**ALL SOLD** Mobtown, SwitchPros, Fox, Hondo Un-Holey (N. Virginia)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by velogeek, Feb 24, 2020.
  1. Feb 24, 2020 at 2:01 PM
    velogeek
    velogeek [OP] Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Traded in the 3rd gen... hopefully the 4th has a better payload and an AT that I can live with so my wife will enjoy wheeling but in the mean time I've turned to the dark side to check all the boxes. On that new truck high in a good mood so this is priced to sell because I seriously owe my wife something nice now.
    Located west outside the DC beltway and I'm willing to drive a few hours for the pricier parts or anywhere along 81/40 between DC and Knoxville TN. Will ship where noted at your expense.
    NOTE: I'm keeping order of inquiries on the small stuff and will offer it up in order but on the large stuff, it's first come, first served. Shipping will be a bitch on the suspension and bumper so I'll sell to the first person to show me the money or at the least, a deposit via paypal.
    Fox 2.5 Rear Shocks - Smoothie w/ Reservoir (FOX-883-24-007) - $700
    Same deal, brand new, in the storage unit, will get pics and update. Good for a 1.5" lift but would just cost you a little down travel if you went higher.
    Fox 2.5 Front Shocks - Emulsion Coilover (FOX-883-02-025) $1,000
    Same deal, brand new, in the storage unit, will get pics and update. Will need UCAs for these or they are likely to contact the arm on full droop. Good for up to a 3" lift.
    Will do the full Fox set for $1,500 if you want both.
    TRD Off-Road Wheel and Tire - $100
    Need to get a stem installed and seat the bead but the tire is barely worn. Picked this up so I'd have a matching wheel for the bumper tire carrier and never installed either of them.
    [SOLD] Mobtown Standard Plate Rear Bumper w/ Dual Swing-Out - $1500
    Sold for $1400 picked up locally
    Picked this up last month, never installed. Includes all hardware and no wait. List is like $2300 with powder.
    [SOLD] SwitchPros SP9100 w/ SDHQ Tacoma bracket USED - $350 (will ship)
    Nice under-hood install bracket that goes under your clutch reservoir or uses those holes on your driver inner fender if you bought an inferior truck.
    The kicker: (1) You will need new labels ($14 via SP) for the panel as I lost them. (2) You will need to splice the 4-pin communications cable or get a new one (Confirmed $39 directly from SP and you have to call) because I cut it when I couldn't find my pin tool as the connector doesn't fit through any standard firewall hole. It's fine wiring so splicing might be a bitch on this one. There's about 5' of cable on the main unit side so you could probably just redo the molex on the head unit side if you have the tools.
    4AWG main power with a Blue Sea MBRF fuse at the terminal that you can connect under the batt(+) nut. I upgraded the wiring to 12awg (actual molex pins using the actual expensive AF molex crimper) and the leads are generally long enough to just use straight out of the unit instead of the 2' leads that you normally get on the thing.
    This does not require additional fuses as it's solid-state so no external fuses or relays required.
    [SOLD] Hondo Un-Holey v2 w/ RAM Ball Mount - $25 EA or $40 for both (will ship)
    Good condition and surprisingly stable. Ran these with a 6th gen iPad (on a very short arm) and they did just fine.
    [SOLD] Mobtown Weld-On Rock Sliders - short wheelbase - $200
    Hope this can slide without pics as it's in my storage unit but they're unfinished and there are a few parts to be welded on aside from just slapping it onto the frame. I'm planning on heading out that way this week sometime and will update with pics before sale.
  2. Feb 24, 2020 at 2:05 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
  3. Feb 24, 2020 at 2:08 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    @velogeek I'll take the SwitchPro. PM incoming
    ramonortiz55, AY_ARONTRD and SuperBad like this.
  4. Feb 24, 2020 at 2:17 PM
    Kcm10883
    Kcm10883 Well-Known Member
    2019 Cement DC TRD Off Road
    Does this version of the Hondo garage allow for the vents to be opened or closed?
  5. Feb 24, 2020 at 2:20 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    PM’d for Hondo Un-Holey v2, I’ll take both.
  6. Feb 24, 2020 at 2:23 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Not really. You get about half the normal movement but they don't fully open or come anywhere near closing.
  7. Feb 24, 2020 at 2:26 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    You are #2... someone beat you via PM by like 5 mins.
    9TRDTCO[QUOTED] likes this.
  8. Feb 24, 2020 at 2:26 PM
    MidwestTactiTaco
    MidwestTactiTaco Well-Known Member
    Northern Illinois
    '18 DCSB TRD OR
    Second in line for the switch pro.
    PM inbound.
  9. Feb 24, 2020 at 2:28 PM
    9TRDTCO
    Thanks
  10. Feb 24, 2020 at 2:28 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  11. Feb 24, 2020 at 2:44 PM
    Tomshouse516
    Tomshouse516 Well-Known Member
    Thomas
    Doylestown, PA
    11 DCSB TXtrd
    33's and some stuff
  12. Feb 24, 2020 at 3:05 PM
    Shubey
    Shubey Well-Known Member
    Scott
    Fleetwood PA
    What cab/bed are the sliders for?
    Thanks
    Shubey
  13. Feb 24, 2020 at 3:29 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Probably should have said that but short wheelbase.
  14. Feb 24, 2020 at 5:35 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    How has noone scooped that rear bumper yet?!
  15. Feb 24, 2020 at 5:52 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Probably because it's 190 lbs according to Mobtown and it's probably gotta be local haha.
  16. Feb 24, 2020 at 6:18 PM
    Hold The Gauc
    Hold The Gauc Before we get started, does anyone wanna get out?
    I will never financially recover from this
    Interested in shocks and sliders, located in central VA
  17. Feb 24, 2020 at 6:24 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Sliders someone has a deposit down and I'm meeting them this weekend or next. Shocks have inquiries but nobody has committed.
    Making a note in the post about first come first served on the big ticket stuff so if you're interested, I can meet up this weekend for the suspension.
    Mack411 likes this.
  18. Feb 24, 2020 at 6:30 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    A few updates to the original post for those tracking, Switch-Pro and Un-Holey mounts sold; sliders have a deposit and a pending sale in person in the next week or two.
    Mack411 likes this.
  19. Feb 24, 2020 at 9:05 PM
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Really tempted by the rear bumper and I'm close enough to make Knoxville a thing........
  20. Feb 24, 2020 at 10:26 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Negatory on the weld ons. You know this doggy.
