All Things 2017 Tacoma TRD Pro: Known Issues, Tips, Tricks and Mods
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wade360, Dec 17, 2016.
  1. Jan 12, 2017 at 2:29 AM
    #121
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    just threw these on my Pro,,,,,
    IMG_4773_241201ab12e46995b7135584c633ebc6533ccfc8.jpg IMG_4777_6a876a997c2220f612e32b26038db23663e15c3a.jpg IMG_4776_7fd51b3a5e0725439766f7f3ecc837d72c0dce79.jpg
    SilverII likes this.
  2. Jan 18, 2017 at 2:28 PM
    #122
    Teknicl
    Teknicl Northern California
    2017 Tacoma TRD Pro
    Nothing yet - just got it two days ago!
    Roughly 1300 miles so far.
    • Dirt at 36 miles.
    • Mud at 400 miles.
    • Snow at about 600 miles.
    All GREAT so far.
    • Prinsu cab rack installed.
    • Working now on swapping out the Rigid lights for something brighter. More updates on that soon.
    No faults that I am aware of.
    I do get a clunk/knock in the back suspension when I "wiggle" the back end from side to side. Clunk could be coming from the leafs or maybe the shocks/mounts. Not sure if it is a problem, or just Pro reality. Anyone else?
  3. Jan 18, 2017 at 2:58 PM
    #123
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    Wonder if the mods care if I use that as SIG material?
    PROseur likes this.
  4. Jan 18, 2017 at 3:28 PM
    #124
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I know i've seen these before, but to save me time in the search, can you tell me where you got these?
  5. Jan 20, 2017 at 9:48 AM
    #125
    SnowFarmer
    SnowFarmer I intend to live forever, or die trying.
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    5900 Miles today. Still got some noise behind the dash I need to have looked at. Bit annoying.
  6. Jan 20, 2017 at 9:49 AM
    #126
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    7159 miles
    One headlight replaced due to leak
    No other issues
    shakerhood likes this.
  7. Jan 20, 2017 at 9:49 AM
    #127
    R.Shaw
    R.Shaw Well-Known Member
    2016 Tacoma 4X4 TRD
    Right pillar to dash is probably your issue, a ton of us have had this issue. I know a thread is around for it, may help you.
  8. Jan 21, 2017 at 9:14 PM
    #128
    SnowFarmer
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    Thank you!
  9. Jan 22, 2017 at 8:12 PM
    #129
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    So I went hunting to find a set of Toyota or TRD wheel lock lugs. The dealership tried to tell me that the part number, PTR27-34061 (TRD Wheel Lock Kit) was the right kit. After further inspection of the kit online, I realized these wheel locks are the conical/acorn style lug nuts. I didn't buy it. Went out to my truck and pulled off one of the lug nuts. Sure enough, the lugs and wheel holes are designed for the flange/flat/washer type lug nuts. The conical style lug nuts will actually damage the hole on your wheels. So, eventually figured out that the following part number is what you'll need. They don't have "TRD" etched into them but are Genuine Toyota: 00276-00900. Pictures below:
    PTR27-34061 (WRONG!)
    00276-00900 (RIGHT! Not TRD etched though. :()
    SilverII and shakerhood like this.
  10. Jan 23, 2017 at 9:44 AM
    #130
    poopshute
    Colorado
    LivinOnEdge[QUOTED] likes this.
  11. Jan 23, 2017 at 10:36 AM
    #131
    Sfearl1
    Sfearl1 Well-Known Member
    DTX
    Posted this pic in another thread but I'll post it here too. Confirming 285/70/17 fit on stock pro suspension w/o any modification. Experiencing slight rub at full lock in reverse but so far that's it. Haven't taken this setup off-road yet.
    hodo_taco and Diablo169 like this.
  12. Jan 23, 2017 at 10:41 AM
    #132
    poopshute
    Colorado
    This is great. Can you post up what the backspacing is of those rims? I want to install bigger tires on my Pro but want to keep the stock rims. I'm assuming you have less (more? can't remember which way it goes) backspacing with your rims allowing you to go with wider tires as opposed to stock. Could be wrong though. Would love to run something this big on my TRD Pro wheels.
    Sfearl1[QUOTED] likes this.
  13. Jan 23, 2017 at 10:46 AM
    #133
    Sfearl1
    DTX
    The wheel specs are 17x8.5", 0mm offset, 4.75" backspacing.
    poopshute likes this.
  14. Jan 23, 2017 at 11:27 AM
    #134
    poopshute
    Colorado
    Awesome, thanks! Anyone know the backspacing on the 2017 Tacoma TRD Pro wheels?
    Also, nice f'n GTR in the garage!
  15. Jan 23, 2017 at 11:31 AM
    #135
    su.b.rat
    su.b.rat broken truck
    13mm. someone correct me if i'm wrong. or is that -13mm. :confused:
    poopshute[QUOTED] likes this.
  16. Jan 23, 2017 at 1:44 PM
    #136
    poopshute
    Colorado
    That's only half an inch of backspacing. Don't think that sounds right.
  17. Jan 23, 2017 at 1:50 PM
    #137
    su.b.rat
  18. Jan 23, 2017 at 8:31 PM
    #138
    brandon0269
    brandon0269 Active Member
    Brandon
    2017 tacoma
    Thats awesome.........
  19. Jan 23, 2017 at 8:38 PM
    #139
    brandon0269
    Brandon
    2017 tacoma
    That's awesome bro............................
  20. Apr 5, 2017 at 2:10 AM
    #140
    RamP
    RamP Active Member
    Richard
    CT
    2017 Cement TRD PRO
    Looking good guys. Just traded in a 2013 Rubicon for a Pro. Much better ride quality compared to the live axles and 35's. Looking to get Relentless Fab sliders right off the bat. I'm sure I'll have lots of questions going forward too.
    Here's what I came from.
