All Pro Long Travel Kit Install
Discussion in 'Long Travel Suspension' started by JRW1223, Apr 10, 2011.
  1. Apr 10, 2011 at 7:22 PM
    JRW1223
    JRW1223 [OP] Well-Known Member
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    All Pro long travel, All Pro Front bumper, BFG 285/75/16, American Racing Ledge Wheels 16x8, Vision X 8.7" Tungsten Halogen Off Road Lights
    Hey guys. I have a few questions for you.
    When installing the rear leafs from All Pro, are there washers that are suppose to go on either side of the bushings? The stock springs that I took out didn't have washers in there.
    For those of you that have the long travel kit, did your kit come with steel washer on either side of the a-arm mounts up front (totaling 8, 4 for one side and 4 for the other side)? I also noticed that if there are suppose to be washers in there, the two fwd washers should be larger in diameter for the bolts to go through correct? My kit didn't come with any so that's why I'm asking.
    Thanks for your time!
  2. Apr 11, 2011 at 1:48 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Which All-Pro leafs are you installing?!
    And I'm sure if you call All-Pro you'd get a faster answer!
  3. Apr 13, 2011 at 8:46 AM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    No washers on the rear leaf only the rubber bushing that's what I have.
    For the front your suppose to have the washers and the two front washer are suppose to be bigger in diameter. Your suppose to have washer for the UCA as well. Hope that helps.
    Contact ALL Pro and let them know your missing them.
  4. Apr 13, 2011 at 1:15 PM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Thanks guys. I think I got it now.
  5. Apr 13, 2011 at 1:57 PM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    Jordan,
    Did you receive everything? Let me know if you need anything else!
  6. Apr 13, 2011 at 2:02 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    good customer service right there +1!
  7. Apr 13, 2011 at 8:21 PM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Thanks Jason. Yea I got everything now!
    Im having trouble getting the axles to go in the diff so ill probably be calling you again tomorrow.
  8. Apr 14, 2011 at 3:02 PM
    stroM-
    2006 4X4 TRD OR
    Jordan,
    Hoping Mike was able to help you with the axle install? Lets see some pictures! :D
  9. May 19, 2011 at 11:22 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Jordan, did you take any pictures of your completed install? I'd like to see some if you got some, especially the front. Thanks.
  10. May 19, 2011 at 4:11 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    Washers for the a-arms? I know the uppers should have them
  11. May 26, 2011 at 5:44 PM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Sorry I haven't posted any. Here are some pictures from my phone.
  12. May 26, 2011 at 9:58 PM
    FixedTRD
    Will
    Alhambra, CA
    Nice how you like it, are you also running the All Pro rear as well?
  13. May 26, 2011 at 10:02 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Jordan, Thanks for the pictures! Seeing your taco juxtaposed with the other is helpful. Rep sent. :) Are you running 33" tires? Have you measured how much additional ground clearance you have gained with the kit+tires? I'd really like to know.
    Thanks.
  14. May 27, 2011 at 8:49 AM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Thanks! I like it alot. There is alot more body roll then what I was use to before but that’s to be expected because the sway bar is off now. It rides great though. I have the allpro 3" leaf springs and fox shox in the rear.
    Thanks! Yea, they are 33" tires by 11.5. I never did measure the ground clearance from before tell now. Wish I did though. You can see in the pictures it's quite a big difference from stock. At the bottom of the allpro front diff skid plate to the ground I'm sitting at about 13.5". I don't have the skid plate on in the pictures above though.
  15. May 27, 2011 at 10:50 AM
    4X4_TRD
    4X4_TRD Well-Known Member
    Justin
    San Diego, CA
    '03 Jeep RUBICON
    No front sway bar (does that count?)
    Why do you gotta make me look bad? Haha. You know mine would have wheeled right next to yours about a week before that picture was taken. Looks good Jord. Get some dirt on that thing now.
  16. May 27, 2011 at 11:09 AM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Thanks Bro! Here are some from today.
  17. May 27, 2011 at 11:24 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    siick pics!! gratz on the new kit!!
  18. May 27, 2011 at 1:13 PM
    theduck911
    Max
    Locked and Geared!
    Nice Pics!
    How are Fox CO's up front?! Heard from some that the valving is a tad on the soft side
    Still can't decide if it's worth buying the Fox over the Walker Evans!
  19. May 29, 2011 at 11:36 AM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Thanks!
    The Fox CO ride great offroad. When I driving on the road I can feel more of the bumps because the kit is much stiffer then stock, but thats to be expected. It rides great thou!:D
  20. May 29, 2011 at 1:43 PM
    theduck911
    Max
    Locked and Geared!
    Yea, that's expected on the road!
    And I'd hope it'd be awesome offroad :)
