All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jun 30, 2021 at 8:02 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I did with a similar Yakima setup and two pieces of angle iron I welded together. This was first and only time I’ve ever attempted to weld, so basically ended up with bunch of buggers. It worked for the light-ish weight loads I put on it before getting my topper.
    1AA1DDA6-40F1-4509-8284-E55BECC8874A.jpg 98F80332-B313-4DCD-A184-3C12AD12DE88.jpg
    jeffcos[QUOTED] likes this.
  2. Jun 30, 2021 at 8:22 AM
    jeffcos
    jeffcos Well-Known Member
    Jeff
    2013 MGM TRD Sport DCSB
    Nice work! I only use my bars for bikes so that would have worked for me too.
  3. Jun 30, 2021 at 9:34 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    I would think XC+ and "downcountry" are about the same thing, and I don't think the SB130 is either one. I have heard they are very efficient but it's a bigger slacker burlier bike than the others. If you want XC+ feeling trail bike I'd be thinking Trail 429, Ripley, Spur, SB115. I think those are in order of most to least capable. I'm not sure the others will have the same efficient pedaling as these if that's your priority.
    backcountryj and ridge[QUOTED] like this.
  4. Jun 30, 2021 at 10:28 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    SB100/SB115 frames are some of the most aesthetically pleasing frames imo.
    backcountryj and ridge like this.
  5. Jun 30, 2021 at 10:35 AM
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    They really are... and my demos on them just solidified that I am fully smitten with them. To @abacall 's point; I've reached out to a couple of local-ish Ibis dealers to see if they have anything at all I could demo. The Pivot Mach was nice... but didn't blow my skirt up like the Yeti SB. My emails back and forth with a local-ish Revel dealer puts me into August for a Ranger frame.
    abacall likes this.
  6. Jun 30, 2021 at 10:41 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    OK shit got serious.
    Ordered summer gloves and padded under shorts with extra ballroom.
    jmauvais, levie125, 113tac and 2 others like this.
  7. Jun 30, 2021 at 11:02 AM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    I've got a Revel Rascal reserved for my AZ trip, looking forward to seeing what the gossip is about.
    I'm sure you are paying attention to suspension setup on the rentals/demos; but it makes a big difference in ride. I rented a Mojo HD on a trip to Colorado and it wasnt until day 3 of thinking the bike sucked that I checked over the compression/rebound settings and they were all out of wack. Fixing the suspension settings brought the bike back to what I was expecting.
  8. Jun 30, 2021 at 12:06 PM
    mtskibum16
    PNW
    Which Pivot did you actually ride? The Mach 4 is a legit XC race bike right? Doesn't really fit with the others you are looking at.
  9. Jun 30, 2021 at 12:21 PM
    ridge
    North Carolina
    MESO!
    It was the Mach 4 and I was comparing it back-to-back with the SB100 I'd recently demoed prior to the Mach, then filtering both of those with the SB130 demo right after the SB100. The SB115 would probably be a near-perfect marriage but, as expected; I can't find one to ride.
  10. Jun 30, 2021 at 12:22 PM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Dudeeee that looks epic.
    I'll be up in Nampa, ID again July 16-18... Gunna try to throw my bike in so I can go out for a rip... I'll let you know when I sort out my life.
    flipnidaho[QUOTED] likes this.
  11. Jun 30, 2021 at 12:25 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    backcountryj, Pablo8 and ridge like this.
  12. Jun 30, 2021 at 12:38 PM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Any of you guys have DJs?
    Been trying to get out early once a week to the dirt jumps and pump track...what a workout... a few laps around and I'm clapped haha.
  13. Jun 30, 2021 at 12:42 PM
    mtskibum16
    PNW
  14. Jun 30, 2021 at 12:51 PM
    113tac
    Stephen
    Northern Virginia
    I wouldn't be surprised if that was in their plan. I imagine they need decent production numbers to make their new factory worth it. If they aren't bring all production over here then they must be filling the gap some how, maybe with a 130-140ish trail bike
    mtskibum16[QUOTED] and Pablo8 like this.
  15. Jun 30, 2021 at 1:25 PM
    mtskibum16
    PNW
    That or a bigger enduro bike. Ripmo kind of rides that line between long leg trail bike and enduro bike. 120/140/160 plus or minus a few is kind of an obvious breakdown for a 3 bike lineup, but I really like the 130r range. I think companies with 27.5" bikes incorrectly assume that people will cross shop the two sizes and that their 27.5 bike travel between the two 29ers fills that hole. Ibis and Transition both seem to do this. There's a big gap between the Spur and Sentinel for instance. Or Ripley and Ripmo though they are a bit closer probably.
  16. Jun 30, 2021 at 1:47 PM
    lukeoct8
    lukeoct8 Well-Known Member
    2017 TRD Sport Black
    Finally...the Covid bike build is complete. Very happy with how it turned out during these rough supply chain and stock times. (Yes, the front and rear rims are different because my i9 front ended up getting backordered, so I needed to find a temporary one for a couple months).
  17. Jun 30, 2021 at 6:50 PM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    Yeah I've got a P3 I take out on occasion. It wears you out fast, same with mountain bikes and jump lines. Wish I was closer to a dedicated pumptrack/bike park.
    dwphoto[QUOTED] likes this.
  18. Jul 1, 2021 at 4:35 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Dirt jumpers are a great way to stay fit and build skills for the big bike especially that elusive reaction speed
  19. Jul 1, 2021 at 8:17 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yep, I just use a cable lock. I use a Master lock with the long u-shaped part to block the bolt that tightens the mount so they can't take the rack with the bike.
  20. Jul 1, 2021 at 8:59 AM
    FreightTrain
    FreightTrain Well-Known Member
    UTAH
    2024 RAV4 Woodland
    I was looking for a similar-style bike as you last fall. I rode the Pivot Mach 4SL, Pivot Trail 429, Yeti SB115 & the Specialized Epic Evo. Mach 4 SL was immediately out. Trail 429 was excellent. The SB115 was nice, but I couldn't seem to get comfortable on it. The Epic Evo was a riot. For me, it came down to the Epic Evo & the Trail 429 and I ended up getting an Epic Evo. The Epic was a little lighter (about 25 lbs!) and it had a nicer build than the 429 for the same money. Geometry was very similar between the two except for head angle (Epic was a little slacker at 66.5).
    I was really lucky to be able to find all of these bikes locally and take some test rides. If I went by numbers alone, I would've chosen the Trail 429. As soon as I was half a block away on the Epic Evo, I knew it was the one for me.
    Good luck in your search!!
    ridge[QUOTED] and Pablo8 like this.
