All pro U-Bolt flip kit concern.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05RedTaco, Dec 13, 2011.
  1. Dec 13, 2011 at 3:08 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have add a leaf and need new U-Bolts, so I thought that instead of getting just the U-Bolts, why not get the U-Bolt flip kit from All-Pro since its only $10 more?
    I have done some research and it seems that the U-Bolt flip kit doesnt work with stock bump stops. From what I have researched it seems that most people who have the U-Bolt flip kit run it without bump stops. Now this is a concern for me since I haul heavy loads in the bed of my Taco and had 1500lbs or more in the bed. The rear end was sitting on the bump stops...
    Will I damage my truck by hauling loads without bump stops? I would guess yes, but would like some opinions from TW...
  2. Dec 13, 2011 at 3:29 PM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    I would not run without bump stops. Just get the kit with the timbren bump stops.
    Or for a cheaper route, get some bump stops from Wheeler's and make it work. Do a search cause others have done this. Just look in the vendor section under Wheeler's offroad. :cool:
  3. Dec 13, 2011 at 3:37 PM
    05RedTaco
    Tony
    Scottsdale
    The Timbrens are Hella expensive, I am on a budget so thats not an option... I wonder If I can make the stock bump stops work with the flip kit...HMMM
    Wheelers bump stops have the same exact mounting points as stock bump stops, so they wouldn't work without modification either...
  4. Dec 13, 2011 at 3:51 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    Just tack weld the stock bumps to the top plate for the flip kit. I did that on my old truck as well as quite a few others. Problem solved. :D
  5. Dec 13, 2011 at 3:54 PM
    05RedTaco
    Tony
    Scottsdale
    Badass! I happen to know friend with a welder :D
  6. Dec 13, 2011 at 3:55 PM
    Fire931
    VA
    00 4Runner
    There ya go. Just as a note they just do fit on top in between the ubolts but it does all work out without any mods. Takes about 5 mins to do.
  7. Dec 13, 2011 at 4:14 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Subbed for future reference. :)
  8. Dec 13, 2011 at 4:18 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    exactly what i was going to say
  9. Dec 13, 2011 at 6:00 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Best thing to do is to go down to O'Reilly Auto parts and pick up a set of the energy suspension cone style bumps they sell for $12. Drill the holes in your bump strike pads (on the frame) and bolt them upside down, facing your U-bolt flip plate. It's a fifteen minute install and gives you another 2'' of travel versus the Timbrens.
  10. Dec 13, 2011 at 6:09 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Sounds familiar
    Just make sure they are long enough so you don't rip your fender off at full stuff. I don't have any cracked welds or metal yet....
  11. Dec 13, 2011 at 10:25 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Interested.subscribed
  12. Dec 14, 2011 at 7:07 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    I just cut my stock bumps to fit on top and drill holes to mount then (drill tap top plate) works great!
  13. Dec 14, 2011 at 7:16 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i run the timbrens i love them man much better than the stockers. they soft and progressive and cushion things nicely if you do ever hit on them.
