All Terrain Tire Question!! (5 LUG)
Discussion in '5 Lug' started by LBCdan, Mar 10, 2011.
  1. Mar 10, 2011 at 12:44 AM
    LBCdan
    LBCdan [OP] I got tiger blood.. WINNING
    Dan
    Long Beach , CA
    2012 MGM DCSB TRD SPORT
    Pioneer 4000NEX , grab handle GPS mount, Bakflip tonneau, OME 885, Bilstein 5100s, Wheelers 1.5" AAL
    2009 2wd taco
    readylift 3"
    KMC Enduro 16x8
    245/75/16 BFG Long Trail
    Miles Per Tank BEFORE Lift, Rims, Tires = 400 miles
    Miles Per Tank AFTER Lift, Rims, Tires = 350 miles
    I found out I am moving to Connecticut in a couple months and it is my understanding that it snows and rains like no other during the winter months. I am looking to buy some A/T for the winter season. Can anybody recommend a good all-terrain tire that also won't kill my gas mileage & won't kill my power? I spoke with a guy at American Tire/Discount Tire and he said that the BFG All Terrain would ruin my gas mileage. I currently have BFG Long Trails (Load E) and the weight difference is only 5lbs per tire. Would that really change much? :confused:
    Any advice? Suggestions? Thanks for the help.
  2. Mar 10, 2011 at 11:09 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    you should get bfg all terrains.
  3. Mar 10, 2011 at 11:11 AM
    Yota Newb
    Yota Newb Well-Known Member
    Bryan
    Indiana
    2010 5-Lug Regular Cab 2.7L 5 Speed
    I think BFG A/T's are the heaviest all terrains you can get, which some would say is a good thing. They are a great tire and you may think about re gearing, which may help both with low end power on take off and high end cruising?
    Look at Tirerack . com they usually have a ton of reviews and detailed specs on all kinds of tires, like weight.
  4. Mar 10, 2011 at 11:27 AM
    LBCdan
    Dan
    Long Beach , CA
    I have been looking everywhere... but of course you get mixed reviews for every kind of tire with every type of truck/suv. I was leaning toward the BFG A/Ts .. thanks for the input.
  5. Mar 10, 2011 at 3:42 PM
    Yota Newb
    Bryan
    Indiana
    Just some more food for thought,
    The BFG's are an excellent choice but your concern was MPG's.
    I did a quick comparison between four tires. Dunflop AT20's(stock tire), Firestone Destination A/T, Goodyear DuraTrac's, and BFG AT/KO all in 245/75/r16
    Overall rating 0 being worst and 10 being best:
    Dunflop: 2.5 LOLOLOLOL! big suprise!
    Firestone AT: 8.7
    Dura Trac: 8.3
    BFG's: 8.5
    Weight of each tire:
    Dunflop: 32 lbs
    Firestone: 36 lbs
    DuraTrac: 40 lbs
    BFG's: 48 lbs
    There are a ton of other stats that I thought were interesting. I can say I have had BFG AT's and the Firestone Destination A/T's on two different Jeeps and I have to say I liked the Firestone's better. The Destinations were very impressive off road and on, especially in wet condition on road. The Firestone's were also around $500 for a set, and that was for 31's.
    Not trying to talk you out of the BFG's just suggesting some other options from past experience. I can say you will notice a drop in mpg no matter what in a bigger tire, but I believe it will be the most pronounced with the BFG simply because it's physics, the heavier the tire, the more work the engine has to use to turn them.
  6. Mar 10, 2011 at 7:08 PM
    LBCdan
    Dan
    Long Beach , CA
    Thanks for advice. I am worried about the MPGs but also driving on ice and snow. The way I see it is 20 (5 lbs. per tire) more lbs of tire couldnt make that much of a difference. My BFG Long Trails weigh 43 lbs each.
    Firestone?:eek: I have seen a Firestone tire explode when they were having all of those problems... which is why Firestone is always my last choice.
    Thanks for your help. :thumbsup:
  7. Mar 10, 2011 at 7:34 PM
    Yota Newb
    Bryan
    Indiana
    Lol, don't blame you with the Firestone's.
    And yeah, I would agree that the little extra weight shouldn't take too much away.
    Good luck, post some pics if you get a chance when you get your tires.
  8. Mar 10, 2011 at 8:14 PM
    LBCdan
    Dan
    Long Beach , CA
    Will do. Thanks again for the help.
  9. Mar 11, 2011 at 7:08 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Another option would be to wait until next fall and get a dedicated set of winter tires, possibly even studded. Pick up a set of stock steel rims to put them on and just use them in the winter.
  10. Mar 12, 2011 at 11:28 AM
    LBCdan
    Dan
    Long Beach , CA
    I was thinking about that too... but I won't have enough space to keep an extra set of tires. I will probably just get some BFG A/Ts AFTER I drive across the country.
  11. Mar 13, 2011 at 12:44 PM
    bluetaco99
    bluetaco99 Well-Known Member
    michael
    chino ca
    06 5lugger
    i have a set of bridgestone revos 2. and i love them, ive never had bfgs but the bridgstones do good on dirt and there a specific made winter track tire. the only downfall is there horrible in mud...but other than that great tire cant complain much.
  12. Mar 13, 2011 at 1:45 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    There is no comparison between the winter vs AT tires, the winter tires will outperform the AT on every ice/snow covered road you drive on. I have 4 vehicles at home with 2 sets of tires for each (snow & all season). If you're truly worried about ice/snow traction a dedicated snow tire is the only way to go, save the AT's for what they are intended for unimproved roads/trails/mud.
    I had Bridgstone Revo's on my old 2wd Ranger great tire for section line roads in ND but anything more than a dusting of snow or ice and they were horrible. Keep in mind the temperatures also play a factor for traction, when it's 20 degrees or lower any all season/AT tread compound is literally frozen stiff, think hockey puck hard, great for ice not so good for traction.
  13. Mar 16, 2011 at 10:33 AM
    jmtz14690
    jmtz14690 Member
    Josh
    Albuquerque, NM
    06 Tacoma Access Cab 2wd 4cyl 5 speed manual
    I have Good Year Wrangler Duratrac tires on my truck and love them. I did research for over a month on a few tires and I saw nothing but good reviews overall for these tires. I recently took the plunge and put them onto my truck and they are awesome tires. The ride is smooth and traction is good. Plus they have an aggressive look and make my truck look awesome. If I could recommend any tire that would look good and work great it would be these ones.
  14. Mar 19, 2011 at 12:45 PM
    LBCdan
    Dan
    Long Beach , CA
    Have you taken the Wranglers in the snow?
  15. Mar 20, 2011 at 12:20 PM
    jmtz14690
    jmtz14690 Member
    Josh
    Albuquerque, NM
    No, unfortunately it was a very dry winter here this year. I have already put almost 400 miles on them on the highway however for long distance trips and they work remarkably well. I have used them in mud though and they worked great. Cant wait to find some snow to try them in.
  16. Mar 20, 2011 at 10:59 PM
    LBCdan
    Dan
    Long Beach , CA
    Awesome. Let me know when find some powder to test them out in. Luckily, I have some time before I need to make a decision.
