All-Pro EXPO or OME DAKAR ?
Discussion in 'Toytec Lifts' started by george2pak, Sep 25, 2012.
Dakar or All-pro EXPO?
Poll closed Oct 25, 2012.
  1. OME Dakar leaf springs
    50.0%
  2. All-Pro's Expedition Leaf Springs
    50.0%
  3. Other please mantion
    0 vote(s)
    0.0%
  1. Jul 25, 2015 at 6:52 PM
    #141
    T4RFTMFW
    T4RFTMFW #DBBeer
    Thanks Pete.
    Are you running spacers up front with the 885s or is your lift height up front approx 2.5" like what I'm expecting?
  2. Jul 25, 2015 at 6:53 PM
    #142
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Just 885's with the 5mm OME trim packer on the driver's side , yep about 2 1/2"
  3. Jul 25, 2015 at 6:55 PM
    #143
    T4RFTMFW
    T4RFTMFW #DBBeer
    Great. How is the ride in the rear without tools? Assuming you've actually never had them with you, once. :D
  4. Jul 25, 2015 at 6:57 PM
    #144
    OZ-T
    Peter North
    British Columbia
    It gets stiffer with less weight , but even just the cap takes the harsh off
    T4RFTMFW likes this.
  5. Jul 25, 2015 at 6:58 PM
    #145
    neverstuck
    neverstuck Well-Known Member
    Vancouver Island
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Dakars with no AAL, and about 800 lbs in the bed sagged about an inch. I wouldn't AAL if I were you. Keep the ride quality nice and smooth when all you have on is the canopy.
  6. Jul 25, 2015 at 7:00 PM
    #146
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    Caddy
    Twin Turbo!!!!! whoosh whoosh pshshshssh
    I have all pro expos and I am regretting sellin my shell. It's way to rough. Can't wait till I get a bed rack and RTT on.
  7. Jul 25, 2015 at 7:02 PM
    #147
    OZ-T
    Peter North
    British Columbia
    Dakars , no AAL
  8. Jul 25, 2015 at 7:03 PM
    #148
    T4RFTMFW
    T4RFTMFW #DBBeer
    Excellent. Thanks a lot both of you.
    What brake like should I be looking at? I know my 5100s aren't going to work with the Dakars. So I'll need to redo the entire rear setup. I'm still using OEM
    bumps on my rear.
    So..
    Dakars.
    Ext. brake lines.
    Bump stops.
    OME rear shocks.
    Are there different rear shocks (I think the front OME struts are available in a softer and a firmer version?)? I don't off-road, so want to keep my pavement pounding as supple as I can.
  9. Jul 25, 2015 at 7:06 PM
    #149
    OZ-T
    Peter North
    British Columbia
    I have OME rears and Wheelers Superbumps , I also have stock brake lines
  10. Jul 25, 2015 at 7:16 PM
    #150
    T4RFTMFW
    T4RFTMFW #DBBeer
    Really? If I can run my OEM brake lines that would be great. Which rear shocks are you using?
  11. Jul 25, 2015 at 7:19 PM
    #151
    OZ-T
    Peter North
    British Columbia
    Yep , almost 5 years , no troubles
    N182's IIRC
  12. Jul 25, 2015 at 7:23 PM
    #152
    T4RFTMFW
    T4RFTMFW #DBBeer
    Thanks Pete!
  13. Jul 25, 2015 at 7:30 PM
    #153
    neverstuck
    Vancouver Island
    13 DCLB sport
    I'm running the original nitrochargers, not the sports. They offer a softer ride and coincidentally, were a little cheaper through Wheelers. I'm happy with them.
    I am running stock brake lines as well and have a full set of stainless steel lines sitting in my garage. I was going to switch to make the Dakar installation easier but didn't need them and one of the top flare nuts was seized so I have put it off. Rear shocks will limit travel before you damage a brake line - they were designed with that in mind.
    I have Timbren SES TORTUN4L and they work great. I have Wheelers superbumps on my front and both seem to be really good quality. I think the Timbrens are more designed to help carry loads though - If I recall correctly they're taller so would engage sooner and have more compression range.
  14. Jul 25, 2015 at 7:32 PM
    #154
    T4RFTMFW
    T4RFTMFW #DBBeer
    Thanks bro! Lots of good info.
  15. Jul 25, 2015 at 7:35 PM
    #155
    neverstuck
    Vancouver Island
    13 DCLB sport
    No problem - good luck with them.
    2 more things:
    The squeaky leaf fix that Oz posted in another thread works like a charm. I did it before install and haven't had a squeak once.
    Get yourself a 3 degree axle shim and mount it to the Dakars before install. I did that as well (with no diff drop) and there is zero driveline vibe.
    krob32 and T4RFTMFW like this.
  16. Jul 25, 2015 at 7:54 PM
    #156
    T4RFTMFW
    T4RFTMFW #DBBeer
    Will do!
  17. Jul 25, 2015 at 10:53 PM
    #157
    T4RFTMFW
    T4RFTMFW #DBBeer
    Much difference between the Sport struts and shocks and the regular sets? I think I read the Sports are a bit stiffer.
  18. Jul 25, 2015 at 10:54 PM
    #158
    T4RFTMFW
    T4RFTMFW #DBBeer
    Where did you get the axle shim?
  19. Jul 25, 2015 at 10:58 PM
    #159
    neverstuck
    Vancouver Island
    13 DCLB sport
    Wheelers. Bought everything through them. There are 2 styles. Buy the one with one hole drilled through it rather than the one that is slotted out. Those are designed to be mounted without removing the pin but the pin that comes with the Dakars isn't long enough to anchor into the perch of the axle so you would need to add a collar to it. The one that has a single hole drilled is a simple install and the centre pin in the Dakars is long enough to accommodate it.
  20. Jul 25, 2015 at 11:22 PM
    #160
    T4RFTMFW
    T4RFTMFW #DBBeer
    Awesome info. I didn't see the 3 degree. I only saw a 5 degree there, but I will ask @YotaDan on Monday.
