All terrain tire with a quiet ride?
Discussion in 'Wheels & Tires' started by Assumer, Dec 20, 2022.
  1. Dec 20, 2022 at 3:13 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Michelin.
  2. Dec 20, 2022 at 4:11 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Ill take the broad and the tires
    Treggit and McGillz like this.
  3. Dec 20, 2022 at 7:13 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    The problem with these tires is that their rubber composition does not provide for long life on bare pavement. Which is why with my Michelin Latitude X-Ice I wait until the weather really turns to snow before I'll swap them on.
    D.A.S. Taco likes this.
  4. Dec 20, 2022 at 8:02 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    A 3PMSF rated tire is one that has scored 25% better than the reference tire(Uniroyal Tigerpaw 225/60/16/97); mounted on a specialized test vehicle, in an acceleration test, on medium packed snow.
    Is a 3PMSF all that?:notsure:
    DuffyBank likes this.
  5. Dec 20, 2022 at 8:53 PM
    McGillz
    McGillz “It’s not accessorizing... It’s a BUILD!”
    New Jersey
    '19 TRD Sport Barcelona Red
    KMC Grenade wheels / BFG KO2 305/65/17 E rated, ECGS clamshell bushing, CMC, ARB Old Man Emu 2.5" lift- ARB 90000 OME Nitrocharger Sport Strut, ARB OME - 2886 Coil Springs (heavy), ARB OME Leaf Springs - EL111R (medium), SPC Specialty Products Upper Control Arms, Retrax One XR Tonneau Cover, Rhino Rack Vortex rails, Rago Fabrication Bed Stiffener, Tacomabeast- Spyder headlights /sequential LED DRL, Rigid driving/fog lightbar, RCI steel Skid Plate, Fab Fours Vengeance front bumper- High Pre Runner Guard, Fab Fours rear bumper, MillerCAT stainless Cat Shield, FEND-X wheel liners, Protec splash guards, Bushwhacker flares (Rhinoliner painted). For now…. Wife cut me off!!!
    As I understand it- 3PMSF is the testing criteria that is used to determine the tires ability to release packed snow and ice from the tread blocks to maintain stability and traction in these conditions. It doesn't have anything to do with the softer compound of the tire that would make it wear faster in warmer weather (like a specialized snow and ice tire i.e. Blizzak). Average overall tread wear is still determined by the manufacturer.
    The Michelins might check most of the boxes for you.
  6. Dec 20, 2022 at 11:34 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    After driving on KO2s for 50k, when I needed tires, I bought Kumho AT52s. Don’t notice too many folks mention these. Good so far in Winter. Time will tell how long they last. I drive mostly on pavement with occasional off road hunting excursions.
  7. Dec 21, 2022 at 1:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Defenders are a replacement for previous model (forgot name) and had on Suburban ran well. Wanted more bite with my Tacoma.
    Had 2 sets of the Michelin LTX A/T 2s and liked them but after 50k they still had tread left but got "slippery" on hard acceleration on wet surfaces so would change out. Handled many cross-country trips at higher speeds then beat them in AK for several months gravel and rough trails with no problems. Then went to the Wildpeak AT3 and similar to A/T 2 due to price (but recently much higher). Wildpeaks have more sidewall lugs/protection. After 35k like them too and did same types of trips with more offroad and sharp rocks and no damage and highway running 10-12 hours at 75-80 in summer heat. Not sure they will make it past 50k but that's all I run tire sets anyway as I use them hard. \Many opinions out there so read the reviews on the tire sites like Discount and Tire Rack and then determine by use and price (and yes looks as we all know).
    DeuceDeuceBravo, McGillz and Zerksees like this.
  8. Dec 21, 2022 at 6:12 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    yokohama geolanders at g015 :thumbsup:
    TRD-WY likes this.
  9. Dec 21, 2022 at 11:27 AM
    BRBNNEAT
    BRBNNEAT Well-Known Member
    Madison, WI
    2021 TRD Offroad-6 speed
    I ran the Defenders on my e53 X5- some trails (more than a dirt road, but not really off roading), mostly highway. I thought for an all season with good winter traction, it was a solid choice.
