All Pro IFS Skid Plate Install Guide (lots of pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kyouto42, Apr 12, 2010.
  1. Apr 12, 2010 at 3:58 PM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    AllPro makes a great skid IMO, but they don't send any directions. You can figure it out pretty easily, but there's a few things that are nice to know up front. Also, you can access the oil drain plug with this skid without removing it. I'm doing this write-up on my 2008 TRD Off-Road Pre-Runner after doing an install on a 2010 TRD Off-Road 4x4.
    Link to the product: Spec: 7G Steel (3/16" or 0.1875" thick)
    Before you install:
    People needed: 1 person, 2 recommended
    Estimated time: 20-30 minutes if alone
    Hardware Included: IFS Skid. You will re-use your stock bolts
    If you have a front diff drop: You will need to space it down with washers. (I will get the correct sizes next time I'm at the hardware store)
    Notes:
    • If you are installing the All Pro front bumper as well, please install the IFS Skid first. Removing the old one and bars is a lot easier if you do it first. The bumper will not fit with the stock skid plate unless you modify it first anyway, and the directions did not specify this.
    • If you are not installing the front bumper, you can leave the TRD extra "C" type recovery point. If you are installing, it interferes with the bumper.
    Gather required tools:
    • 12mm socket (3/8" or 1/4" drive)
    • 17mm socket (1/4" drive)
    • 3" extension (3/8" and 1/4" or just 1/4")
    • Ratchet (3/8" and 1/4" or just 1/4")
    • Jack
    • Safety Glasses (especially if you wheel, always a good idea regardless)
    Procedure:
    Remove front skid
    Remove front two bolts (12mm)
    Remove center 2 bolts (12mm)
    Remove rear 2 bolts (12mm)
    Remove skid supports
    All bolts are 17mm, Pass side has 3 bolts (two toward back, one front). Driver side has 4 bolts (two front, two back).
    Prep skid for install.
    Bent up portion goes toward front.
    Required bolts for IFS skid install:
    • 4x 17mm (front 2, middle 2)
    • 2x 12mm (rear 2)
    • Optional (dropped front diff) x# washers of x size. (will update when I get the proper sizes).
    Install locations:
    Install skid.
    At this point it helps to have a buddy assist in keeping it stable and with the alignment, but you can do it alone. Install the 4 corner bolts first, then the middle two. As with any install, always keep the bolts loose to wiggle for alignment until all are in, then tighten down (hand tight to estimated 40ft-lbs) in a star-like pattern. I used a jack position near here:
    You're Done!
    Note, the TRD recovery point clears just fine with this skid and stock bumper:
    I decided to test out the new skid... the jack didn't go high enough on it's own to completely pull the tires up, but I'd venture to safely say about 90% or more of the weight was on the jack. Note, wheels were chocked and e-brake on!
    Result: No no flex in the skid at all, awesome product!
    Enjoy the new skid!
    If anyone has suggestions for clarification, updates, or anything else you'd like me to update to this, please let me know. I'm going to do a write-up on the front bumper install too when I get a chance to do it. Also, I ran a search and didn't find any previous write-ups for this, if there was I apologize in advance.
    Search tags: IFS, skid, plate, All Pro, AllPro, Install
    Manfred and Dominic4Lo like this.
  2. Apr 12, 2010 at 4:24 PM
    kyzmyss
    kyzmyss Well-Known Member
    NorCal
    07 Dbl. Cab TRD Sport 4x4
    Nicely done. Looks great!
  3. Apr 12, 2010 at 4:40 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i wish someone would have done this before i got mine.....i didnt know about the 2 cross members had to come off.....
    great write up
    no one gives any kind of good directions with there products anymore and its a shame,,,
  4. Apr 12, 2010 at 4:48 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Nice job picking up the slack where AP left off. Really, what is with companies these days not including competent instructions? It's not like the skid is hard to install, but it would have been nice to have known that it needs to go on before the AP bumper and that it doesn't work if you a diff drop (you'll need spacers to push the skid down an ounce to make room for your diff).
    I installed mine on my own using a bottle jack, a lot of balance and forearm strain, and a healthy amount of foul language...
  5. Apr 12, 2010 at 6:58 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Thanks for the comments guys! I didn't know about the diff drop issue, I'll add that to the parts list.
