All-Pro Long Travel Blowout SALE!
Discussion in 'Group Buys' started by stroM-, May 11, 2011.
Thread Status:
Not open for further replies.
  1. May 11, 2011 at 5:44 PM
    stroM-
    stroM- [OP] @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    $1,950.75 - 10 Kits Available at this price!!!
    Lower Control Arms, 4130 Chromoly, TIG Welded
    Upper Control Arms, 4130 Chromoly, TIG Welded, Fully Gusseted, Dust Caps
    Tie Rod Extenders
    Spindle Gussets
    Extended Steel Braided Brake Lines, DOT Approved
    All-Pro Off Road’s Long Travel IFS suspension system for 05+ Tacomas, 03+ 4Runners, and 07+ FJ Cruisers, is now available at a more affordable price! Get 12” of wheel travel with our 2” wider per side kit! From the rocks to the sand, this all-terrain long travel kit does it all without sacrificing comfort, quality, and performance. Make getting to the trail head part of the fun!
    Included with this killer deal you get 10% off the additional options: (Only applies when purchasing into the Long Travel Kit)
    Coilover Shocks
    All-Pro Off Road offers either Walker Evans or Fox Racing coilover shock packages that are specifically designed for use with our Long Travel kit. Instead of using a generic 8” travel shock, we have them built to the correct length with internal stops, eliminating the need for limit straps. Both systems feature race-inspired 2.5" body high quality coilover shocks, springs and upper mounts that fit into the factory towers.
    Walker Evans 2.5 Non Resivoir - ($1,050) $945
    Walker Evans 2.5 Remote Resivoir - ($1,295) $1,165.50
    Fox Shox 2.5 Remote Resivoir - ($1,395) $1,255.50
    Coilover Adapters
    We are the only company to offer a billet aluminum adapter so that you can use your existing aftermarket coilovers with our LT kit. It is a good way to get the additional travel, track width and strength of our LT kit, without having to buy new coilovers up front. You can always upgrade to the LT specific coilovers at a later date to gain an additional 1” of travel. We also offer a trade-in program as well, giving you market value for your used coilovers as credit towards the LT version.
    ($129) $116.10
    Heavy-Duty Steering Kit
    To eliminate the weak factory tie rod, we have developed a heavy-duty steering kit that utilizes a powdercoated 1” x .156 wall DOM tie rod with top quality ¾” spherical rod ends (heim joints) on both ends. We include boots with our kits to help keep out the elements, however, they do not provide an impenetrable seal, so regular maintenance is required.
    ($495) $445.50
    Chromoly Axle Shafts
    Our extended heat treated 4340 chromoly axle shafts, made by Currie Enterprises, are required for 4x4 applications. They are inserted into the factory inner and outer CVs to retain 4WD. Please specify vehicle when ordering.
    ($495) $445.50
    Timbren Bumpstops
    All-Pro has teamed up with Timbren SES to offer an upgraded bumpstop for use with our LT kit, or even stock arms. They are made of a softer compound than their usual offerings for weight carrying, and they provide a smoother, stop than the factory bumpstop without needlessly limiting travel. Recommended for 33”+ tires.
    ($195) $175.50
    Official List:
    1. Matt B.
    2. Patrick L.
    3. Brennan L.
    4. Kolin K.
    5. Matt S.
    6. Jeff B.
    7. Scott O.
    8. Max T.
    9. Dave B.
    10. Mark N.
  2. May 11, 2011 at 5:50 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Great price.
  3. May 11, 2011 at 6:04 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I'd be all over this if I had my tax return, irs has been "holding" it and keeps requesting more time... up to 105 days requested now -_-
  4. May 11, 2011 at 6:23 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    can't beat that price... bust out your credit cards...
    "shoulda, woulda, coulda"
  5. May 12, 2011 at 7:18 PM
    IRACE87
    IRACE87 Member
    Pat
    Up North
    07 TRD Sport
    I'm really interested........What I would like to know is that if I buy the LT kit, would I be able to get a deal on other parts like a rear kit and front bumper.......
    Thanks
    Pat
  6. May 12, 2011 at 7:25 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    How do the tie rod boots hold up?
  7. May 12, 2011 at 7:27 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    fuggin' subbed.
  8. May 12, 2011 at 7:35 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I thought the Heavy-Duty Steering was already included?!...and is the 10% applied to the AP Glass Flares as well?!
  9. May 12, 2011 at 7:37 PM
    bobby15
    bobby15 Well-Known Member
    SoCal
    09 DC LB 4x4 magnetic grey tacoma
    I WISH =/
  10. May 15, 2011 at 12:33 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Damn! To think I just bought my wife an expensive anniversary present. Would have covered this kit plus all the extras needed :(
  11. May 15, 2011 at 12:46 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    "I swear! If you don't fuck her I'll kill myself! Do her for me, for me!"
    -the girl next door
    That quote goes for all you guys....but meaning to the suspension.
  12. May 15, 2011 at 1:04 PM
    OffRdn916
    OffRdn916 Well-Known Member
    Sacramento
    2010 SR5 4x4 DC
    Weathertech floor lines, 265/75/16 Duratracs, 16x8 XD Énduros, Anti theft tailgate mod. Bilstein 5100x4, Eibach coils, rear TSB.
    Rocklin huh? You go to rhs?
  13. May 15, 2011 at 1:06 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Hmm just got a new credit card...
  14. May 16, 2011 at 9:50 AM
    stroM-
    2006 4X4 TRD OR
    Got your PM - working on the prices for you now!
    It used to be included and now it is an optional upgrade. Our kit retails at $2295 now (and includes what you see on the top picture). The fiberglass is being sold at the price of $399. We are updating our prices on those so that is actually at the discount price now.
    :headbang:
  15. May 21, 2011 at 2:27 AM
    HIYota
    Angel
    Yes...yes it does :(
    RHS? As in Rocklin High School?! Dude I'm 23. Key word "wife". Also I have the airforce symbol with my location being the sandbox. Just saying.
  16. May 21, 2011 at 2:31 AM
    HIYota
    Angel
    Anyway back to the LT Kit...Strom, how long is this going to be available if you guys don't sell 10 kits? Just wondering. I'll be reenlisting in July and then I get the big $$.
  17. May 25, 2011 at 7:18 PM
    stroM-
    2006 4X4 TRD OR
    We did, but it is currently discontinued at the moment! I will be sure to inform when its available again.
    Once the 10 kits are sold we will not honor the price, but I will tell you the new price of the kit is much more affordable at $2,295! :D
  18. May 25, 2011 at 7:56 PM
    PLC721
    Patrick
    Chandler, Az
    but then you have to buy steering, bumps, and axels correct?
  19. May 25, 2011 at 8:09 PM
    theduck911
    Max
    Locked and Geared!
    The only thing being removed is the heavy duty steering (reason for price drop), you always had to buy bumps & axles seperate!
    From research & such that I've done, I noticed that most people don't need the heavy duty steering, it's nice to have but not required!
  20. May 25, 2011 at 8:10 PM
    PLC721
    Patrick
    Chandler, Az
    well being 2" over per side does it come with an extension?
Thread Status:
