All Pro Ubolt flip install question
Discussion in 'Suspension' started by Voodoo Rufus, Mar 21, 2012.
  1. Mar 21, 2012 at 8:21 PM
    Voodoo Rufus
    Voodoo Rufus [OP] Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    The flip kit came with the Ubolts and Locknuts. Am I supposed to re-use the OEM washers to go between the nut and the leaf hold down plate, or does it matter?:confused:
    Lessons learned in Post 6.
  2. Mar 21, 2012 at 8:23 PM
    BCTacoma
    BCTacoma Well-Known Member
    Port Hardy, BC
    06 SR5 Tacoma
    Toytec ULK, OME Dakars, Bilstein Shocks, Extended Brake Lines, 285/75/16 Duratracs, Pro Comp Steel wheels, Relentless Fab Front Bumper/Sliders
    I would. The AllPro didn't supply any washers ?
  3. Mar 21, 2012 at 8:50 PM
    Voodoo Rufus
    Bakersfield, CA
    Nope. I already wrenched the nuts most of the way down, but didn't torque them yet. I guess it's not too big of a task to take them off.
  4. Mar 22, 2012 at 8:50 AM
    Voodoo Rufus
    Bakersfield, CA
    Too late, already done! The washers are on, they certainly can't hurt.
  5. Mar 22, 2012 at 8:55 AM
    Voodoo Rufus
    Bakersfield, CA
    Pre-install:
    Heights, hub to fender:
    FL 20 3/8" FR 20 1/2"
    RL 21 1/4" RR 21 7/8"
    Post install heights, one overload removed:
    RL 24" RR 24 1/2"
    I have not installed my coilovers yet, planning on doing that this afternoon.
    Things of note:
    1. Ratchet strap from axle to frame/sliders helps reposition the axle better for the front leaf bolt
    2. Find the best spots to align the All Pro U-bolts before tightening otherwise you will have interference with the Timbren mount. This may require hammering after torquing as well
    3. Icon 2.0 VS shocks need to have their rubber bushings trimmed to fit in the OEM shock mount
    4. If you have a Hellwig rear sway, unlink the threaded rods or you will bend them. I now need to replace mine.
    5. If I think of anything I'll add it here.
  6. Mar 25, 2012 at 9:57 AM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    icon bushings dont need to be trimmed.. you either got there 1st run or FJ shocks.. im guessing you bought them from a guy on this site ?
  7. Mar 25, 2012 at 10:22 AM
    Voodoo Rufus
    Bakersfield, CA
    Yeah. Parts Whore Xmas group buy.
    The plastic I just trimmed down with a hacksaw and a box cutter. The metal bushing itself seems to be the right size.
  8. Mar 25, 2012 at 3:01 PM
    97Taco09
    97Taco09 Active Member
    Jojo
    Greenwood, Florida
    96 Tacoma LX 3.4V6 4x4
    2" Body Lift
    What does this kit do to the suspension?
  9. Mar 25, 2012 at 3:38 PM
    surfrat
    LI, NY
    oh..that explains it.. watch your shock shaft for rust.. there FJ shocks btw
  10. Mar 25, 2012 at 7:46 PM
    Voodoo Rufus
    Bakersfield, CA
    Any particular reason these might rust more than others?
