 at 7:42 PM
    cr250mw2
    Sacrmento
    08 tacoma 4x4
    Should I think about doing a 4" spindle lift in the front to off set the rear? I already have the SAW coils for the front but I don't want my truck to look and ride like s#$t!
  10. Nov 29, 2010 at 7:46 PM
    kinkrider101
    santa barbara
    wheels and tires
    Yesdo like 5 in the front with 3 in the back
  11. Nov 29, 2010 at 7:52 PM
    cr250mw2
    Sacrmento
    08 tacoma 4x4
    How much are 5" spindles and where do I find them for a 08 Tacoma. Should I get rid of the Saws and stick with stock front coils or will the saws still be better with spindles? Can I even put spindles on a 4x4?
  12. Nov 30, 2010 at 7:16 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Spindles don't work on 4x4 trucks. They're 2wd only.
    Get the 3" pack in the rear. It'll sit fine.
    For reference, this was my truck when I had W/E shocks up front and the AP 3" packs in the rear:
  13. Nov 30, 2010 at 7:18 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I have OME that are 2.75 and my truck sits fine. I'm also not as high in the front because I'm not running coilovers (OME)
  14. Nov 30, 2010 at 8:44 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    i think itll sit too high in the rear. i have a 2.5" aal, and its too high for my taste. dont really need too much rake, cause the only things that get thrown in the bed are surfboards, snowboards, camping gear, and turnouts. nothing too heavy
