All-Terrain 265/75r16? Suggestions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HSmith_11, Nov 30, 2016.
  1. Dec 8, 2016 at 8:32 AM
    #81
    HSmith_11
    HSmith_11 [OP] Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Yep I'm finally learning enough to teach others. But keep in mind that you'll have to do some more unique cutting if you get 285s or 33x12.50s
  2. Dec 8, 2016 at 8:37 AM
    #82
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Cooper st maxx...no doubts that they are a superior tire.
    DustStorm4x4 likes this.
  3. Dec 8, 2016 at 2:52 PM
    #83
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I have no experience with this issue but would a set of 1" spacers help OP to get rid of the rub on his 285's??
  4. Dec 8, 2016 at 2:55 PM
    #84
    HSmith_11
    Hunter
    Madison, Va
    I have 33x12.50s right now. Much wider than the 285s
  5. Dec 9, 2016 at 7:12 AM
    #85
    BerettaMato
    BerettaMato ELKAHOLIC
    Beretta
    Niwot Colorado
    04 DC 4x4 TRD Black & 99 EC 4x4 TRD Green
    04,ARB,Warn,Bilstien,Slee & Duratrac. 99,ARB,Warn,OME,Slee,BFG & CVT.
    He does not have 285's. His main problem in the 12.5 width. I have the same tire size on my 99. I have trimmed the basic items but but still rub the Frame, Washer reservoir and the rear fenders. I bought 285/75r16 but they rubbed even worse since the are actually taller than 33/12.5r15. I had two choices for sizes left 33/10.5r15 or 265/75r16. I wanted to be 100% no rubbing and be able to use chains so 265 is it. Spacers are very unsafe and will put a ton of extra strain on your bearing.
  6. Dec 9, 2016 at 7:13 AM
    #86
    HSmith_11
    Hunter
    Madison, Va
    Thats my exact issue. Except I'm gonna skip the 285/75 step so i can be completely sure
  7. Dec 9, 2016 at 7:19 AM
    #87
    BerettaMato
    Beretta
    Niwot Colorado
    The 33/10.5r15 are made in KO2 and might be a great way for you to go and they are cheaper than 265 route. you will still have to do the rear fender bottom screw mod to get them flush and you will still rub the washer tank guard at full compression but that is all. What is the back space of your 15" wheels.
  8. Dec 9, 2016 at 7:21 AM
    #88
    HSmith_11
    Hunter
    Madison, Va
    3.75, but I also wanna go back to a 16" cause I don't really like the 15" steel rim. id rather just run my stock rim until I can get some 16" alloys.
  9. Dec 9, 2016 at 7:23 AM
    #89
    BerettaMato
    Beretta
    Niwot Colorado
    I here you. I did the same thing
  10. Dec 9, 2016 at 7:25 AM
    #90
    HSmith_11
    Hunter
    Madison, Va
    Yea i shouldve just done it that way the first time. But oh well, just another lesson.
  11. Dec 9, 2016 at 7:25 AM
    #91
    BerettaMato
    Beretta
    Niwot Colorado
    Make sure you get a 4-4.25 back space when you get the 16" wheels
  12. Dec 9, 2016 at 7:26 AM
    #92
    HSmith_11
    Hunter
    Madison, Va
    Why is that? Just curious. And what is the stock backspacing on my older wheels.
  13. Dec 9, 2016 at 7:37 AM
    #93
    BerettaMato
    Beretta
    Niwot Colorado
    It will help give the stance you are looking for to match the flares and give you more option for future tire sizes if you want to go bigger. The 04 in our build is a 4.1 BS. If I went 4.5 I would have probably had to put in a SPC UCA. Like I did on my other two. Angie's 04 has a 3" toytec billy lift and a 1.5 ADD in the rear but she has 250lbs of extra weight up front that brings it down to 2.5".
  14. Dec 9, 2016 at 7:39 AM
    #94
    HSmith_11
    Hunter
    Madison, Va
    Ohhh cause i was wondering how people with 265s had there tires out as much as they do.
  15. Dec 9, 2016 at 7:40 AM
    #95
    BerettaMato
    Beretta
    Niwot Colorado
    Your stock BS is 4.54"
  16. Dec 9, 2016 at 7:41 AM
    #96
    HSmith_11
    Hunter
    Madison, Va
    Okay thanks a lot. Will I have any problems running the 265/75s on my stock rims for a while.
  17. Dec 9, 2016 at 7:42 AM
    #97
    BerettaMato
    Beretta
    Niwot Colorado
    Yes but a 3.75 will put strain on the bearings since they are so far out. 4" is the sweet spot but most rims are 4.5".
  18. Dec 9, 2016 at 7:43 AM
    #98
    BerettaMato
    Beretta
    Niwot Colorado
    On road should be fine. what lift do you have?
  19. Dec 9, 2016 at 7:43 AM
    #99
    HSmith_11
    Hunter
    Madison, Va
    I'm planning on getting some of those SCS wheels once I can get the money. maybe a birthday present in March.
  20. Dec 9, 2016 at 7:43 AM
    #100
    HSmith_11
    Hunter
    Madison, Va
    2.5" via billies at 2.5 and a 1.5" progressive aal in the rear with billies.
