All-Pro Offroad :: Hi-Lift T-Bar Mount
Discussion in 'All-Pro Off Road' started by allpro, Aug 19, 2014.
  1. Apr 2, 2015 at 4:04 PM
    #61
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Chased the threads on the bracket and now I can fit in with the cool kids.
  2. Apr 2, 2015 at 6:04 PM
    #62
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    That looks good sir :thumbsup: BTW which hi-lift version did you get?
  3. Apr 2, 2015 at 6:34 PM
    #63
    ThomasMore66
    48". HL 485. I need a cover now. I don't think sitting in the rain will be good for it.
  4. Apr 2, 2015 at 6:38 PM
    #64
    Lord Helmet
    Nick
    Thanks, I have a tonneau cover. Fold-A-Cover G4 Elite. I have it to prevent prying eyes since I carry tools in the back. It's lockable on both front and rear. They're other brand but I bought this one just because I can lock it and open it without lowering the tailgate first like the other brands.
  5. Apr 2, 2015 at 7:16 PM
    #65
    ThomasMore66
    That's the one I want! I've bought stuff that I think will fit under the G4. Do you like it?
  6. Apr 2, 2015 at 8:53 PM
    #66
    Lord Helmet
    Nick
    I love it. Money well spent. Almost 3 yrs and no issues. One guy from AZ had the rubber that covers the hinges breaking apart but then again he lives in a dry area so dry rot is a issue out there. I've used rubber protectant ie; Amor-All or any UV rated type and wipe the entire tonneau cover with it which will usually do the trick. Almost 3 yrs and the rubber piece is still soft and pliable.
  7. Apr 2, 2015 at 8:58 PM
    #67
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Pretty well thought out design, definitely one of the stronger ones out there.
    The bed walls on these trucks are strong than people give them credit for - I've had a hi lift mounted on standard brackets bolted through the bed walls (with plates on the back side to distribute the weight) for years without issues. And that's a long travel truck that definitely flings shit around more than a low speed crawler.
    NateMob likes this.
  8. Apr 28, 2015 at 8:18 PM
    #68
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Thanks for the great mounts AP! They fit perfect and I have no doubt will hold my 60" Hi-Lift for years without issue.
    allpro[OP] likes this.
  9. Apr 28, 2015 at 10:18 PM
    #69
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
  10. Sep 10, 2015 at 3:48 PM
    #70
    HuskerHerm
    HuskerHerm Well-Known Member
    Brent
    Portland, OR
    2013 TRD T/X Baja
    Dealer Security/Remote Start, Truxedo LoPro QT Tonneau, OEM Roof Rack, OEM Bed Mat, OEM Hood Protector, Cabela's WeatherTech's, 265/75/R16 DuraTracs, Icon Tubular UCA, AllPro 3" leafs, Allpro SS Brake Lines, Allpro UBolt flip, Timbren Bumpstops, Exhaust Relocate, Full RCI Aluminum Skids, RCI Sliders, 3M Clear Nose Bra, Direct Radar Wire, Window Tint, TRD Shift Knob, TRD Oil Cap, TRD Radiator Cap, DImMrYo Mirror Relocate, Bullaculla Trailer Harness Bracket, V5ioV Anytime Fog, Trimmed Mud Flaps, Trimmed Antenna to 18", Custom Yakima Bike Mounts, Electric Tailgate Pop-N-Lock, Custom APN settings to tether iPhone, Factory Tacoma black emblems, Relocated all traction control switches to under HVAC controls, and oh yeah... Supercharged.
    Will these mount against the back of the cab as well? Or just along the bed itself?
  11. Sep 10, 2015 at 8:14 PM
    #71
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    You could use these mounts on the rails in any location, but that would be a pretty short hi-lift(I don't think a 48" will fit there).
  12. Sep 10, 2015 at 8:21 PM
    #72
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Group buy launching product? First time buyers of prototype get discount depending on how many people want one?
  13. Nov 28, 2015 at 10:39 AM
    #73
    Silver Taco 08
    Silver Taco 08 2011 SWB GUY
    Clem
    St. Paul Minnesota
    2011 SWB ACCESS CAB 4X4
    I have a list....
    Looks Great. Is it lockable yet and is there an active link?
  14. Nov 29, 2015 at 9:06 PM
    #74
    allpro
    allpro [OP] Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    We don't currently offer a lockable unit yet. Here is a link to our site wher you can read more about them.
    Let me know how I can help you!
    Tracy
    tracy@allprooffroad.com
  15. Nov 30, 2015 at 12:19 PM
    #75
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    #75
    Acerwin, ChadsPride and allpro[OP] like this.
  16. Dec 26, 2015 at 5:49 PM
    #76
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    #76
  17. Dec 26, 2015 at 6:06 PM
    #77
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    What is the bolt/stud size where the knob is twisted on? 3/8"?
  18. Dec 27, 2015 at 5:56 AM
    #78
    allpro
    Montana
    It is 1/2x13 tpi
    Tracy
  19. Dec 27, 2015 at 7:50 AM
    #79
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  20. Jan 15, 2016 at 3:27 PM
    #80
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Thanks Tracy!
    I mounted my Hi-Lift in the bed and wanted to address some concerns that were brought up in this thread.
    AP now put longer studs than what's previously pictured with a hole to allow you to put padlocks and secure your jack.
    Also, I mounted the jack with the "tooth" up and it still fits under my tonneau.
