All terrain tires are "cupping"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The 2TR FE, Sep 7, 2014.
  1. Sep 7, 2014 at 2:25 PM
    The 2TR FE
    The 2TR FE [OP] 4 Bangin'
    Ian
    NH
    14 Toyota Tacoma Regular Cab 4x4
    LC Engineering Pro Flow Cat back exhaust w/ Magnaflow muffler and resonator delete, BF GOODRICH A/T KO2 (32s) bunch of led lights (two sets of duallys and a generic 28" light bar) smittybilt light bar mount HPS Short Ram intake with K&N cone filter Undercover tonneau cover (repaired)
    Hey, I wanted to discuss something that was bothering me a little. Just today I noticed my hankook dynapro ATMs were choppy but it only seems to be on the right rear. I got the tires used and I didn't really check to see if they were like that before. I think it's just because I didn't balance it correctly, could this be the problem or what else could be the problem. Thanks!
  2. Sep 7, 2014 at 2:26 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Sep 7, 2014 at 2:28 PM
    The 2TR FE
    Ian
    NH
    They are all at 34 psi should I knock that down a bit? And I must say holy s**t that was a quick response haha I also should add it's more on the outer edge and when you run your hand across it you can feel it is bumpy
  4. Sep 7, 2014 at 2:37 PM
    T4RFTMFW
    Edited post with info.
  5. Sep 7, 2014 at 2:42 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Chalk test your tires first, then check the suspension:
    Unless you have stock tires you cannot rely on the sticker in the door. To find out the correct inflation for your truck you must 'chalk test' the tires.
    1. Inflate all tires to 35psi. (Start high. You can always let some air out if needed)
    2. Go to a large parking lot where you have at least 300 feet of open pavement.
    3. Using ordinary, children's sidewalk chalk, draw a 1" wide line across your tread on one of your front and rear tires.
    4. Drive in a straight line for 300 feet.
    How's it wearing? Is it worn off in the middle but not on the sides?
    If so, you are overinflated. Lower the pressure to 32psi and try it again. Keep repeating the process until it's worn evenly across the entire tread.
    Is it worn on the sides but not in the middle? You're underinflated. Add a couple of pounds and try it again. You get the idea...
    Our trucks are not very heavy, and they are lighter in the rear than in the front, so your front tires will probably take more than the rears. My truck has Goodyear Duratrac's on it and I found that 30psi in the front and 26psi in the rear is just right. I would be surprised if you need more than 30psi in any of your tires....
    ready6delta likes this.
  6. Sep 7, 2014 at 2:44 PM
    The 2TR FE
    Ian
    NH
    I saw that, thanks I am going to are them down a bit, and maybe rebalance that tire.
  7. Sep 7, 2014 at 2:45 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Make sure you rotate religiously.
  8. Sep 7, 2014 at 2:45 PM
    T4RFTMFW
    None of that has to do with cupping....
  9. Sep 7, 2014 at 3:22 PM
    teneighty
    The title says cupping but the OP said chopping
  10. Sep 7, 2014 at 3:41 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    rotate your tires. simple as that. geting your alignment checked wouldnt hurt
  11. Sep 7, 2014 at 3:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Problem i see with the chalk test is its not at speed and can often yeild too low for hwy speed pressures.
  12. Sep 7, 2014 at 3:59 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    TIRE PRESSURE FIRST! alignment check is a good idea-I use the hand test first.
    Drive it a while -test it with your hand to see where the heat is the warmest-Good EASY First check.
    Cupping
    [SIZE=-1]Cups or scalloped dips appearing around the edge of the tread on one side or the other, almost always indicate worn (sometimes bent) suspension parts. Adjustment of wheel alignment alone will seldom cure the problem. Any worn component that connects the wheel to the car (ball joint, wheel bearing, shock absorber, springs, bushings, etc.) can cause this condition. Worn components should be replaced with new ones. The worn tire should be balanced and possibly moved to a different location on the car. Occasionally, wheels that are out of balance will wear like this, but wheel imbalance usually shows up as bald spots between the outside edges and center of the tread.[/SIZE]
  13. Sep 8, 2014 at 4:52 AM
    The 2TR FE
    Ian
    NH
    To be honest my truck is brand new (less than 5k on it) I am guessing it was from the previous owner. Sorry for the confusion on choppy and cupping but they are both the same for me :confused: I might just rebalance all four if I ever get a chance at work or just that one. Thanks for all the replies and I love how TWF members help out so quickly... Thanks
  14. Sep 8, 2014 at 5:57 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    I've seen it caused by cornering too fast if its in the outside of the tires. just a thought....
  15. Sep 8, 2014 at 5:59 AM
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    Then adjust for it. It's a whole lot better than guessing!...
  16. Sep 8, 2014 at 1:48 PM
    Justin Calhoun
    Justin Calhoun Well-Known Member
    Justin
    Fuckin' Texas!
    2005 PreRunner
    Headlights, Custom grille, Custom decals, 2 12" Kicker subs, Pioneer deck, Green underdash L.E.D's, Straight pipe exhaust, and C.A.I.
    Your right rear is the drive tire, so it gets the most abuse (usually). As far as the wear, that's fairly normal for Asian trucks as far as I've seen working at Discount Tire. Regular rotation is the best solution for the problem unless the Dynapro's are just prone to irregular wear.
  17. Sep 8, 2014 at 4:25 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You put used tires on a new truck?????????????????????????????
  18. Sep 8, 2014 at 4:48 PM
    teneighty
    I did too
    :anonymous:
  19. Sep 9, 2014 at 6:32 AM
    The 2TR FE
    Ian
    NH
    Yeah cause they were FREE 265 75 16 all terrain tires with 10 32nds still you can't go wrong
    Good for you, used tires are cheaper or in my case free so why not??
  20. Sep 9, 2014 at 6:57 AM
    wake100
    Syracuse, NY
    unless they dry rotted and/or over 6 years old
