All-Pro's Newly Re-Designed Transfercase Skid Plate
Discussion in 'FJ Cruisers' started by allpro, Jun 14, 2012.
  1. Jun 14, 2012 at 3:32 PM
    allpro
    allpro [OP] Well-Known Member Vendor
    Montana
    All Kinds Of Toyotas!!!
    NEW TRANSFERCASE SKID
    It’s obvious that extra protection is needed when traversing vigorous trails that are beating up your new FJ Cruisers. All-Pro’s heavy-duty Transfer Case/Exhaust Skid Plate protects your transfer case and exhaust cross over pipe from getting smashed by the rocks on the trail. The skid plate is made out of heavy-duty 3/16" steel plate that is mounted to .120 wall round steel tubing which extends to the frame rails with bolt-on backing plates. This innovative design essentially spreads the load from any impact to the frame instead of to the transfer case, which as we know is a vital (and costly) component in four-wheeling.
    Easy bolt-on installation using the included hardware with low profile countersunk bolts that won't get snagged on the rocks. You'll be protected and ready to hit the trails in no time. Our skids provide the highest possible ground clearance - more than any other skid on the market - so you won't get unnecessarily hung up. This product has it all: function, fit and performance, and it even comes powder coated black!
    Now Available for Only $299
