All Terrian Tires Useful with Only 2WD ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Apr 9, 2024.
  1. Apr 25, 2024 at 12:04 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    They called it Auto LSD, and it's pretty clear that it uses the braking system, not really false advertising.
    Mechanical is not always better. It depends how much you like changing diff fluid with additives, and changing clutch packs, vs. easier maintenance, plus you get the benefit of traction control and stability control on the 09+ models.
    And just where you started this thread, tires are still the most important thing.
  2. Apr 25, 2024 at 12:58 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    I dont believe in traction or stability control. Go with mechanical any day. Would not have guessed they could come up with such a hermphadited LSD.
    Thanks for the warning i will steer clear of that.
  3. Apr 25, 2024 at 3:36 PM
    TCTND
    TCTND Member
    2014 regular cab
    My '99 Prerunner went down a lot of dirt with only 2wd. You do have to pay attention and avoid certain situations.
  4. Apr 26, 2024 at 10:36 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ I have a 2 wd and use it for hunting all over Nevada and never get stuck,running Falken Wildpeak AT 4 tires 255/80/17.
    TacoBell07[OP] likes this.
