All-Pro Expedition Series Pack Rack
Discussion in 'All-Pro Off Road' started by allpro, Jan 22, 2014.
  1. Jun 25, 2014 at 9:58 AM
    #101
    kaprisdad
    kaprisdad Well-Known Member
    Scott
    Prosser, WA
    '14 DCSB MGM TRD Offroad
    Toytec Boss 3", Sport Hood, Sport Grill, TRAC Performance 50" Curved Led Bar Mount, Rigid 30" Lower SR Mount and Light Bar, LS460R Projector Headlights, Rear View Mirror Relocate, Rear view Mirror with Thermometer, WeatherTech Liners, In Cab LEDs, Pop & Lock Electronic TailGate Lock, Method NVs, Toyo AT II 285/75r16
    Any chance one getting just the two hoops from the accessory rack by themselves in steel for a custom spare tire project?
  2. Jun 25, 2014 at 10:23 AM
    #102
    allpro
    allpro [OP] Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Give us a call and we will see if there is something we can figure out for you.
    406-961-0126
  3. Jun 25, 2014 at 11:14 AM
    #103
    kaprisdad
    Scott
    Prosser, WA
    Called and got taken care of. First time dealing with you guys and it certainly wont be the last. Thanks for the great customer service!
  4. Jun 26, 2014 at 8:35 AM
    #104
    skisailbike
    skisailbike Well-Known Member
    Colorado/Alaska
    '14 4x4 DCSB OffRoad
    Icon 2.5 ET coilovers, LR UCAs, Dakars, Icon 2.0 RR ET Rear Shocks
    I'm going to be mounting my CVT Mt. Shasta on an All-Pro rack, with the tent opening to the side. For those of you that have similar setups, did you run the support bars lengthwise or did you cut them down and run them across the bed. It looks like it would require some trimming of the aluminum mounting inserts to get it to work if I run them lengthwise. Advice would be appreciated!
  5. Jun 26, 2014 at 9:16 AM
    #105
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I'm interested because I will be mounting the same tent on a pack rack soon.
  6. Jun 26, 2014 at 9:36 AM
    #106
    DefconBrix
    DefconBrix instagram @defconbrix
    Sean
    Phoenix, AZ
    '13 Overland Taco
    Check the build thread.
    My CVT Mt Shasta opened up to the passenger side and the mounting rails went length wise down the bed and I didn't have to trim anything. I no longer run the tent on my PackRack (now on a trailer) otherwise I would take a close up shot for you.
    This photo shows the Mt Shasta and the 55" awning mounted on the PackRack which was such a perfect fit!
    Here is the best photo I could find of how mine was mounted length wise underneath.
  7. Jun 26, 2014 at 10:34 AM
    #107
    CrunchyTaco99
    CrunchyTaco99 Well-Known Member
    Joe
    North Georgia
    99 TRD Tacoma
    33x12.50 Pro Comp M/T's All-Pro Coils, UCA and 3" leafs.
    Keep in mind that the cvt rails run 32" apart. So if you welded up the rack like I did you need to check how wide your front to back tubes are apart. I got the rack before the tent and didn't think about the spacing. I randomly welded mine something like 4" inches away from the outside bend. Of course with my luck it put the bars 34" apart and very hard to mount the rack correctly. I am currently having to weld mounting plates to mine to fix the issue. I can post pics later is someone want them.
  8. Jun 26, 2014 at 9:29 PM
    #108
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    That PackRack is awesome... great setup.
  9. Jul 2, 2014 at 8:21 AM
    #109
    allpro
    Montana
    Show us the pictures of your PackRack setup!
    We have seen some pretty awesome set-ups on instagram lately.
    Here is one we found on instagram that the owner, @toy_yoda_tacoma, has incorporated in 2 large ammo cans on a full height PackRack.
  10. Jul 2, 2014 at 12:32 PM
    #110
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Do y'all still offer the bolt together rack? I didn't see it on your website.
  11. Jul 2, 2014 at 12:49 PM
    #111
    allpro
    Montana
    We don't, the cost to produce the bolt-together kit was extremely high.
    We send these out as weld-together kits. If you don't personally have the capability of welding it yourself usually a local welder can do it for you for around $100 or less.
    We can also weld it together for you for $100 but it would have to get sent truck freight which would increase your shipping cost.
    Give us a call and we can figure out the best options for you.
  12. Jul 7, 2014 at 9:27 AM
    #112
    allpro
    Montana
    Here is our Aluminum PackRack with a welded on accessory bar for the Axe/Shovel mount.
  13. Jul 10, 2014 at 9:46 PM
    #113
    refokus
    refokus Member
    Brad
    Glendale, AZ
    2014 Tacoma DCSB
    I'm glad I found this thread. I like the racks and will be looking to get one along with the RTT.
  14. Jul 10, 2014 at 10:02 PM
    #114
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Sub'd - Awesome Thread. Nice work All-Pro.
  15. Jul 11, 2014 at 11:12 AM
    #115
    allpro
    Montana
    Awesome!! We are happy you found it also :D
    Let us know when you're ready, we also sell CVT and ARB rooftop tents to make it a one-stop shop.
    Thanks for the feedback! We are trying to get our threads updated with new images with as much info as possible!
  16. Jul 23, 2014 at 8:20 AM
    #116
    allpro
    Montana
    DefconBrix with his custom canvas cover down on his PackRack.
    * The Hi-Lift is bolted onto the PackRack with the optional weld-nut inserts.
    * Also attached to his PackRack is the 55" Awning from CVT using billet Fourtreks mounts.
    We are still working out the details of offering a similar cover.
    ____
    This is a photo we found on the Overland Expo website of this PackRack.
    * using the Accessory bar on the passenger side for an Axe mount.
    ____
    Here is the PackRack without everything mounted up to it (except the cover)
    * Notice the accessory bars on both sides
    * The billet Fourtreks awning mounts are attached also on the back as well
  17. Jul 23, 2014 at 8:51 AM
    #117
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    LOL at marshmellows and hotdog!
  18. Jul 23, 2014 at 4:09 PM
    #118
    DefconBrix
    Sean
    Phoenix, AZ
    '13 Overland Taco
    Gift from my wife for Father's Day lol
  19. Aug 13, 2014 at 7:21 AM
    #119
    allpro
    Montana
    Brownie last weekend exploring in Montana.
    What do you strap onto your PackRack?
    surforegon likes this.
  20. Aug 13, 2014 at 2:14 PM
    #120
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    I got mine welded up last weekend. Hoping to get it dropped off at the powdercoaters next week.
    Any chance you guys are going to offer any specials on the gear rack and accessory bars? Maybe a buy 2 bars + gear rack discount? ;)
    Also, do you have any suggestions for a bolt-on solution for carrying a spare tire on top of the rack?
