All pro 5" rear springs installed won't level out
Discussion in 'Suspension' started by dtmccray, Jan 26, 2013.
  1. Jan 26, 2013 at 5:46 PM
    dtmccray
    dtmccray [OP] Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    I'm stuck on my rear end. I can't figure out why it's not sitting level. If it was just a little it wouldn't be a problem but it's about 1.5 to 1 3/4 inches lower on the ds than the pass side. Tried swapping the springs still low on ds. Measured perches they are within 1.5 degrees of each other. You can push down or pull up on the ds and it will move 4-6 inches. It seems like it kinda sticks in place but I can't find anything that is binding. I'm stumped...
  2. Jan 26, 2013 at 5:58 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    First of all, what year tacoma?
    Could be rear shock, taco lean, or a bent frame.
    (Measure from the ground to the frame on both sides.)
  3. Jan 26, 2013 at 5:58 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    where are you measuring?
  4. Jan 26, 2013 at 6:04 PM
    dtmccray
    millbrook alabama
    01 money pit
    Measuring from axle tube to frame. It's an 01 dbl cab prorock 60's front and rear, three link front with 12" Walker Evans co's, 5" all pro rear springs with 6 or 7 inch shackles. I put 3/4 inch more preload on the front ds co to help offset the lean but it was only marginally helpful.
  5. Jan 26, 2013 at 6:08 PM
    dtmccray
    millbrook alabama
    01 money pit
    Frame appears straight. It measures the same amount out as the axle tube to frame numbers. It sat level before I changed rear springs and axle.
  6. Jan 27, 2013 at 7:12 AM
    dtmccray
    millbrook alabama
    01 money pit
    C'mon people I'm out of ideas. Anything that you think it might possibly be...
  7. Jan 27, 2013 at 7:18 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    did you install new shackles at the same time? check shackle length on both sides?
  8. Jan 27, 2013 at 7:20 AM
    dtmccray
    millbrook alabama
    01 money pit
    Yeah shackles are the same.
  9. Jan 27, 2013 at 7:32 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    How squishy are your new rear springs? You say you can move the height of you rear just by pushing or pulling, by 4-6"?
    If they move that easily, then something as simple as a full tank of gas could be your difference.
  10. Jan 27, 2013 at 8:08 AM
    dtmccray
    millbrook alabama
    01 money pit
    Yeah I thought that too but, the other side doesn't move that much even with me in the bed. I need to swap the springs again just to make sure but I'm fed up with that pos truck.
  11. Jan 27, 2013 at 1:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I didn't read if you put the new packs side by side & measured...
    You mentioned pulling up & sticking on driverside, is the same result doing it to the pass. side ?
  12. Jan 27, 2013 at 1:32 PM
    dtmccray
    millbrook alabama
    01 money pit
    Measured springs on the floor within 1/8 inch at the pin. No pass side react as you would expect it to.
  13. Jan 27, 2013 at 3:02 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Pretty sure your answers in here , just gotta trace & re trace your work dude, I do this alot (R&R springs) & altho' I can do it in my sleep once in awhile I'll get bit overlooking something....
    Ok, dumb question time... What kind of surface are you working on ?? (I know you measured from tube to ground/frame) but hear me out, I've got what for all purposes appears to be level (slab) but it isn't & when I've got a truck sitting there, the pass. side always "appears" to be about 2" lower than dr. side, pull it out & park it just about anywhere else & all looks level, so i dunno something to consider....:notsure:
    Also you said something about changing the axle ?? If you can get a straight edge on it see how much out of horizontal it is (all axles are a little un parallel )
  14. Jan 27, 2013 at 7:55 PM
    dtmccray
    millbrook alabama
    01 money pit
    This is what it looks like.
  15. Jan 27, 2013 at 8:07 PM
    SandDiesel
    SandDiesel Member
    Bob
    Phoenix
    2016 Tacoma TRD Offroad 4x4
    I just bought a 2000 PreRunner two weeks ago and it sits the same as yours. Doetsch coilovers set at two inches up front and I believe just stock rear. I figured shocks or flattened leaf but haven't measured them yet.
  16. Jan 27, 2013 at 8:16 PM
    dtmccray
    millbrook alabama
    01 money pit
    I dunno I have measured, pushed, loosened, greased, pried, removed, reinstalled and everything I can think to do on it. I'm just going to ignore it till I get the death wobble thing fixed.
  17. Jan 27, 2013 at 8:22 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Does your shock extend fully?
  18. Jan 27, 2013 at 10:27 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Whats going on with the rear shocks ?? (relocation) if I'm seeing right (zoom in), the driverside is a little compressed & the pass. side looks almost maxed out....you did measure between the top of bump stop on axle to bottom of contact point on frame already ? or ?. If you get diff. results , new or not & even if you measured them side by side & they're within an 1/8" it could be a weak spring or 2 in the "low" side of the install & it wasn't until there was load putting springs under a little stress (installing them) that they reared their ugly heads... It almost looks like the beds twisted...
  19. Jan 27, 2013 at 10:36 PM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    I had a bad lean on the passenger side similar to yours but when i replaced both leaf packs it fixed it, and since you have switched both packs on either side it cant be a bent pack like mine was, could it be something to do with the left front causing the rear to sag?
  20. Jan 28, 2013 at 5:33 AM
    dtmccray
    millbrook alabama
    01 money pit
    The rear is leaning compressing that shock and extending the other. I have to get longer shocks, they won't let my springs droop all the way. Yeah I measured axle to frame and ground to frame and axle to ground. The springs have been swapped side to side and the ds stayed low.
