All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Apr 20, 2021 at 7:01 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Dude that's cool of you to do! Nice lil treasure hunt
    Bannerman[QUOTED] likes this.
  2. Apr 20, 2021 at 7:04 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Carrying a battery 1/2 a mile is not an easy task at all.
  3. Apr 20, 2021 at 7:32 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    Yeah I would have happily given them the coordinates and continued on my way. :rofl:
    E-Paz 732NJ and GarlicFarts like this.
  4. Apr 20, 2021 at 8:31 AM
    iriddler
    iriddler Well-Known Member
    Elko Nevada
    2018 TRD Sport Magnetic Gray
    That surprised me as well, I really like my enjoy Stumpy I have the ST Alloy 29 https://www.specialized.com/US/en/s...585?color=274056-170585&searchText=93220-7402
    Pretty decent specs on a $2k full sus bike
    Coolerman[QUOTED] likes this.
  5. Apr 20, 2021 at 8:53 AM
    jjones.yota
    jjones.yota Well-Known Member
    Jack
    I got the SRAM bleeding edge tool, which I didn't have the first time I bled my brakes. I figured let's give it a shot with this and see if it turns out better.
    Nope. Following SRAMs own video, the SRAM Guide Rs just have a terrible bite point. It's about a 25mm pull before the brake bites at all.
  6. Apr 20, 2021 at 9:01 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
  7. Apr 20, 2021 at 9:02 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Do like Alex recommended and use a smaller bleeding block in between the pistons when bleeding. Allows more fluid.
    Also, try pressurizing the master cylinder more I suppose.
  8. Apr 20, 2021 at 9:03 AM
    jjones.yota
    Jack
    yeah I just have to do the cheater method, which is fine I supposed, but still dumb to me.
  9. Apr 20, 2021 at 9:08 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    That’s garmin to go-pro, not sure how many lights come with garmin mounts.
    this is niterider to GoPro, I don’t have it, I’ve just considered getting it but don’t ride at night enough haha
    https://k-edge.com/shop/light-and-action-camera-mounts/light-camera-accessories/niterider-adapter/
    mrtonyd[QUOTED] likes this.
  10. Apr 20, 2021 at 9:11 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    here's what I end up doing...it's a little tricky and gotta be careful...once you do the initial bleed, put your wheel back on and pull hte lever until you get normal pressure...then put the bleeding edge back on and pressurize from there. Pressurize and close the port while still holding the syringe in so that it takes in the pressure. if you don't like it, open up the port and pull some out and close. try again. repeat until you gt the pressure you like. Be careful not to squirt DOT fluid all over your pads and rotors when you pull the bleeding edge tool off. :)
    jjones.yota[QUOTED] likes this.
  11. Apr 20, 2021 at 9:13 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    The brake rotor will be easily salvageable, not sure how you'd get the fluid out of the pads.
    Maybe let it soak in the water for a day and it would come out of the pores.
  12. Apr 20, 2021 at 9:16 AM
    ginseng27
    '17 DCSB OR
    not enough.
    hah. or just don't get dot fluid all over it. I usually put a towel or something over the caliper.
  13. Apr 20, 2021 at 9:39 AM
    mrtonyd
    Tony
    Colorado
    omfg i did not know that existed. i have like 3 nite riders and those cheap straps that go through the helmet and wobbles all the time. def picking one of these up. summer riding is a blast at night
  14. Apr 20, 2021 at 9:46 AM
    mtskibum16
    PNW
    @jjones.yota I’ve had pretty good luck with a thinner bleed block and nothing else special in the process. It’s a balance. Old SRAM brakes sucked because there wasn’t enough clearance and the rotors always rubbed and I would have loved more clearance back then. Now we have clearance and a long throw. I guess they just need a lever/master cylinder that pushes more fluid with less lever throw. Used to cheat my old Shimano brakes in closer for shorter pull too.
    But trust me they aren’t nearly as bad as many many of the brakes in the past and we still have it pretty good. But they are a budget “good brake” so one of those things you get what you pay for.
  15. Apr 20, 2021 at 9:59 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    For real dude. Remember the when they were called Avids? Special place in my taint for those Juicy brakes
    113tac and mtskibum16[QUOTED] like this.
  16. Apr 20, 2021 at 10:01 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I still have nightmares about they horrid turkey gobble those things produced.
    mtskibum16 likes this.
  17. Apr 20, 2021 at 10:19 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I had a set of Avid Elixir's on the Motobecane hard tail. They were okay, but bleeding them was a production. Then next to it bleeding shimano's takes like 2 seconds and no special tools.
    113tac likes this.
  18. Apr 20, 2021 at 10:20 AM
    mtskibum16
    PNW
    I was going to specify Avid but figured these new riders wouldn't even know what that was. Those Juicy brakes were the WORST! ha
    Rezkid and 113tac like this.
  19. Apr 20, 2021 at 10:25 AM
    huckfin
    huckfin Well-Known Member
    mtn bike insurance? never heard of it, my homeowners/renters insurance covered my bike when it was stolen.
    E-Paz 732NJ and abacall like this.
  20. Apr 20, 2021 at 10:36 AM
    113tac
    Stephen
    Northern Virginia
    It is definitely on my list if I pick up night riding haha
    Juicy’s sucked, elixirs were better but once I tried shimanos (new at the time) first icetech stuff I have not gone back
