All-Pro Suspension Group Buy - Ends 9/1
Discussion in 'Closed Group Buys' started by allpro, Jul 30, 2010.
Thread Status:
Not open for further replies.
  1. Jul 30, 2010 at 3:56 PM
    allpro
    allpro [OP] Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    SUSPENSION GROUP BUY - per your votes!
    PRICING STRUCTURE FOR ALL ITEMS IS AS FOLLOWS:
    5+ = 5% Discount
    10+ = 10% Discount
    15+ = 15% Discount
    20+ = 20% Discount
    (Discount is per item, not cumulative)
    05+ TACOMA SUSPENSION:
    - Reg. $649/pr
    • TIG welded​
    • 4130 chromoly construction​
    • 1.25" FK teflon lined uniball​
    • Zerk fittings​
    • Powdercoated finish​
    • Gusseted design for strength​
    1. Toby S *
    2. Gregg E.
    3. tcangas
    4. babdak
    5. Chris P. (wizo) *
    6. Benjamin B. *
    7. Theodore V. *
    8. Paul R. *
    9. Tom D. *
    10. Thomas W. *
    11. Guy B. *
    12. Jim H. *
    13. James H. (FJSkukum) *
    14. Gregg E. (milenko032) *
    15. Duff Man
    16. Abel D. *
    17. Angel R. *
    18. Tony C. *
    - All-Pro Exclusive
    Non-Reservoir - Reg. $995/pr
    NEW! Remote Reservoir - Reg. $1295/pr
    • Nitrite-Coated Shaft - will not chip or rust
    • 160 PSI Nitrogen Charged
    • Adjustable Ride Height 0-3.5" of lift
    • Heavy-Duty, High-Flow Piston with Flutter Stack Compression Valving
    • Billet Upper Mount
    • 3/4" PTFE Lined Spherical Bearing
    • Completely Re-Buildable & Re-Valvable
    • Zinc-Plated, Threaded Steel Body
    • 100% Made in the USA
    1. Colin B.
    2. babdak
    3. Chris P. (wizo) *
    4. rainman4x4 (at 20% off)
    5. Theodore V. *
    6. Spencer H. *
    7. Paul R. *
    8. Tom D. *
    9. Angel R. *
    10. Rich O. *
    11. Cole C. *
    - All-Pro Exclusive
    Non-Reservoir - Reg. $259/ea
    NEW! Remote Reservoir - $359/ea
    • Aluminum Body and 3/4" Shaft
    • 1-yr. Warranty Against Leakage, Breakage &/or other manufacturer's defects
    1. babdak
    2. rainman4x4 (at 20% off)
    3. Theodore V. *
    4. Paul R. *
    5. Tom D. *
    6. Angel R. *
    - 3" Lift - Reg. $375/pr
    Bolt-on 11-leaf pack featuring Military / Anti-Wrap Torque Leaf, Progressive Spring Rate, Shot peened for longevity, Teflon friction pads between leafs, & includes poly bushings. Provides great off-road flex with a 1-yr manufacturer's warranty against breakage & defects.
    1. David R. *
    2. Steven F. *
    3. Cory G. *
    4. PowTaco
    5. Michael N. (mnudo200827) *
    6. STR8_BEAST
    7. ClimberFreak
    8. Joshua O. *
    9. Cristy R. *
    10. Cole C. *
    11. malamute (at 15% off)
    12. Michael N. *
    13. Anthony F. *
    14. Bryan B. *
    Includes:
    • 2” extended tubular 4130 Chromoly upper A-arms with a 1.25" Teflon-lined uniball for maximum travel & strength and zerk fittings for easy bushing lubrication
    • 2” extended tubular 4130 Chromoly lower A-Arms with precision designed uniball adapter connector and bumpstop contact point – this strong design provides the utmost in off-road function and durability
    • Heavy-duty Chromoly steering system with top quality 3 piece chromoly heim joints – allowing for increased droop
    • Extended steel braided brake lines, DOT approved
    • Heavy-duty spindle gussets
    Add the additional components needed to complete the kit at 10% off - 4340 Heat Treated Chromoly Extended Axle Shafts (for 4WDs), Fox or WE coilovers, Timbren bumpstops, etc.
