All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jul 28, 2020 at 6:39 AM
    Astra
    Astra Well-Known Member
    Aaron
    St. Louis
    2007 Tacoma AC TRD Off-Road - Speedway Blue
    I do and have for about a year. The good thing is you typically get more value than the $55 price tag. You also get some unique clothing items (hats, t-shirts, sweatshirts, etc.) that you won't find anywhere else. The downside is that it starts to get repetitive. I have more front fenders, grips, and air pumps than I can use but I have backups in a pinch.
  2. Jul 28, 2020 at 6:41 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    That's what my concern is, I'm not a new rider so I'm pretty picky about the gear I use. I don't need a flavor of the month set of grips when I'm running RevGrips already. So I feel like I'd be paying $55 for a new Tshirt.
    113tac likes this.
  3. Jul 28, 2020 at 6:41 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Yea I went ahead and signed up. It’s $55 every month, cancel any time. If things get too repetitive, I pull the plug. That or I’ll just start white elephanting gifts to TW folks.
  4. Jul 28, 2020 at 6:43 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    don't you already pay roughly that for new clothing items though? but then you're getting some random accessories alongside it, occasional tool, food, mug, etc. that you can either keep and replace your items that are wearing out, or maybe gift/sell.
    that's my thought process...maybe I make sense haha....but I'm not subscribed...
  5. Jul 28, 2020 at 7:22 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Honestly, the Wasatch Crest trail is more fun. It's still a worthy ride, and the views are killer. Again, WC is better in every way... Recently did the Crest->Meadows->Mid Mountain->Insurgent->Ricochet ride, and wow was that fun!
    Having been a little bit into the 'racecar scene' I can sum up in a few words. Cars and bikes are extremely different in how they brake. In a car you controller is set to a fixed % of brake power front/rear. Most are 80/20. That means 80% of your braking force is applied to those front rotors. With MTB application, you control the f/r ratio yourself, and most people are in the realm of 40/60 f/r most of the time. The great thing about that is that you can control the ratio as conditions demand. While rotating mass is extremely important in both application, in a car with rear wheel drive, you are not driving the wheels with the largest amount of brake force. That means your front wheels will typically have larger (and heavier) rotors, which do not impact acceleration as drastically (though it does impact cornering). That allows for a few construction changes such as venting, size, metallurgy, pad size and construction, liquid capacity and line construction. That allows them to combat overheating (and thus fade) in a few ways, fighting fade with a combination of heat soak (how much heat the system can soak until it transfers it overloads) and heat escape (removing heat from the system).
    Car rotors are vented, meaning they are essentially hollow in the middle, which aids in heat transfer. They are also made up of heavier and specific metallurgy combination that allow for larger heat-soak capacity.
    Calipers grow not only to add modulation and power, but to add more pad surface area, additional liquid, and construction can help aid venting.
    System brake fluid capacity can be tweaked along with line construction.
    Pads can get larger, and thicker, with built in vents to aid in both heat soak and transfer.
    Air direction channels are created to direct air into the system at various points to aid in heat transfer.
    While vented rotors are still popular, their only real benefit is when the system gets overloaded to the point where gasses are created as the pads heat up to the point where they are being overheated. The gasses create a small layer or air between the pads and rotor, which good venting can allow to escape between the vents in the rotors. You can have drilled rotors where the gasses escape to the vented channel, or simple vents that do not. Both work, but drilling compromises the rotors strength and can cause cracking.
    Bikes are much lighter, therefore the heat generated is MUCH smaller. Smaller systems can handle that.
    Just like bikes, all things are compromises. You have to pay to play.
    Get the SD, having the option in the future and the extra stability is worth the small upgrade fee. Also, get the handle. Makes life 1000% better.
    Jesus, your tires last a year?! I'm replacing tires every couple of months max...
  6. Jul 28, 2020 at 7:36 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I'll take a white elephant gift from that subscription box! :D
    DUDE. The drop into canyons is epic from the crest. did you do Redcoat at all? that's such a sweet approach to Insurgent. Ricochet is such a fast flowy downhill. Canyons has so much more potential but nooooo vail doesn't want to do anything. Honestly prefer the canyons side more than the millcreek side but...don't tell everyone about it. hehe.
    Well, my sealant lasts a while. I'm on my 3rd tire this year because first tire ran low on tread. 2nd tire got a cut in the sidewall at Brian Head (side note, I plugged it with the stan's dart tool and surprisingly, it held for the next day). hopefully this 3rd tire lasts a little longer. Sick of buying tires this year. lolol.
  7. Jul 28, 2020 at 7:39 AM
    ginseng27
    '17 DCSB OR
    not enough.
    "Het"???
    also, i second the handle. Every 1up user friend of mine who doesn't have the handle has their mind blown once they see the handle
    abacall[QUOTED] and backcountryj like this.
  8. Jul 28, 2020 at 7:40 AM
    Bannerman
    Johnson
    Charlotte, NC
    I'm sure he meant get....
  9. Jul 28, 2020 at 7:41 AM
    ginseng27
    '17 DCSB OR
    not enough.
    I'm just starting my coffee. that's my excuse.
    Bannerman[QUOTED] likes this.
  10. Jul 28, 2020 at 7:43 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    disconnected likes this.
  11. Jul 28, 2020 at 7:45 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I just assume those subscription boxes contain trinkets that didn't sell in the first place so these companies buy them in bulk at a discount.
  12. Jul 28, 2020 at 7:48 AM
    Bannerman
    Johnson
    Charlotte, NC
  13. Jul 28, 2020 at 7:49 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    box examples...doesn't look like trinkets that didn't sell to me. I don't like hats like that, but the rest would be fine.
  14. Jul 28, 2020 at 7:54 AM
    Rucksack
    Rucksack Member
    Casey
    Inferno Tacoma
    hard use seat covers, Falken Wild peak AT-3 tires. Gator folding toneau cover. Bilstein B6 4600
    Just a ride from my doorstep. Spring.
    pridgway, mtskibum16, abacall and 3 others like this.
  15. Jul 28, 2020 at 8:05 AM
    backcountryj
    Jonathan
    GA
    You'll have wait your turn. @Bannerman already said he wanted all the grips and fenders. Something about being new to the game and not being sure what he needed. I don't know, just trying to help the guy out.
  16. Jul 28, 2020 at 8:07 AM
    Bannerman
    Johnson
    Charlotte, NC
    I saw a dude on Avery the other day running a front fender on his rear triangle. MotoAF.
    :bikewheelie2:
    backcountryj[QUOTED] likes this.
  17. Jul 28, 2020 at 8:31 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
  18. Jul 28, 2020 at 9:20 AM
    backcountryj
    Jonathan
    GA
    Ordered a single speed today.
  19. Jul 28, 2020 at 9:20 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    looks to be just your size.
  20. Jul 28, 2020 at 9:25 AM
    backcountryj
    Jonathan
    GA
    Well that stinks. It on its way to your house. I even special requested the extra heavy duty training wheels and seat post for your...heft.
