All-pro IFS skid bolt issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neonlazer, Mar 10, 2012.
  1. Mar 10, 2012 at 8:46 AM
    neonlazer
    neonlazer [OP] Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    So since all-pro aint open till monday thought I might ask here. I have mounted the skid on the first 2 and middle 2 bolts fine, but the rear 2 bolts...don't fit..are you supposed to have all 6 bolts in on the skid? i have tried both the stock frame bolts and the smaller factory skid bolts but neither go in very well.(frame ones dont fit at all lol)
    bolt holes on far right and left on the crossmember
  2. Mar 10, 2012 at 8:53 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Try keeping all the bolts loose until they are all started. I imagine you torqued the fronts down and now cant get the rears started.
  3. Mar 10, 2012 at 8:57 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    ^yup. Did that the first time I put mine on.
  4. Mar 10, 2012 at 9:00 AM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Actually I took the whole plate off just to see if the frame ones would fit and definitely too big..the skid plate ones seem to fit but dont go in right so didnt want to strip them.
  5. Mar 10, 2012 at 10:51 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You should use the smaller bolts, IIRC like a 12mm head.
    They won't go in easily with the skid off either? If that's the case you need to find a tap and die set, find the correct ones and run a tap up through those holes, then run a die on the bolts.
    If they go in fine without the plate on then it's just a matter of lining everything up. I'd suggest a floor jack (with a block of wood) to push the plate up into place, don't install any bolts, just position it until all holes align with the bolt holes on the frame and get it pushed tight up against your truck then thread in all your bolts. Sorry for the run on sentence.
    Coat all bolts in anti-sieze!
  6. Mar 10, 2012 at 10:58 AM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Frame bolt is a no..its too big..the only option is the the factory skid bolt.
  7. Mar 10, 2012 at 11:14 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah, that's what you're supposed to use.
    Coat everything in anti-sieze while your truck is nice and new.
  8. Mar 10, 2012 at 12:00 PM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Yea..ok so I was wrong..indeed the skid plate bolts work..now a bigger issue as to why i can't line both up(I used a jack to push it up in the back)..I got the passenger side bolt in, but the back of the slid plate hits against the crossmember so no way in hell i can put in other side. I am almost wondering if they made it a inch too short..i loosened everything and tried to line both up and i did..but when i pushed it against the frame the back part of skid slid up the rail..ill take pic in a min..while i was under the truck some ants decided to piss me off. lawlz
    All in all. The skid needs to move forward a few mm but the flap on the back of the skid hits the crossmember. I am going to call all-pro monday to check and see if they have never had issues on 12's yet.
  9. Mar 10, 2012 at 12:17 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I also complained to them about this. Start what bolts you can then you need to use a jack and get it to where you slowly start lifting the vehicle, then put the last few in
  10. Mar 10, 2012 at 12:18 PM
    08pretaco
    az
    Should have read all posts before i posted, disregard mine
  11. Mar 10, 2012 at 12:24 PM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Skidplate against the back of crossmember
    And for giggles...the pic ill put in my build thread :p (Always say ill sell my cameras but gosh..so hard to)
    Altho i think the idea is to have it against the crossmember so when you put the transmission cover on you can screw into it..hmm..ah well..so at least I have 5 of the 6 bolts in..i rust the front 4 the most. Stupid to not have the frame bolts for the back to..
  12. Mar 10, 2012 at 12:52 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You don't need those bolts in the rear to be massive, they're really only supporting a small load, any shear they encounter when you knock the skid in a horizontal plane and the weight of the skid itself. How much is that last bolt hole off? Take a round file or a dremel to it.
