All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Feb 20, 2021 at 8:57 AM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    I really don't understand how you guys are not damaging bikes with tailgate pads. I've tried five different pads, and all of them cut into the finish on the bikes downtube, the fork leg, or cut into the finish on the tailgate. Some less/more than others, (the least destructive seems to be the EVOC) but if things get at all dusty, then the damage is magnified.
    I keep my bikes meticulously clean, so maybe I'm picky because i see the damage right away. But I basically only use the pad for short hops, and always put microfiber rags between the bike and the pad.
    Thegenerik1 and levie125 like this.
  2. Feb 20, 2021 at 9:30 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    I have some beefy frame protection on the downtube. Hasn't bugged my bike since.
    abacall and levie125 like this.
  3. Feb 20, 2021 at 10:13 AM
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Same, and they also sent him down with the straps on the tailgate pad so they don't move much.
    ginseng27[QUOTED] likes this.
  4. Feb 20, 2021 at 10:35 AM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    Assuming your transporting a modern mountain bike...you will almost definitely need an extension or swing out to keep the handlebars from hitting the rear of the camper. You're going to want a swing out for accessing the camper anyway.
    I have a vagabond drifter and a 1up with rakattach. That combo fits perfectly.
  5. Feb 20, 2021 at 11:34 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    As mentioned, DT protection. Lots of options, easy to apply, no issues from tailgate pad rub. I'm still not a fan of pads though, and prefer the 1Up to most anything I've used.
  6. Feb 20, 2021 at 12:10 PM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    So I'm building a thing to hold my wheels to the bed rails when the bike is mounted into my custom rack. This mitigates the wheels just bouncing in the bed.
    Here's a rapid prototype 3D print. Whaddya think?
    Bonus Prerunner aesthetic.
    113tac, abacall, john8899 and 12 others like this.
  7. Feb 20, 2021 at 3:10 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    That's awesome.
    Is it threaded so you can use the axle to secure it? because most wheel end caps are just snap in place so without an axle to secure it I wouldn't trust it driving down the road.
    And I would maybe make the middle wider to give more strength, it would suck to hit a bump, crack the plastic, and have your wheel bounce out of the bed.
    I think if you perfect the design you could easily sell them, I know I'd buy a couple of them.
    Gunshot-6A[OP] and Bentrodder like this.
  8. Feb 20, 2021 at 3:12 PM
    ssd2k2
    Keith
    Minnesota
    I went with a Yakima pad because they have nice neoprene pads for the downtube to rest on. But then again I have helicopter tape on all my bike downtubes to protect from rock chips, so I don't worry too much about the tailgate pad.
  9. Feb 20, 2021 at 3:17 PM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    That’s rad! I would definitely buy a pair. Only issue I see is if it is in fact using the axle, I would have to have a second spare because my axle is what I use to hold the bike to my rocky mounts.
  10. Feb 20, 2021 at 3:20 PM
    ssd2k2
    Keith
    Minnesota
    You could use a dummy axle like Park Tool uses for their wheel holder and have a cotter pin to secure it.
  11. Feb 20, 2021 at 3:22 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Def needs a prerunner bed cage and ratchet strap! :rofl:
    R4D4G4ST[QUOTED] likes this.
  12. Feb 20, 2021 at 3:43 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    A fun day riding around the hills in Pacifica.
  13. Feb 20, 2021 at 4:14 PM
    [TACOMA]
    [TACOMA] Well-Known Member
    SoCal
    '17 DCLB Sport in QS
    Very cool indeed. I was looking for somthing like this, but only found the delta wheel hitch which would have worked. Decided to keep it simple with 1 & 3/4" velcro strap, to secure the wheel to each bike. (I usually transport 3 bikes)
  14. Feb 20, 2021 at 4:42 PM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    So we made one out of aluminum. The plastic was just a proof of concept.
    We're building a special axle that would thread into the aluminum plate. I have a couple knobs on order that would attach to the other end of the axle. We're building a 15x100, 15x110 boost and 15x150 fat bike threaded rods since I have bikes with all three front hubs.
    My buddy building them said building extras isn't hard after the prototype.
    Here's more photos.
  15. Feb 20, 2021 at 4:45 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That looks awesome! :thumbsup:
    May be interested in one after I double check if it would work for my setup.
  16. Feb 20, 2021 at 4:47 PM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    When we can complete the axles, probably next week, I'll take more photos. And do some test drives on some bumpy roads. It should work for anything with a 15mm axle, in 27.5" and 29".
    Bentrodder likes this.
  17. Feb 20, 2021 at 4:59 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    https://www.1up-usa.com/product/rakattach/
    so you work with a CNC mill?
    Rhann86[QUOTED] likes this.
  18. Feb 20, 2021 at 4:59 PM
    bassmusic
    bassmusic Coastal Redwood Cultivator
    Spicoli aka ChrisTOEpher
    Chapel Hill NC
    19 Tacoma SR5
    Just got mine back from the powder coater, winter project color change from white to Miami Vice. I pedal, rarely.
  19. Feb 20, 2021 at 5:05 PM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    My buddy is a prototype machinist. He mostly works with motorcycle/dirt bike stuff but MTB isn't an apple falling too far from the tree.
  20. Feb 20, 2021 at 8:24 PM
    ginseng27
    '17 DCSB OR
    not enough.
    Whoa. Why was this NOT a thing before? excellent idea man. Anyone with the bed mounts would definitely gobble that up. Only trick is to make sure you get threading done correctly for each axle type. yah know? but great starting point dude.
