All Steering and suspension parts.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jlmartinez0305, Oct 8, 2020.
Can you guys help with websites that I may need?
  1. Any
    0 vote(s)
    0.0%
  2. Any
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Oct 8, 2020 at 1:32 AM
    Jlmartinez0305
    Jlmartinez0305 [OP] New Member
    Joe
    2001 4wd v6 prerunner
    None
    Working from the bottom up ... replacing everything. Any assistance is major help. Thank you guys.
  2. Oct 8, 2020 at 9:35 AM
    Jlmartinez0305
    Joe
    None
    So far I have replaced rotors, calipers. Moving to joints, And rack opinion. I was wondering if any of you know what specific parts I need. I don't know the names .
    All the joints and large parts.
  3. Oct 8, 2020 at 9:37 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sway bar bushings and end links
    Steering rack bushings
    Tie rod ends
    Lower ball joints
    Lower control arm bushings
    Upper ball joint
    Upper control arm bushings
    Coilovers
    Fluids an obvious given.
    Radiator
    Plugs
    Fuel filter
    Air filter
    Clean MAF
    Clean throttle body
    Check and clean grounds
    Jlmartinez0305[OP] likes this.
  4. Oct 8, 2020 at 9:39 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Welcome to TW
  5. Oct 8, 2020 at 9:45 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I've given these people lots of $ replacing suspension parts. :spending:
    https://www.lowrangeoffroad.com/
    Definite improvements......
    • replace steering rack bushings with polyurethane bushings (Energy Suspension)
    • replace sway bar bushing with poly bushings (Energy Suspension)
    https://www.energysuspensionparts.com/8.10103
    Lastly from my experience....if you replace the sway bar links, go with the 555 brand (made in Japan) from Low Range. I had the Moog replacements and they are not even close in the quality of the 555 brand.
    https://www.lowrangeoffroad.com/toy...ar-end-link-made-in-japan-tac-sp-sbl0104.html
  6. Oct 8, 2020 at 9:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just watch this channel, but not all parts need to be replaced especially when paying attention on to how to inspect them. Lower ball joints will be the only legitimate item I encourage you to replace.
    https://www.youtube.com/c/TimmyTheToolman/playlists
  7. Oct 8, 2020 at 10:12 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
  8. Oct 8, 2020 at 11:10 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    buy genuine toyota lower ball joints, in the long run, you'll be glad you did. If you just can't afford them then use 555 branded ones made in japan. google toyota tacoma lower ball joint failure, it's not pretty.
