All-Pro Standard or Expedition? 2nd gen.
Discussion in 'Suspension' started by JDawg562, May 21, 2015.
  1. May 21, 2015 at 2:51 AM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    Sorry I know this has been beat to death...
    I'd like to know what's best for my set up.
    I have a 2007 Access Cab, v6, Prerunner. I'll be doing desert trails going a decent speed ~30mph(I don't know I never look at the speedometer) or so and will hit smallish whoop and jumps. For my daily trips in the rear I'll have the spare wheel/tire, small/medium ice chest and maybe another 100lbs of equipment. When I go camping I'll have the bed fully loaded to the top of the bedsides, but wont be off roading with it till I drop most the stuff out. On other trips I may take a couple dirt bikes. Other times I may haul a jet ski or boat. I already have Bilstein 5100 extended length (B110) shocks in the rear.
    I'm on the fence.
    I feel like the All Pro Standard springs will be great for Daily Driving, access cab and off road with an emptyish bed, but when I haul stuff on the street I feel like it will sag like crazy and I'll wish I had the Expedition pack.
  2. May 24, 2015 at 7:55 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Im trying to determine the same thing. I have a leer cap and want a spring that will hold that and flex well over whoops.
  3. May 25, 2015 at 10:45 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Yeah not bashing on the guys at all pro, but I emailed them and they basically told me the same thing they have advertised on their site lol.
    I'm assuming it would be a different ride with a Double Cab Short Bed than an Access Cab Standard Bed. Less weight towards the rear on my access cab, but I'm no expert. I also don't know if the Standard pack will be better over the whoops or if the Expedition pack will be better for hitting stuff at speed or if it will buck me! I won't really need it to flex for crawling I like to go fast :D.
  4. May 25, 2015 at 10:49 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    If you got the air bumps in the rear and have fabricated quick release set up you could have the best of both worlds
  5. May 25, 2015 at 10:53 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Wait quick release for what?
  6. May 26, 2015 at 7:17 AM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    For the air bumps to take them out while off roading
  7. May 29, 2015 at 1:39 PM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    How much lift do you have in the front? When unloaded, the EX springs will sit at about 4", and even with your daily load you'll likely still sit high and ride a little firmer than the standard packs. However, to be able to haul more and tow, you'll need the EX springs. With the standard springs, you'll probably get 2-2.5" of lift with 200-lbs of gear, anything more than that, and Timbrens or air bags are a good idea.
  8. May 29, 2015 at 1:45 PM
    mromeo
    mromeo Well-Known Member
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    sub'd. im about to need some new leafs, so im interested how this turns out!
  9. May 30, 2015 at 12:00 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    I don't know how much lift I have in the front I never took measurements before and after. :rolleyes:
    My rear leafs are pretty shot. I bottomed out alot unloaded and got bucked. I threw a band-aid($70 AAL from eBay:der:) in there and have some Wheeler's Super bumps right now too.
    ANYWAYS Will the All Pro Standard leaf pack will have more load capacity than the stock leafs?
    Also with the AAL from the center of my wheel hub to the top of the bedside is about 38" I don't know how much over stock inches that is, but I want to keep it around that maybe .5-1" lower. It's just about level.
  10. Jun 1, 2015 at 10:54 AM
    allpro
    Montana
    No, our standard pack does not have added capacity over the stock leafs for the simple fact that to provide better flex, the large flat overload leaf is eliminated. We will need to know tire size to better estimate how much lift you're getting from the suspension alone, but typically AALs are 1.5-2".
  11. Jun 1, 2015 at 11:52 AM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    I'm running 315/75/16s. Yea I believe the AAL was advertised as 2"
  12. Jun 2, 2015 at 5:17 PM
    allpro
    Montana
    The EX springs may sit too high for you unless you have 400-lbs of constant weight in the bed (when compared to your lift with the AAL). But, as stated before, if you use our standard springs with your daily load of 150-200 lbs, your truck will likely have about 2-2.5" of rear lift. However, since you also want to haul dirtbikes and tow, you should add Timbrens as a "helper spring". With about a 200 lb/in spring rate, our standard 3" springs will handle some weight, but you'll damage them if they are overloaded and go into a negative arch. Dirt bikes and trailers with little tongue weight should be fine.
  13. Jun 3, 2015 at 11:10 AM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Ok yeah that's exactly what I was thinking! I was also thinking since it's an access cab it has less weight towards the rear than a DCSB. I never really load my bed up off roading or daily driving and I just haul stuff to my camp then dump everything before. I'll try to save up next time they go on sale or group buy or free shipping lol. Unless I find a used set.
    This was me the last few weeks.
    allpro[QUOTED] likes this.
