All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 6, 2021 at 9:03 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I hear what you're saying, but I left my tailgate pad on for two continuous years, SLC winters and all, before I bought a oneup, with only the occasional wash, and saw no issues with paint degradation, etc.
    The concern about downtube damage, esp on 3rd gens with the fatter tailgate lip is a concern, but seem to be a non-issue on a 2nd gen.
  2. May 6, 2021 at 9:07 AM
    Gunshot-6A
    Conner
    Everett, WA
    If @honda50r can't see the maxtrax, they can't hurt him :D Mine get well used for a different hobby of mine though.
    Harry P. Ness, E-Paz 732NJ and 113tac like this.
  3. May 6, 2021 at 9:10 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    Yeah I use soft pvc foam between frame and pad. Frame is also wrapped too so... I treat it like trash. :)
  4. May 6, 2021 at 9:13 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    yea, my "best way" involves not having to remove a wheel which, especially with a thru-axle, can be inconvenient, and then attaching it to the rack, and then reversing it all at the trailhead, and then again after the ride.
    Its so nice to be able to just pick up the bike, set it on the tailgate, and know its pretty much not going anywhere, even without tying it down, and like most people have said, the "damage/wear" is a non-issue.
  5. May 6, 2021 at 9:16 AM
    Gunshot-6A
    Conner
    Everett, WA
    Which on the factory fox 36 is a PITA because of the Kabolt-x pinch bolt.
    piff, neatoneto and DarthPow[QUOTED] like this.
  6. May 6, 2021 at 9:19 AM
    DarthPow
    I'll admit I don't know what that means exactly. lol
    but for me, the biggest issue is getting the axle lined up again and threading it back into the fork. Having to hold the bike up and in place until I the axle threads catch is annoying as hell to me.
  7. May 6, 2021 at 9:20 AM
    Gunshot-6A
    Conner
    Everett, WA
    The Factory 36 uses a non-qr thru-axle and then adds a pinch collar you use to cinch it all up. Which means you have to loosen a bolt just so you can loosen the axle bolt. And no, of course they aren't the same size hex.
    DarthPow[QUOTED] likes this.
  8. May 6, 2021 at 9:24 AM
    DarthPow
    oh jeez. I would definitely NOT be using any system that involves taking the wheel off. what a PITA, indeed.
  9. May 6, 2021 at 9:27 AM
    Gunshot-6A
    Conner
    Everett, WA
    Yeah, oneup or tailgate pad status confirmed
  10. May 6, 2021 at 9:58 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    Same size bolt for the thru-axle and pinchbolt on the 2021 36 forks. 6mm I believe. Still, I’d rather have a QR.
  11. May 6, 2021 at 9:59 AM
    Gunshot-6A
    Conner
    Everett, WA
    Its been a while since I took it off, so I was second guessing after I said that. Either way, I dont enjoy taking it off, even for a flat, etc.
  12. May 6, 2021 at 10:03 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    Same boat for me. For my normal everyday after work or weekend rides literally nothing is better than a tailgate pad. Having to remove a wheel and mount on a rack is nothing like a perfect rack for my needs. The tailgate pad bike carry has been my absolute favorite thing about having a truck. I'm fine using racks and whatever for longer trips, camping, etc, but you can't convince me there is a better after work ride carry method than a tailgate pad.
  13. May 6, 2021 at 10:12 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    One up most of the time, I sometimes throw the pad on if I use the rack on another car. Both are easy enough, even with the RTT and mid height rack.
    Have no idea where that could be! Hit me up with a DM, please?
    E-Paz 732NJ, iriddler and neatoneto like this.
  14. May 6, 2021 at 10:31 AM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    Like the SX Trail? Those were pretty cool.
  15. May 6, 2021 at 10:39 AM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    Tailgate pads absolutely serve a purpose. I've had a bunch of them, and I think I like the EVOC the most. So I do use them a fair bit. Nothing beats how easy they are or the ability to easily carry multiple bikes. But I'm too persnickity about everything to enjoy using them day to day. I keep everything super clean and removing the tailgate pad every time I wanted to wash the truck, I think, is more of PITA than removing the front wheel. (but I don't have Factory 36 fork either).
