All Pro U Bolt Flip Kit question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROGU3 PR3DATOR, Feb 18, 2012.
  1. Feb 23, 2012 at 3:12 PM
    GVY
    GVY All those moments will be lost in time
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    Bushwacker Cut-Out Fender Flares, ARB Winch Bull Bar, 3" All Pro Bilstein Coilovers, All Pro UCAs, Wheeler Off Road Custom Rear Bumper, All Pro Standard Leaf Pack, Bilstein 5125 rear shocks, All Pro steel-braided brake lines, U-Bolt flip kit, JBA cat-back exhaust, KC 6" Daylighters & 2x6" driving lights, AFE Pro Dry Air Filter, Deck plate mod, Toytec 1" shackles, Rhinolined bed, Tiregate Prerunner, Procomp 85 gloss black steel wheels, 285/75/16 Toyo Open Country M/Ts
    Is the shock mount not on the stock u-bolt plate for 2nd gens then?
  2. Feb 24, 2012 at 5:06 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR [OP] Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Nope, its just a bracket that cups the axel. Shock mounts are on the axel I believe. Never really paid much attention...
  3. Feb 24, 2012 at 8:15 PM
    GVY
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    Ah. That's convenient. 1st gens need to weld on new shock mounts to the rear axle for a U-bolt flip. I just figured they were all the same.
  4. Feb 25, 2012 at 7:21 AM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    That really sounds like a PITA just for a u bolt flip.
  5. Feb 25, 2012 at 5:14 PM
    GVY
    Guy
    FT Bragg
    98 Tacoma 2.7L SR5
    You said it.
  6. Feb 25, 2012 at 6:09 PM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    I double checked today, the shock mounts are welded to the axel.
  7. Feb 25, 2012 at 7:08 PM
    Oysterhead
    Oysterhead Well-Known Member
    Nashville
    '10 TRD OR
    Kings are king
    Bought the AP flip kit but they're out of stock til Friday.
    Bummer because I'm installing sliders on Wed, was hoping to tack the bump stops to the new plate in the process. (relying on my uncle for the welder/welding)
  8. Feb 25, 2012 at 10:38 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    So the supplied nuts for my flip kit have a dimple in the side which acts a lock nut, it is a pain to get threaded down. If you know how much thread you can loose, I'd suggest cutting the u-bolt down.
    I used a set of Tibrens. Other options are drilling the stock bumpstop or Wheeler Super Bumps. Also I have seen someone on here use poly bushing that is mounted to the frame.
  9. Feb 25, 2012 at 11:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Can't you weld the stock ubolt plate to the flip kit plate?
  10. Feb 26, 2012 at 12:10 AM
    singlefin
    Hood River, OR
    Syncro
    I thought that's what you did?
  11. Feb 26, 2012 at 12:48 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Me? I don't have a flip kit. :p
  12. Feb 26, 2012 at 7:24 AM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    You could weld the stock bump stop to the flip kit plate, but not the stock ubolt plate to the flip kit plate. The stock one goes under the axel, and the flip kit goes on top of the leafs. It would serve no purpose at all.
  13. Feb 26, 2012 at 10:35 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Gah that's what I meant haha. :D
  14. Mar 10, 2012 at 2:17 PM
    Oysterhead
    Nashville
    '10 TRD OR
    Kings are king
    Can anyone confirm that both the stock and All Pro nuts on the flip kit are 22mm?
    I need to buy a deep socket...
  15. Mar 10, 2012 at 4:18 PM
    #35
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Stock and all pro are the same size. 7/8 is what I used. Seemed like the right size. I dont have a 22mm to verify.
  16. Mar 10, 2012 at 5:23 PM
    #36
    Oysterhead
    Nashville
    '10 TRD OR
    Kings are king
    I went to the FLAPS.
    22mm deep socket seems to fit perfectly.
  17. Mar 10, 2012 at 7:16 PM
    #37
    badger
    badger Well-Known Member
    07 SR5
    The AP nuts are standard 7/8" but a 22mm is only .009" smaller, so most 22 mm sockets should still fit
  18. Mar 12, 2012 at 7:43 AM
    #38
    Oysterhead
    Nashville
    '10 TRD OR
    Kings are king
    A pic of stock bump stops tacked to top plates from AP Ubolt Flip Kit.
  19. Feb 9, 2020 at 1:57 PM
    #39
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Thread revival. Sorry. I tried installing my all pro flip kit today and ran into the same issue. Can't tighten the nut by hand past 1/2" and it is incredibly difficult still with my 90 ft/lb cordless ratchet. From what I'm reading here I need to lubricate the threads first and it will be much easier?