  6. Apr 12, 2010 at 7:17 PM
    middiedefense
    middiedefense like a boss
    Joe
    GA, MD
    09 Access Cab. V6, 6spd, sr5, 4x4, OME 3" kit
    OME 3" Complete kit, TRD O/R Wheels (rattle can flat black), Black Badges, Ultra Gauge
    When I got my lift from toytec, had to did. drop and it came with spacers an longer bolts for the stock skid. However I don't have the numbers on them at the moment.
  7. Apr 12, 2010 at 8:30 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Great pics and instructions plus 1 for u b
  8. Apr 12, 2010 at 8:36 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Thanks for the write up man..it looks great!
  9. Apr 12, 2010 at 8:48 PM
    thai fyter
    thai fyter Well-Known Member
    Good job, looks cool too!
  10. Apr 12, 2010 at 10:24 PM
    kyzmyss
    NorCal
    Can you tell me what spacers you used? No wonder mine didn't mount up right...haha...
    Pics would be greatly appreciated...:thumbsup:
  11. Apr 13, 2010 at 3:03 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    when i had my AP on, i didnt need any spacers to fit over my diff drop. same for my ATO skid now
  12. Apr 13, 2010 at 3:31 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That piece indeed looks heftier than the oem but didn't strike me as solid enough to be jack spot for front of truck. That seems like it would also be important selling point for this item. It has me contemplating my skid situation........nice writeup......price?
  13. Apr 13, 2010 at 8:20 AM
    Breadbox
    Breadbox Well-Known Member
    Northern VA
    TRD Sport, MT, 4X4, SR5
    4" lift; ION and Camburg, custom progressive rear springs no overload; ION Bumps; Roadmaster Active suspension, quick disconnect sways front and rear, Nitro 4.10s, Detroit TrueTrac, ECGS bushing, Aluminess Rear bumper w/swing outs and flood lights, 285/70/17 on ProComp Steelies, Kenwood NAV, URD Short Shifter, CB, front rally bar with LED flows and fogs, RockSliders, FWC.
    Suggestion:
    http://www.quickoildrainvalve.com/
    Makes draining the oil through the little access hole much much cleaner and easier and this drain does not come past the All Pro Skid.
  14. Apr 13, 2010 at 9:48 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Yea I was a tad skeptical too... that's why I tested it out. Though I did test it in probably the strongest spot of the skid near the bend... Honestly though being a massive steel piece I honestly think it'll take most abuse and laugh at it. Hopefully I'll never have to find out :p
    I've thought about that but... I'm still not that keen on putting a valve on the oil. I've seen so many valves (not this particular one mind you) fail before that putting it on such a vital thing as the engine oil kinda scares me...
  15. Apr 13, 2010 at 10:00 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Looks great what gauge steel does AP use on these skids?
  16. Apr 13, 2010 at 10:46 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    7 gauge
  17. Apr 13, 2010 at 3:40 PM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Nice write up!
    Sorry we didn't have instructions yet. This is one of the more straight forward installs, but you bring up some good points. We are working on instructions for all of our products, but are making sure the more difficult ones are done first. Would you mind if we used yours for the time being? Let me know what size shirt you wear, and I'll get one out to you with the rest of your order that is shipping this week (e-locker guards were the hold up!).
  18. Apr 13, 2010 at 5:43 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    By all means, please use it! I wrote it up just to help people save some time, and more than anything with the front bumper install because that can be kinda frustrating :D
    Awesome with the shirt, XXL if possible thanks! (I like'm loose :D)
    Also another quick question... the site says the transmission skid doesn't fit the 2wd PreRunners but... I'm curious as to why. From the pictures and what we saw on the 2010 4x4 it attaches to the AllPro IFS skid and the support beam behind correct? My truck has that support area also.... Though without his truck here I think it might be a bit higher after looking at it again but not sure...
  19. Feb 13, 2011 at 6:56 PM
    Krasus22
    Krasus22 Well-Known Member
    Rancho Cucamonga, CA
    05 PreRunner SR5 Murdered Out
    Blacked Out Badges, Blacked Out Front Grill, BLacked Out Rear Bumper, WeatherTech Floor Mats, Kenwood DDX616, BLHM, Flowmaster Exhaust.
    Love the post! I have a quick question though. I called into All Pro to order the skid plate, but they told me that their skid plate does not fit with the stock bumper. And to me it looks like it fits your stock bumper just fine.
  20. Feb 13, 2011 at 6:59 PM
    The_Hodge
    SC
    they've gone to making a "new and improved" skid since then. this is why it may not work now. you'd have to get someone's older and mangled up one i suppose....or go non-AP
