All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jul 29, 2020 at 7:02 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    2019 Santa Cruz Bronson CC. OE shock. Damage started as one scrape to piggyback, now it has multiple scrapes.
    RockyMounts hitch rack. Secures back wheel and front wheel. Nothing hits the shock.
    Transport it alone only.
  2. Jul 29, 2020 at 7:04 AM
    andnyleswillriot
    andnyleswillriot Well-Known Member
    Nyles
    Breckenridge, CO
    2004 Tacoma TRD 3.4L
    kmc wheels w/duratracs. Bilstein 5100's. Rear firestone airbags. Jayco slide in camper
    what about when two bikes are on the rack and a pedal from the other bike hitting it?
    ginseng27 likes this.
  3. Jul 29, 2020 at 8:01 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    oh dear god. that sucks. the only way that would happen is something hit it. either a pedal like @andnyleswillriot said or some rock kicked up and hit it or you fell and scraped it on something? that's a really odd location entirely though. Very hard to hit something there.
  4. Jul 29, 2020 at 8:18 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    squirrels.
    RockiesTaco and gsubioguy like this.
  5. Jul 29, 2020 at 9:12 AM
    jmauvais
    NorCal
    ...stuff
    it started off as a single white line, and that’s what I thought. I thought a rock or something hit it. But the area looks to be getting hit repeatedly at the same angle in the same spot, so I’m convinced it has to be the swing arm.
    ginseng27[QUOTED] likes this.
  6. Jul 29, 2020 at 9:13 AM
    jmauvais
    NorCal
    ...stuff
    Plausible. Must investigate further
  7. Jul 29, 2020 at 9:26 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Hows the swing arm look?
  8. Jul 29, 2020 at 9:31 AM
    ginseng27
    '17 DCSB OR
    not enough.
    True. constant rub on it makes it sound liek the suspension. is there anything sticking out where the reservoir woudl hit? I know you've said you've already checked it all. Is the frame flexing under you as it travels through the suspension?
  9. Jul 29, 2020 at 9:37 AM
    jmauvais
    NorCal
    ...stuff
    swing arm has no marks on it that I can see. I do feel a slight flex in the bike sometimes when taking a turn at speed. It feels similar to a tire with low air pressure, but tires are good (I was asking about that yesterday for the same reason). I will probably need to tear down the whole bike and check it all out. Linkages are all tight so I’m kind of concerned the carbon could be flawed/weak in some area. I also sent the picture to Santa Cruz to see if they had any idea
  10. Jul 29, 2020 at 9:44 AM
    ginseng27
    '17 DCSB OR
    not enough.
    yeah. no idea. would think that the linkage system is rubbing into it somehow. Keep us posted to what SC says! UBER curious now.
    gsubioguy likes this.
  11. Jul 29, 2020 at 9:52 AM
    jmauvais
    NorCal
    ...stuff
    the only thing close enough to the piggyback to touch it is the swing arm, so it has to be that. The reason it’s able to reach there... that’s the ultimate question
  12. Jul 29, 2020 at 12:22 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Let's talk saddles, my WTB is starting to split at the seams after almost two years of riding. I've never had any problems with it, comfort-wise, but I've also never really given it any thought. I've seen good things about the Ergon SM Pro. I guess maybe it's better for your dick so I was thinking about giving that a try. Thoughts?
  13. Jul 29, 2020 at 12:24 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    if you've never had an problems why not get another WTB? 2 years is a good life I'd say with your riding.
    or are you worried maybe you're missing out on even more comfort?
    Bannerman[QUOTED] likes this.
  14. Jul 29, 2020 at 12:31 PM
    Bannerman
    Johnson
    Charlotte, NC
    Well if there is truth that the Ergon is indeed better for my dick, then I want to get that one. #treatyoself
  15. Jul 29, 2020 at 12:33 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    If I remember correctly it’s that cutout that’s supposed to keep your junk from going numb. I have an SR comp On my old road bike which is similar to the SM. It’s solid but I prefer the WTB volt which doesn’t have as big of a cutout as other. Maybe the volt just has more padding idk
  16. Jul 29, 2020 at 12:40 PM
    MattJakobs
    Matthew
    NorCal
    If you're going numb down low, I'd recommend getting another saddle asap.
    Cut outs are more so keeping your junk getting air. If something doesn't get air, it tends to die. Same goes for your dick. If it doesn't have air and blood pumping in it, that's a bit of a worry. The WTB Volt doesn't have a cut out but it does have a pretty deep groove in their saddle to get some breathing done.
  17. Jul 29, 2020 at 12:46 PM
    113tac
    Stephen
    Northern Virginia
    Yeah I’m good to go with the volt now, I haven’t had any issues with it since I got it. The bontrager Arvada is solid too, that’s what I run on my stache. I tried the bontrager montrose pro which has a big cutout but basically no padding, no numbness but I found out why chamois butter exists. This is all super personal though and all trial and error in my opinion.
  18. Jul 29, 2020 at 1:15 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I actually just watched this today.
    https://www.worldwidecyclery.com/bl...+Saddles,+PNW+launches+4+new+Loam+grip+colors
    Gonna be sending my Ergon Enduro back for warranty replacement. Not sure if I’ll keep it or move to something else.
  19. Jul 29, 2020 at 1:16 PM
    Bannerman
    Johnson
    Charlotte, NC
  20. Jul 29, 2020 at 1:21 PM
    backcountryj
    Jonathan
    GA
    That was my takeaway too.
    ‘You don’t really need to worry about your saddle if you ride less than 10hrs a week.’ WTF haha I typically like their videos
