All Pro IFS skid plate install - need some help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Dec 18, 2009.
  1. Dec 18, 2009 at 6:14 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Putting on my skid plate, bumper is already on. Two questions:
    1. I've removed the right side support that was there for the factory skid plate (right as in the truck's right/passenger side).
    On the driver's side, it's held on with four bolts (two towards the crossmember, two up front). One of the bolts up front will not clear on the All Pro bumper. Besides taking the entire bumper off (which I do not want to do), I can't get the bolt out.
    Am I heading down the right track, or is that support from the stock skid plate suppose to remain in place?
    2. For the rear of the skid plate, there are two holes on the frame to mount the bumper to, just no bolts in them (and no bolts included with the skid plate). Whiskey Tango Foxtrot, over? Anyone know what the deal is here (am I missing bolts from my original skid plate or am I missing bolts from all pro?).
  2. Dec 18, 2009 at 6:18 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    both of those braces need to come off. when they are both off, install is obvious. there was a post on this not 2 days ago
    EDIT: the extra bolt from the front and the extra bolt from the rear braces should be the extra bolts u are looking for
  3. Dec 18, 2009 at 7:13 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    I searched it, the thread I found did not answer my questions.
    I've removed the stock braces and mounted it up in the front and the center portions, now the rear won't fit right.
    It's contacting something on the transmission in the center, is that right? Doesn't seem so - figure if you hit the skid all the energy is going straight to that transmission componenet.
  4. Dec 18, 2009 at 7:16 PM
    jhodge83
    SC
    17 XLT Sport
    shouldnt be contacting anything. i'm not sure how you are putting this on, but now that the braces are out of the way u can put the skid on a floor jack and lift it into place. line up the holes bu the bumper and the rest should go straight up and in
  5. Dec 18, 2009 at 7:59 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    I figured it out - the part of the transmission that the CV joints run to (transfer case?) has a drop bracket on it because of my lift to reduce the CV angle. That's what it's contacting.
    The rear bolts wouldn't go - the hole was drilled the right size for about 1/16th of an inch, then it went down to a smaller, thread hole. Just so happens that the 13mm bolts from the bumper would fit it - so I used those with washers.
  6. Dec 18, 2009 at 8:02 PM
    jhodge83
    SC
    17 XLT Sport
    i've got the 1" diff drop on mine and it sits like 1/4" from the skid. maybe they did a redesign lately
