All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jul 13, 2021 at 6:50 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Orange endurance and have zero complaints. Truthfully that’s all I’ve ever used. But I’ve yet to see a reason to try anything else :notsure:
    abacall, Gunshot-6A[OP] and gdb85 like this.
  2. Jul 13, 2021 at 7:51 PM
    levie125
    levie125 Well-Known Member
    2019 DCLB TRD
    Been using this for a year now and no complaints: https://www.goatheadbikeco.com/
    mrtonyd likes this.
  3. Jul 14, 2021 at 5:19 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    I'm really bad about sealant. I top off Stans maybe twice a year. Its not uncommon for me to pull a tire and its bone dry.
    SenatorBlutarsky and honda50r like this.
  4. Jul 14, 2021 at 5:59 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    We are supposed to add sealant periodically?
    Uh, is there a good link for maintaining modern tubeless MTB tires............well and carbon rims..........to change a tire without messing up an $800 rim?? :help::bananadead::)
  5. Jul 14, 2021 at 6:02 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    technically yes, I think regular orange seal is like once a month or something like that.
    I have used Stans, Orange Seal and Panaracer Seal Smart. The panaracer seal smart has some huge chunks in it but it is nearly impossible to put it in through the stem (which is my preferred method). I am still using the regular Orange Seal right now.
    Pablo8[QUOTED] likes this.
  6. Jul 14, 2021 at 6:24 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Thanks!
    https://www.google.com/search?client=firefox-b-1-d&q=maintaining+tubeless+mountain+bike+tires
    https://www.youtube.com/results?search_query=maintaining+tubeless+mountain+bike+tires
    113tac[QUOTED] likes this.
  7. Jul 14, 2021 at 6:50 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I just use Stan's and give it a refresh a couple times a year. I'm not a weight weenie and it is cheap, so I use plenty. I've never had any luck going through the stem, so I always remove the tire and clean things up, remove the latex coral ball that sometimes forms. Stan's has always worked to seal small punctures (not so well on 2" sidewall gashes on a brand-new $70 tire), so no reason to try something different. And you know it is latex-based, so if Stan's is not available in a pinch you can just use another latex-based sealant.
    For protecting the rim, I use a plastic trash can to support the wheel and push down on opposite sides, rotate, do again, until the bead breaks. I have a Pedro's DH tire lever that I wrap some electrical tape around to pry up the bead, and then use plastic tire levers to work it loose from there. Once you get about a foot of the bead off (~30cm for our northern neighbors), the rest can usually be done by hand. Getting it back on is about the same in reverse. Then, you get to re-seat the bead! Different tire/rim combos can make this a challenge, especially if you don't have a charger pump or compressor. I have a compressor, and even that sometimes takes a lot of patience. I like the Bontrager system with the plastic liner, seems to make it much easier.
  8. Jul 14, 2021 at 6:53 AM
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    Just regular Orange Seal, refreshed about every 6 months and/or completely flushed and refilled once a year. I tried the Finish Line sealant as a test one year and it stayed liquid longer than OS, but I don't really get flats often enough to make it worth swapping over to. It was more "goopy" than OS, and with larger chunks, but I like using the syringe>valve method for filling and emptying the tires, and the Finish Line stuff was too viscous for that.
    Only downside to OS is when you forget to clean it out of a set of tires for a season or two and end up with this monstrosity... (still weighed less than a tube)
    In other, more exciting news... REEB REEDUUUUX!
  9. Jul 14, 2021 at 6:56 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    Yeah I’m usually about a once a year clean and reapply. Although I haven’t touched mine since spring 2020 at this point I can only assume they are more or less dry but holding air pretty well and I haven’t had any punctures so…. :thumbsup:
    levie125 and Pablo8 like this.
  10. Jul 14, 2021 at 7:07 AM
    113tac
    Stephen
    Northern Virginia
    so sick! Those reebs look good
    ridge[QUOTED] likes this.
  11. Jul 14, 2021 at 7:21 AM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    The lifty yesterday said the PCMR pass still gets you and your bike onto the Canyons gondola....
  12. Jul 14, 2021 at 7:26 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I just called my insurance agent and had a rider clause specifically for bikes. $1000 deductible
    Almost had to use it (recovered the bike stolen from my garage) and it was super easy. It was a pre-owned bike and the insurance company didn't ask any questions. Just took the deductible off the replacement cost check (More than I paid for the bike in first place)
  13. Jul 14, 2021 at 7:27 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    was cost around 1-1.5% insured price of bike?
  14. Jul 14, 2021 at 7:36 AM
    113tac
    Stephen
    Northern Virginia
    Gunshot-6A[OP] likes this.
  15. Jul 14, 2021 at 7:38 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    levie125 likes this.
  16. Jul 14, 2021 at 7:44 AM
    ridge
    North Carolina
    MESO!
  17. Jul 14, 2021 at 7:46 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
  18. Jul 14, 2021 at 7:47 AM
    113tac
    Stephen
    Northern Virginia
    haha I'm assuming its just a sponsorship type thing but I wouldn't be surprised
    Seriously though, I guess no one is immune to it...money talks! haha
  19. Jul 14, 2021 at 7:48 AM
    113tac
    Stephen
    Northern Virginia
    Mike Levy is going to offer tens of dollars for that to show off the next donut version
  20. Jul 14, 2021 at 7:49 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
