All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Aug 12, 2020 at 10:29 AM
    snozberries
    snozberries is forever trying to find a campsite
    Cory
    Martinez, CA
    2016 Quicksand
    Tires, Rack, LED bar, RTT, etc.
    HA! You aren't wrong. May just go with the mount on my rack for convenience/cost. The folding type racks I want are a little more expensive, and small chance we occasionally use other things on the hitch.
    levie125[QUOTED] likes this.
  2. Aug 12, 2020 at 11:18 AM
    rageman
    rageman Well-Known Member
    Keith
    2018 Barcelona Red Tacoma TRD Off-Road
    What type of tires are you guys running? I live in Houston, all singletrack and crushed gravel. I have Maxxis IKONs that came on the bike, and they worked OK, but i have lost traction when cornering hard. I haven't had it wash out completely yet, but I've lost some confidence in the corners.
    That being said, it's a 29er and I'd like to go tubeless. What are your recommendations?
  3. Aug 12, 2020 at 11:28 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Ikons are great if its dry and smooth single track. Any other conditions and I was all over the place. DHF/Aggressor has worked for me for years over all kinds of terrain, but recently switched to an AssGuy in the front, working pretty well so far but I've got less than 100 miles on it so far so can't make a recommendation. But all an all, the answer to what you should run is highly personal, terrain, riding style, type of bike etc.
    levie125 likes this.
  4. Aug 12, 2020 at 11:44 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    100% switch to tubeless and try lower tire pressures. What kind of pressure do you currently run and how wide are your tires?
    Lower tire pressure might make enough difference
    Gunshot-6A[OP] and Bannerman like this.
  5. Aug 12, 2020 at 11:58 AM
    mangosmoothie
    mangosmoothie Well-Known Member
    Casey
    Northern AZ
    '22 Pro
    I'm real excited my bike fits in the bed. REI CoOp brand.
    27.5 mid fat tubeless with 1x11 SLX. Tubeless is the way.
    I need to ditch the crank bros. Suggestions? Leaning towards spd. I need a quicker and more confident clip in
    paleh0rse, 113tac and levie125 like this.
  6. Aug 12, 2020 at 12:07 PM
    snozberries
    Cory
    Martinez, CA
    2016 Quicksand
    If I had the skill/tools to fab something up, I would definitely try to do something. Who wants to help me with a weekend project? :rofl:
  7. Aug 12, 2020 at 12:13 PM
    5 pigs
    5 pigs Well-Known Member
    john
    Don’t lay your bike down on the derailleur side.., and spd’s are pretty popular. I use one
  8. Aug 12, 2020 at 12:22 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    What do you use on the other one..?
  9. Aug 12, 2020 at 12:24 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Toe Clip over a Deity Bladerunner flat pedal. His foot ain't going nowhere! :rofl:
  10. Aug 12, 2020 at 12:39 PM
    Dirtjunkie
    Dirtjunkie Well-Known Member
    Northern Colorado.
    2006-Taco-Sport-TRD-Quad Cab-Short Bed, 4x4 No mods to speak of.
    I always recommend Time ATAC clipless. SPD are also a great choice. Those two are really the only two on the market with solid easy in easy out clip in actions. Crank Brothers don’t have enough surface space and are known to create pressure points on the foot. We talked about pedals about four pages back.
  11. Aug 12, 2020 at 12:40 PM
    5 pigs
    john
    I’m an amputee so I just clip in on the stump side and run a flat on the other
  12. Aug 12, 2020 at 12:43 PM
    MattJakobs
    Matthew
    NorCal
    Ah, gotcha. I accidentally clicked the right arrow above "quote" to quote you and it took me to your post of the Jet9 with mismatched pedals.
  13. Aug 12, 2020 at 12:48 PM
    rageman
    Keith
    Too much. I ride almost daily on both concrete and crushed gravel, so I leave them around 25-30. But that's been the case for a while and I've never had issues with traction.
    What do you recommend?
  14. Aug 12, 2020 at 1:02 PM
    Bannerman
    Johnson
    Charlotte, NC
    Haha, so that's why it's 5 pigs? The other 5 all went to market?
  15. Aug 12, 2020 at 1:11 PM
    113tac
    Stephen
    Northern Virginia
    That’s actually not that bad, could possibly go lower depending on the width of the tire. I’m about 225 and on my 27.5x2.35 ride 25-28psi. My stache with 29x3 I ride 12psi front and 15 rear, but that’s an extreme example.The front should be on the lower side.
    Tubeless won’t really help with traction as far as I know, only with getting to a lower tire pressure without flatting was much. I’d still recommend tubeless and try lower pressure.
    If not a knobbier front tire like the maxxis DHF will help a lot. The bontrager XR4 is solid too and I think that will be a little more aggressive than the ikon but not as aggressive as the DHF. I’ve also been curious about the maxxis dissector and the WTB options out there. It is kind of tough to recommend a tire since I’ve never ridden out there though.
  16. Aug 12, 2020 at 1:45 PM
    5 pigs
    john
    That they did, and never came home.. That’s what my daughter said to me when I was in the hospital. Lol
    actually got in a tango with a hydroplane propeller.
    honda50r and abacall like this.
  17. Aug 12, 2020 at 1:59 PM
    Bannerman
    Johnson
    Charlotte, NC
    Shit happens, hopefully you got a cool story out of it, and glad you are ok now!
  18. Aug 12, 2020 at 2:38 PM
    mangosmoothie
    Casey
    Northern AZ
    '22 Pro
    The derailleur can't hit the bed, I tested it.
  19. Aug 12, 2020 at 2:45 PM
    5 pigs
    john
    I’m all right now . That was nearly six years ago. I started riding mtn bike about two years later. This is a much healthier sport / addiction.
    abacall likes this.
  20. Aug 12, 2020 at 5:07 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Evening run - still sucks ass.