    I've also noticed that bikes were significantly more stable on the Gen IIs with the flat tailgate. The lipped tailgate on the Gen III causes the bikes tip and roll on the tailgate way worse, which magnifies and focuses rubbage onto a smaller point on the fork tube. And I can't fit in the garage with my bikes on the pad, so after a long ride I had to unload before I could park and go take a shower and enjoy a cold beer. Both bikes are sitting in the rack, in the garage at this very moment, actually.
    So....
    I ordered the "mini stiffys" from a guy on here, then it's just a scrap of aluminum tube and some scraps of aluminum angle, and few slots/holes, some Rivnuts and a set of Rocky Mounts (which I already had). Then I worked with @TMCmakes to build the things that hold the wheels against the bed rails, because wheels bouncing around was not ideal. I think he's planning on making a batch to sell.
    My goal was I wanted to get the bikes in/out without having to climb in the bed, park in the garage with the bikes stowed, the bikes/wheels had to be stable and not bounce around even on long-fast washboardy roads (like shuttling Mag 7 in Moab), it needed to be able to accommodate a Fat bikes 150mm axle, as well as Boost 115mm and my wifes 100mm. And I wanted it to be easy to remove for when the truck does more traditional stuff. So the whole thing comes out with two allen-head bolts.
    Pic overload;
    TwZeWY8OLF0IBqr9qM6Q6NBFPVP98gMKTI8URDwe_7d750c24b9327470cd3b4908c60cc5535248484c.jpg
    u70kh4SUj2Q1aoeFzE4kIi0HKrptkBlUtDgFUbkb_cbdf0557cb79c6b2aaba14e4f2c1de59ec941651.jpg
    HC_5IFT-5yguSKKXPdev3seI1bOUbYobF5AAZJyl_651f6abb8065c10f766a31d9b56e0f5ce6ee327f.jpg
    v3vZ8SWlu-nccPZr8idiQlIqvci-hLqAOmxhj37W_d8033d18527d917b433e68f01e83b98010acd73f.jpg
    FZY-hm5Mz8gHB4Ny9Dv75I1H7AZe_eH0VmGrFw2a_5a1f402b57b98fc739555277ae151688975254ea.jpg
    BribnZiUTGv2wECjcK6EgtVHTzjc2Qrl83A5HsSf_df980983152bd667bf250527531524459594fadd.jpg
  16. May 6, 2021 at 10:41 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I think it was just an SX, I wanna say it had like 100mm of travel. Just a straight up slopestyle bike haha. I want to say it was supposedly one of Darren Berrecloth's old bikes that made its way around pinkbike.
    Dr. Doom Says[QUOTED] likes this.
  17. May 6, 2021 at 10:50 AM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    Yea slope bikes are cool. Was riding with a guy with one of the new Polygon ones yesterday. I have a CC helm on the way for my P3 but its going to be kind of a goofy setup, might just bite the bullet and build a slope bike instead.
  18. May 6, 2021 at 11:32 AM
    [TACOMA]
    [TACOMA] Well-Known Member
    SoCal
    '17 DCLB Sport in QS
    So much ^This. As inconvenient as removing/installing the front wheels can be, being able to just drive in and park inside the garage is worth it. It wasn't until a older lady, at a local bike path, pulled up and loaded her bike onto her Fiat 500 roof rack in less time than it took me to unload and install the wheel on just two of mine. :pout:
    I'd like to run a hitch mount rack, but maaaan that'll be a long ride. DCLB + 4bikes.
    R4D4G4ST[QUOTED] likes this.
  19. May 6, 2021 at 12:08 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    how do i start a dm?
    abacall[QUOTED] likes this.
  20. May 6, 2021 at 12:21 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Yeah, I have quick releases. Right now my plan is just to use the QR - and I will probably get a hub mount and bolt it to my garage wall as well, I can't ride at my house/I don't live 2 seconds from trails, so no matter where I ride it's going to be taking the wheel off - so I'll just leave the wheel off, and have a mount on my wall in the garage.
    Man, that thing is sweet! I have to look at my mounting options. Now that I think about it, I'll pull some measurements but I might be able to use extruded aluminum to hold a mount somehow instead. And I did see those wheel holders, I think I'm on the list for one.
    Curve ball for it is I want to have a way to put my BMX back there too, because I'm 28 and want to go hang out with the middle schoolers