  10. Jan 3, 2023 at 6:43 AM
    Assumer
    Assumer [OP] Well-Known Member
    Maumelle Arkansas
    2020 TRD White
    GoRhino D1
    Thanks for all the reply’s. Just out of curiosity, how noisy are the. KO2 tires. That’s a nice looking tire. Probably don’t need it but while I’m looking you never know
  11. Jan 3, 2023 at 6:59 AM
    McGillz
    New Jersey
    As a KO2 owner I can say they make more noise than the OEM (Good Year Kevlars)- It doesn't bother me and I don't hear them at all when the radio is on. I kind of like to hear the tires- It lets me know they're still mounted on the rims :rofl:
    I'm going to make a point that I'm sure will stir the bees...
    Just keep in mind- Put the best tire on the vehicle for your needs. If you're going to be on pavement and doing a lot of highway driving - then the Michelin's are a great option. They wear well, they're not noisy, they get good gas mileage and they are stable when making an emergency maneuver. I wouldn't take them rock climbing! That's not what they were designed for. At the end of the day does your new tire of choice check most of the boxes? In the end- There is no "Perfect tire for everything". Get as close as possible!
    D.A.S. Taco, GSDLVR123 and ColoradoTJ like this.
  12. Jan 3, 2023 at 7:29 AM
    CementTRDx
    CementTRDx Well-Known Member
    Tomas
    Boston, MA
    2018 Tacoma TRD Off-Road DCSB 6MT - Cement
    I had the falken wildpeak at3w in 265/70/17 for my first 50k miles. Loved them so much and when I got my lift and got a set of scs ray10s, I wrapped them in another set of falken wildpeak at3w 285/70/17 E load. Its honestly such a great tire for the price point and it never failed me in any driving conditions.
    cammerv8 and drizzoh like this.
  13. Jan 11, 2023 at 7:45 AM
    Assumer
    Maumelle Arkansas
    2020 TRD White
    GoRhino D1
    Well, I went with the Pirille Scorpion AT Plus. Wal-Mart had a sale and they were $156 a tire. Road noise is less than or equal to the stock tires. Thanks again for all the replies.
    JasonLee likes this.
  14. Jan 11, 2023 at 7:55 AM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Update us at 20K and let us know how the noise is going.
    RIX TUX likes this.
  15. Jan 11, 2023 at 8:04 AM
    #35
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I have about 40k on my Toyo Open Country AT3, 255/70r17. Once those wear out I will definitely buy them again but will size up to the 265/70r17
    They are very quiet on the highway for an AT tire and have excellent winter traction, plus they look good.
  16. Jan 11, 2023 at 8:08 AM
    #36
    GrandMasterChooch
    GrandMasterChooch Well-Known Member
    east coast
    snow tires
    No its not. I would venture to say that my KO2s kinda suck in the snow. Sure they bite in and get you moving in some snowy conditions, but the handling seems very sloppy compared to my dedicated blizzaks. Too much sliding around and squirellyness. The blizzaks perform like a scalpel cutting through snow, inspiring much confidence. I run them from December to April.
  17. Jan 11, 2023 at 8:20 AM
    #37
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    KO2’s look great but any no where near a 3 peak winter tire. They suck in snow they suck in rain and they dry rot fast. I would chose the general grabber a/t x over them any day. My next tires will be grabber a/t x, Toyo a/t 3, or fallen wild peaks a/t3w
  18. Jan 11, 2023 at 8:33 AM
    #38
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    I have the toyo open country at3, quiet tire but ever since putting them on I get steering wander.
  19. Jan 11, 2023 at 8:34 AM
    #39
    islesrule123
    New York
    Do yours wander in the lane while driving?
  20. Jan 11, 2023 at 8:47 AM
    #40
    ssd2k2
    Keith
    Minnesota
    No issues with wandering with my Toyos. What size are you running and on what size rims?
