All Pro Bumper noise help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ffemt2987, Oct 19, 2011.
  1. Oct 19, 2011 at 6:00 PM
    ffemt2987
    ffemt2987 [OP] Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Hey guys, I just put an All Pro 1st Gen Bumper on my truck and it is making some creaking noises loud enough to hear from inside the cab "when driving over speed bumps etc". Has anyone else has this problem? Any ideas as to how to fix this problem? I plan on Line-Xing it so I am not sure if that will help. Thanks!
  2. Oct 19, 2011 at 6:03 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Is it making contact with your fender flares? Is it close (the bumper is mounted the frame, and the cab is mounted on bushings. So when the truck flexes, the cab can move independently of the bumper).
    Recheck torque on all your bolts.
  3. Oct 19, 2011 at 9:11 PM
    ffemt2987
    Austin
    Golden
    I couldn't see any contact with the fenders. I guess Ill just tighten all the bolts down again, they were all tight a week ago. Thanks
  4. Oct 19, 2011 at 9:25 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Mine squeaked like a bitch when I first put it on.
  5. Oct 20, 2011 at 5:15 AM
    darcivic00si
    darcivic00si Love this forum!
    Darci
    Tucson, AZ
    '20 Super White TRD PRO Manual!!!
    Mine squeaks pretty loud, too. I found out where it is coming from, but only have a temporary fix right now.
    The squeak on mine is coming from the fog light area. The hex shape housing for the fogs is contacting the OEM black sheet metal on the top of the hex area. For now I just cut a piece of fuel line rubber tubing down the side and shoved it in between the 2 pieces.
    I can't take pics now because the truck is being shipped overseas at the moment.
    Hope this helps! :)
  6. Oct 20, 2011 at 9:52 AM
    ffemt2987
    Austin
    Golden
    Thanks for the help guys, I was hoping I wasn't the only one.
