All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Feb 3, 2021 at 10:00 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    So you're running DD on your trail or enduro rig?
  2. Feb 3, 2021 at 10:04 AM
    blaklabl
    blaklabl Well-Known Member
    Eric
    Cave Creek, AZ
    2021 Cement TRD Off Road
    levie125, Chris(NJ) and backcountryj like this.
  3. Feb 3, 2021 at 10:05 AM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    I ran DDs and prefer the insert. Its the better handling of the CC that really sold me. Protection is nice, not dinging wheels is nice, but the dual-stage damping was a game changer for me.
    Voltron4x4, levie125 and Chris(NJ) like this.
  4. Feb 3, 2021 at 10:09 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Close, but no cigar! That was Six Mile ;) But yea, I hit Allaire a few times a year. It's about 45 minutes for me to get there so I usually opt for Six Mile, LewMo or Hartshorne, which are all about a 30 min drive for me.
    levie125 likes this.
  5. Feb 3, 2021 at 10:32 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I haven't run DD casings, but I have friends that have. To me the biggest thing is rim protection. With a DD casing, you can still damage your rim. Sure the sidewall support will be better, and less likely to puncture & all that, but your rim is still vulnerable.
    & like what @mrtonyd said. You can still ride down a trail with just the insert and no air.
    I don't carry a spare tire anymore. Just a couple bacon strips & CO2 in case I need to plug it. Haven't had a flat once since having my cush core's (other than when I blew up the rim lol).
    What's the weight difference between a DD casing vs a cush core insert? Too lazy to look it up. I can't imagine it'd be that different. From what I remember, those DD tires are pretty burly and heavy.
  6. Feb 3, 2021 at 10:37 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Smashing the side of your rim against a rock is going to crush your rim, insert or not. So if neither protect from bad lines but both protect from flats then I will take the simpler of the two
  7. Feb 3, 2021 at 11:54 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    DD has two layers, all around the carcass of the tires. The stiffer casing does protect against rim strikes, since it's stiffer and deflects differently. It's not going to be as good as CC at protecting against a low-pressure smash into a pointy rock, but it does offer significant increase in protection compared to single ply.
    Enduro= Front and rear DD. Trail bike = Front EXO+, rear DD.
    I never felt much difference TBH. I even ran the Procores, which has a tunable double chamber design. That did make a difference, and was my preferred system. But the DD was a simpler way to avoid flats and change the feel of the tires to the point where I like it.
    It's good to have options. I'm glad I've tried them, and found what works for me. Riding style, weight, and location is a huge consideration as well. CC would be sweet in bike parks, where you're loading the hell out of the tire, and having that sidewall stability would be great. DD is a necessity in a lot of the fun CO trails, where shark teeth and pointy rocks slash sidewalls regardless (even DDs aren't always immune).
  8. Feb 3, 2021 at 12:24 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I had to look up more info on my casings because I get lost in the numbers. My tires apparently fall between EXO+ and DD, but I'm not in a hurry to take out the cushcores yet.
    Taken from enduro-mtb
    Gravity Shield
    The name says it all: Gravity Shield tires are made for those who follow the call of gravity and like to go as fast as possible on the descents. Michelin combine a three-ply 60 TPI casing with another three-ply 33 TPI casing for added reinforcement. The thick threads of the lower TPI casing do push up the weight of the tire, but they offer enough support for you to run lower tire pressures without having to worry about them squirming when you corner. You’ll rarely have to deal with cut sidewalls on rocky trails either. Pinch flat protection with Gravity Shield tires is better than Kenda’s EMC casing, but not quite as good as MAXXIS’ DoubleDown or Schwalbe’s Super Gravity casing, though they are a bit lighter.
  9. Feb 3, 2021 at 12:34 PM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    Yeah, I should mention I don't run DD, but I do run EXO+ with silk shield in the sidewall.
  10. Feb 3, 2021 at 3:36 PM
    abacall
    Phil
    UT
    2020 VooDoo DCSB OR
    Great day on the trails. I used the Decoy to find the trails, the Wrecker to rip em.
  11. Feb 3, 2021 at 4:00 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    All right. Who's looking for a bike? I'm probably gonna be selling my Capra here pretty soon...Need to support my NBD addiction.
    Bentrodder, neatoneto and Chris(NJ) like this.
  12. Feb 3, 2021 at 4:43 PM
    cartter469
    cartter469 Professional Idiot
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    I might have the smallest amount of interest. Would obviously depend on sizing price etc. Post up some pics and specs because I'm sure there are more than just myself who have interest.
    ginseng27[QUOTED] likes this.
  13. Feb 3, 2021 at 7:00 PM
    ginseng27
    '17 DCSB OR
    not enough.
    I'll get around to it soon. for starters, it's a 2019 capra AL Base. size L. with quite a few upgrades. I'll post something up when I get the chance.
    cartter469[QUOTED] likes this.
  14. Feb 3, 2021 at 9:23 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Sooo I got a bike tune at REI... and when I pedal reverse from 11th it drops to either 9 or 10th gear for some reason... the tech said you shouldn’t be doing that... I want to say my derailer is bent.. I’m annoyed help!
  15. Feb 3, 2021 at 9:27 PM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    New bike day! Hopefully the trails are dry this weekend.
  16. Feb 3, 2021 at 9:40 PM
    ginseng27
    '17 DCSB OR
    not enough.
    backpedalling is always a funky proposition. Potentially bent hanger or der. OR your b-tension is not set correctly. I notice it on one of my bikes sometimes when i'm in first gear and I back pedal. it jumps into 2 or 3 reallll quick. forward pedal always fixes it though.
    Does pedalling normally make it all work and go back to 11th?
    Harry P. Ness, levie125 and 113tac like this.
  17. Feb 3, 2021 at 11:03 PM
    cartter469
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    https://mashable.com/article/polar-vortex-2021-cold-temperatures/
    Hope you guys like riding in the cold!
    The "polar vortex" that article talks about makes me personally excited because I am not ready for phoenix summer yet. Today my phone told me the feels like temperature during my ride was 93 degrees. If it was April I'd be fine with that, but in February? All I know is I will be putting in a lot of miles next week because mid day temps should be right around 55-60 for me.
    RockiesTaco, Voltron4x4 and levie125 like this.
  18. Feb 3, 2021 at 11:28 PM
    BalutTaco
    When I pedal forward it goes back to 11th.
  19. Feb 4, 2021 at 4:33 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    $2k Downhill Bike with carbon wheels. Lightly ridden. Can't beat that.
    Intense 951 Evo, 27.5, Medium
  20. Feb 4, 2021 at 5:15 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    "This is amazing bike that can handle anything you throw at it."
    "Climbs like an XC Bike, descends like a DH bike"
    "Professional mechanic maintained"
    "Perfect shape"
    "Never raced"
    Wash, Rinse, Repeat dumb classified ad phrases
