All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Feb 4, 2021 at 4:05 PM
    levie125
    levie125 Well-Known Member
    2019 DCLB TRD
    Did you pull the lever at all when you had the bleed port open?
  2. Feb 4, 2021 at 4:06 PM
    jjones.yota
    jjones.yota Well-Known Member
    Jack
    Nope. Had it strapped, did the caliper bleed, unstrapped but held with finger, pushed caliper syringe to push the lever out. Then didn’t touch the lever again until after the lever bleed was done and everything was back together. New pads on, wheel on, then did squeezes on the lever to set it and it takes half a pull basically to “grab”
  3. Feb 4, 2021 at 4:08 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    its been a bit, but im guessing you didnt adjust the reach on the levers and only did a bleed?
  4. Feb 4, 2021 at 4:08 PM
    jjones.yota
    Jack
    I adjusted them to 75-80mm as the video stated to do. Then did the bleed and new pads.
    blaklabl and levie125 like this.
  5. Feb 4, 2021 at 4:09 PM
    mrtonyd
    Tony
    Colorado
    blaklabl likes this.
  6. Feb 4, 2021 at 4:13 PM
    mrtonyd
    Tony
    Colorado
    i dont think you want the lever strapped/close to the bar when you bleed the brakes. you should bleed the caliper and lever at the same time right? is this a newer set with the bleeding edge port? SRAM has great videos on their own stuff, trying to promote STU
    https://www.youtube.com/watch?v=DRt-CP2l474&ab_channel=SRAMTECH
    levie125 likes this.
  7. Feb 4, 2021 at 4:16 PM
    jjones.yota
    Jack
    I don’t have the bleeding edge adapter, so I’m not really sure. I have sram guide r. I followed this videos procedure because it’s the only one I found that they weren’t using the bleeding edge adapter
    https://youtu.be/nqdp7a7FXe8
  8. Feb 4, 2021 at 4:17 PM
    levie125
    2019 DCLB TRD
    @jjones.yota This is the same video I watched to do mine....Its only 6 minutes long but I probably watched 45 minutes worth of it to do my brakes.
    jjones.yota likes this.
  9. Feb 4, 2021 at 4:20 PM
    jjones.yota
    Jack
    Yeah I rewound and redid the video a lot haha.
    levie125[QUOTED] likes this.
  10. Feb 4, 2021 at 4:22 PM
    jjones.yota
    Jack
    Like the brakes don’t feel bad, but they don’t feel any different than before the bleed necessarily. Maybe a bit improved but that’s it. I thought they’d be like super super tight after bleeding.
  11. Feb 4, 2021 at 4:24 PM
    levie125
    2019 DCLB TRD
    Sounds like to me you need to take a harder "crash" that messes up the GoPro a little more so they replace it. :D
    Bentrodder and jjones.yota like this.
  12. Feb 4, 2021 at 4:25 PM
    Geoff
    Geoff Well-Known Member
    Adirondack Mountains
    2023 TRD OR
    Read the 4th post in this thread:
    https://www.pinkbike.com/forum/listcomments/?threadid=190668
  13. Feb 4, 2021 at 4:29 PM
    jjones.yota
    Jack
    Hm. Yeah not having the bleeding edge adapter I can’t do that, but I did think it was weird to “pressurize the system” then clamp the caliper syringe, then just take the syringe off lol.
  14. Feb 4, 2021 at 4:32 PM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    EVERYONE is struggling with supply. The fact that they even had new bikes ready to ship was a miracle. Orbea is forecasting AUGUST!
    YT has crazy value when stacked against 90% of manuf. Of course their stuff flies off the shelves. For reference; the Decoy is an eBike with a custom 540 w/hr battery built by Tesla, E8000 motor, full XT build, Code RSC brakes, Fox 36/DHX2 factory elite, DTSwiss wheels. $5,500. Can’t even find that level build on non eBikes for the $.
    whitedlite likes this.
  15. Feb 4, 2021 at 4:38 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
  16. Feb 4, 2021 at 4:51 PM
    blaklabl
    blaklabl Well-Known Member
    Eric
    Cave Creek, AZ
    2021 Cement TRD Off Road
    Not sure how you have far back (in) you have your bite point set, I always dial mine out almost to max before a bleed and then dial it back in after.
  17. Feb 4, 2021 at 4:52 PM
    jjones.yota
    Jack
    I can’t adjust the bite point. Just the reach.
    as far as I know..
  18. Feb 4, 2021 at 4:53 PM
    blaklabl
    Eric
    Cave Creek, AZ
    Sorry, that’s what I meant. The reach.
  19. Feb 4, 2021 at 4:55 PM
    jjones.yota
    Jack
    I adjusted the reach to 75-80mm from the center line of the handlebar like the videos told me to.
  20. Feb 4, 2021 at 5:01 PM
    blaklabl
    Eric
    Cave Creek, AZ
    I’ve done the same and found I get the same result as you, which is why I dial it all the way out now before the bleed.
    jjones.yota[QUOTED] likes this.