    1. Jordan W. *
    2. Garry S. (at 20% off)
    3. Sebastian S.
    4. 1TUFFTRD (at 20% off)
    5. Rich O. *
    6. Jonathan C. *
    95-04 TACOMA SUSPENSION:
    - Reg. $499/pr
    • TIG welded
    • 1" FK Teflon lined Uni-ball
    • Zerk fittings
    1. Ian F. *
    2. William E. (TanSR5x4)*
    3. Bill D. *
    4. Jim L. *
    5. Robert P. *
    6. Donald R. *
    7. Gordon M. *
    • Consistent arch, lift and spring rate
    • Lower cost when compared to custom springs
    • Shot peened leafs - reduces spring fatigue
    • Precycled to reduce sag
    • Anti-wrap leafs (rear)
    • Teflon liners (pads)
    • Full Military wrap
    1. 3fitty (at 20% off)
    2. el tacorojo
    3. William E. (TanSR5x4)*
    4. Jim L. *
    5. Brody S. *
    6. Eric G. *
    7. Tristan W. *
    Bilstein Coil-Overs - Reg. $699/pr
    • Adjustable from 0-3" of lift
    • Available with heim or bushing mounts
    • Available with 550 or 650-lb/in coil springs
    • Spanner wrench & mounting hardware included
    1. Ian F. (Sterling) *
    2. Justin S. *
    3. Willaim E. (TanSR5x4) *
    4. Brody S. *
    5. Gordon M. *
    • 52-3/4" Eye to Eye
    • 11 Leaf Pack with a Progressive Spring Rate
    • Extended U-Clamps & Teflon Friction Pads for Added Performance
    • Triple Military Wrap
    • 1-yr. Replacement Warranty for Non-Racing Applications
    1. Jonathan S. *
    PLUS - Take 10% OFF any Additional Suspension Components with your order, like Timbren bumpstops, spindle gussets, u-bolt flip kits, CV boots, sway bar links, Fox Shox, etc.
    We will keep an updated list for each item on this post once the orders are placed (* indicates official order has been placed). We will not charge you until your order ships. Please allow 2-4 weeks for delivery. Thank you!
    Last Updated 8/26/10
  2. Jul 30, 2010 at 4:04 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    YES!!!!!! perfect timing!
    think you'll have anything on the fox 2.0s?
  3. Jul 30, 2010 at 5:05 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Awesome, need those leaf springs
  4. Jul 30, 2010 at 5:55 PM
    caz22
    caz22 Member
    Las Vegas, NV
    06 Double Cab TRD offroad
    Rear leaf springs!!
  5. Jul 30, 2010 at 10:22 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Rear leaf springs- what would shipping be to hawaii zip code 96753
  6. Jul 30, 2010 at 10:25 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    No fox gear?
  7. Jul 30, 2010 at 10:26 PM
    David10MGM
    David10MGM Active Member
    David
    Tennessee
    10 PreRunner TRD Off Road MGM
    Camburg spindles, bilstein 5100's @ 1.75, All-pro 3in leaf, 1.5in block, 5125's
    Already ordered leaf springs and rear brake lines but was told the leaf springs are on backorder until August 20th.
  8. Jul 31, 2010 at 8:32 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Awesome timing, I want the Walker Evan fronts!
  9. Aug 1, 2010 at 9:28 AM
    KaoskrewPB
    KaoskrewPB -Empty-
    Contemplating the rear leafs..
