All pro ubolt flip kit timbren/bump stops
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darektylka, Mar 19, 2014.
  1. Mar 19, 2014 at 12:36 PM
    darektylka
    darektylka [OP] Well-Known Member
    Darek
    Chicago
    Taco TRD Sport DCLB 4x4
    For installing the all pro ubolt flip kit what's the advantage of having the timbrens? Can you use the flip kit without any bump stops?
    ChadsPride likes this.
  2. Mar 19, 2014 at 12:46 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    They work great for hauling heavy loads, but they do take from some of the uptravel due to their height.
    IMO they are more designed for hauling/towing rather than offroad, at least this is what Timbren designed them for. They are also pretty pricy for a bump.
  3. Mar 19, 2014 at 12:55 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I like using the timbren with a softer leafpack. Instead of the OEM bumpstop, they are very flexible and smooth and act like a progressive damper. They are perfect combined with a deaver leafpack so you have a pretty smooth and progressive ride without loosing too much load capacity.
  4. Mar 19, 2014 at 1:11 PM
    darektylka
    Darek
    Chicago
    I'm ordering the Dakar leaf pack to get the 2.5" of lift and more carrying capacity. Anyway to use the stock bump stop with the ubolt flip kit? Also, what if you only have the flip kit and no bump stops at all and carrying a load about 1000LB-1500. Will anything get damaged since there is no bump stop?
  5. Mar 19, 2014 at 2:37 PM
    Mr Salty
    Hermmy
    Lots of chrome
    You will reverse arch the spring packs over bumps and possibly contact the top plate and bolts/nuts with the chassis. Basically don't go without the bumps.
    With the flip kit there is no other option other then getting a universal bump and welding it to the ubolt plate or the chassis above.
    Honestly a lot of folks buy these flip kits without understanding this nor even needing them because they don't plan to drag their shit all over rocks, which is the whole purpose of the flip kit.
    Mademan925 and ChadsPride like this.
  6. Mar 19, 2014 at 2:44 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you're not really losing any travel with the timbrens. you'll still push your leaf pack into negative arch (which is okay, since most packs are designed for a small amount of neg arch). the downside to them is that if you like higher speed wheeling, they rebound quickly
  7. Jan 4, 2016 at 12:01 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Yep that works to
  8. Jan 13, 2017 at 2:33 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    This is nice.
    I just got a Ubolt flip kit from All Pro and Timbren bump stops.
    I like how you did this though.
  9. Mar 31, 2017 at 1:46 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Thread revive: How do you install them upside down like that with the flip kit? THe ones I have don't have screw holes on the sides, just where the ubolts can hold the metal bracket down. That won't work as I have the flip kit. Weld on I guess? Pics would be much appreciated! Going to install mine this weekend
  10. Mar 31, 2017 at 7:32 PM
    aubi1414
    Justin
    Pensacola, FL
    anybody
