all pro lift install
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01Yota, Dec 5, 2011.
  1. Dec 5, 2011 at 8:08 AM
    01Yota
    01Yota [OP] Well-Known Member
    Jonathan
    Kentucky
    2003 toyota tacoma 4x4 Little monster truck
    I'm looking at getting the 3 inch lift for my 2001 regular cab and was wondering what was the install time? Is it a weekend deal or longer?
  2. Dec 5, 2011 at 8:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Should only take about 4 to 6 hours.
  3. Dec 5, 2011 at 8:12 AM
    01Yota
    Jonathan
    Kentucky
    That's not bad then and you have to get it allined after correct
  4. Dec 5, 2011 at 8:25 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes. usually you do.
  5. Dec 5, 2011 at 8:40 AM
    01Yota
    Jonathan
    Kentucky
    The ride quality of the stock toyota setup on the trails is horrible
  6. Dec 5, 2011 at 8:50 PM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    if you know what your doing it will be about 7
  7. Dec 5, 2011 at 10:37 PM
    01Yota
    Jonathan
    Kentucky
    Then I'm looking at a two day event I'm going in blind to what's to come
  8. Dec 5, 2011 at 10:40 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Read up on here in the suspension section and use the search. It's really not hard, just be very careful with spring compressors if you go that route.
  9. Dec 5, 2011 at 11:05 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    grab a friend, at least it'll make it a hell of a lot more fun:D
    the back will be pretty straight forward, its the front that is going to be a PITA
  10. Dec 5, 2011 at 11:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    just save the beers for after:D