  10. Aug 1, 2010 at 2:05 PM
    Sterling
    Sterling Well-Known Member
    Ian
    Mesa, AZ
    2019 TRD Off-Road Tacoma
    Lookin' to take my 2001 4x4 up 2.5-3". PM me what I need and my name to the list!
  11. Aug 2, 2010 at 8:46 AM
    3fitty
    3fitty Well-Known Member
    Lambone
    Gulf Coast
    01 Prerunner
    Bilstein 5100 front, 5125 rear and Skyjacker AAL. Manaflow Catback exhaust. aFe Pro-Dry air filter.
    I want the rear leafs. It says anti-wrap - so does that mean ZERO wrap or very minimal wrap? And if my wife loves me then she will get me the Bilstein coilovers :)
  12. Aug 2, 2010 at 8:57 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    T50 pack?
  13. Aug 2, 2010 at 9:03 AM
    jandrews
    '09 FourDubDee TRD OR
    Can someone give me a run-down on how Walker-Evans compare to Icon/King, primarily in terms of durability and ability to take a beating?Don't give much of a shit at all about ride quality.
  14. Aug 2, 2010 at 9:47 AM
    imtwistd
    imtwistd Going nowhere as fast as possible
    I forgot
    Liverpool NY
    08 dbl cab long bed sport 4x4 beast
    AllPro offroad front LT with Fox 2.5 shox and AllPro expedtion rear springs with Fox piggy back res shox, TRD skid plate, Toyota roof rack, Undercover tonnuea cover, Pro comp 3" lift, 4 Pro comp 8" offroad lights, 17" XD Series "SPY", Nfab tube steps and light bar, Fitch Fuel, Flexalite fan, Unichip, URD cai, TRD supercharger, URD y-pipe, Banks monster cat back, debadged, projection head lighs, LED tail lights and a loud stereo, Stainless Steel Brake Lines front and rear, Doug Thorley long tube headers, Walboro 255 fuel pump, KC rock guards on my Pro Comp 8" lights
    I want the leaf springs, but do they come with shocks?
  15. Aug 2, 2010 at 10:35 AM
    allpro
    Montana
    Fox unfortunatly does not give us any reasonable volume discounts, so the most we can offer is 10% off when you buy other components, like if you buy the rear leaf springs, you can get 10% on the rear 2.0 Fox Shox, or if you buy the front UCAs, then we can give you 10% off on the Fox 2.0 Coilovers.
    I've sent a quote request to Aloha Freight.
    The springs were originally due in last month, but the new ETA is 8/5. I'll be sure to apply the discount to your order. We'll apply the starting discount level, then credit you back any additional discounts if applicable at the end of the group buy.
    PM Sent!
    Axle wrap is minimized with the anti-wrap leaf, but it also varies between trucks depending on what tire size & gears you have.
    Sure, we can extended the group buy pricing to the Baja Leafs too, I'll add them shortly.
    The leaf springs come with bushings only, but shocks can be purchased at a 10% discount with the leafs.
  16. Aug 2, 2010 at 12:49 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Saaaahweeet lol
  17. Aug 2, 2010 at 1:00 PM
    allpro
    Montana
    $185.35 for a set of leaf springs w/bushings via Aloha Freight (UPS is over $300!)
  18. Aug 2, 2010 at 1:19 PM
    sinaloa226
    sinaloa226 SIINALOA 226
    PATTERSON, CA
    10 DC 4X4,
    POWDER COATED WHEELS, KM2, LEATHER INTERIOR
    Is the price on the website for the w.e. Coilovers wrong because they are less the price posted on here?
  19. Aug 2, 2010 at 3:56 PM
    Burgman
    Stephen
    Ric VA
    check the prices again, you are probably looking at the 2.0 models... the ones on sale are the 2.5s
  20. Aug 2, 2010 at 6:20 PM
    TacomaTSP4
    TacomaTSP4 Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    is there any way we can get the 2.0 W.E. coilovers in this group buy if we dont want the 2.5's?
Thread Status:
