all pro bumper and piaa 5100
Discussion in 'Lighting' started by j83soldier, Jan 18, 2010.
  1. Jan 18, 2010 at 12:59 AM
    j83soldier
    j83soldier [OP] Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    Anyone who has an ALL PRO plate bumper and put piaa 5100 in. How did you wire them. I hooked them up with my stock foglight wires and they shine really dim. Has anyone elese hooked them up this way or is it needed to run new wires for them.
  2. Jan 20, 2010 at 8:14 AM
    coke_220
    coke_220 Active Member
    Rob
    WA
    SR5 4x4
    Volant intake and ram air scoop, pioneer avc 900tb,8IN sub,aux fuse block, Satoshi Grill, brush guard with 2 lights
    have u hooked the lights up to the batt to see if they get brighter??
  3. Feb 7, 2010 at 8:51 AM
    05TRD4WD
    05TRD4WD Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
  4. Feb 7, 2010 at 1:27 PM
    Plain Jane Taco
    Plain Jane Taco You....out of the gene pool.
    Bill
    USA
    2015 SW DCSB TRD Sport PreRunner
    If you want the PIAAs to work with the stock foglight wiring, power them off of the battery and use the stock wiring to trigger a relay. Safe and simple.
  5. Feb 7, 2010 at 2:12 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
  6. Feb 7, 2010 at 2:20 PM
    Plain Jane Taco
    Bill
    USA
    Ok...I'll help ya out a little more. Go buy a standard 4 pole, 30amp automotive relay and some 16-14 gauge wiring and terminals. You can buy the relay at AutoZone, Advanced Auto Parts, Radio Shack, etc., etc.
    Wire it up this way:
    #30 (+) to battery with a 15-20 amp fuse as close to the battery as possible. I'm not really sure how many amps the PIAAs pull. But I'd think a 15-20 amp fuse should be enough.
    #85 (+) to stock foglight positive wire. No need for a fuse here as the stock fuse will protect this end of the circuit.
    #86 (-) ground
    #87 (+) lead to PIAA foglamps
  7. Feb 7, 2010 at 5:48 PM
    05TRD4WD
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    could you please explain i like the idea but not sure how to do it
  8. Feb 7, 2010 at 7:02 PM
    Plain Jane Taco
    Bill
    USA
    Look up 3 posts. :thumbsup:
  9. Feb 7, 2010 at 7:13 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Awesome, I was thinking about this when I get the lights. Thanks.
  10. Feb 7, 2010 at 7:42 PM
    05TRD4WD
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    dont the stock fog lights have a relay on the wire harness already
  11. Feb 9, 2010 at 11:13 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    A dude with the same name...sweet!
    Anyways, yes I believe they do.
    I have my PIAA 5100 wired up to the stock wires and as per All Pro's instructions. They shine a lot brighter than my stock fogs did, OP you might have a bad set of bulbs.
  12. Feb 9, 2010 at 7:31 PM
    dustin19d
    dustin19d Well-Known Member
    NorCal
    06 Sport, 4X4, 6-Speed
    AllPro, Armorology, Mobtown, Pelfreybilt
    No! snip off the stock fogs. Strip, solder, shrink and wrap the lights into the stock wiring and they should work just fine with the stock dash switch. It's like a 10 min job. If not check your connections, then check the lights.
    Don't run anything to the battery. The stock wiring pushes plenty of power.
  13. Feb 10, 2010 at 3:47 PM
    Plain Jane Taco
    Bill
    USA
    I agree that it should be fine. I was only offering him an alternative if he felt the stock circuit wasn't good enough.
  14. Feb 28, 2010 at 9:27 PM
    kyzmyss
    kyzmyss Well-Known Member
    NorCal
    07 Dbl. Cab TRD Sport 4x4
    Ok, help me out here...I did this and it kept blowing fuses. Any idea why this would be the case? When I tried it before soldering, shrink and wrapping it the fogs worked fine. Then I tied it all up and it keeps blowing fuses? Any ideas?
