All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Feb 21, 2022 at 11:40 AM
    16SRMGM
    16SRMGM Well-Known Member
    2016 Tacoma SR
    Finally decent weather in West TN. Rain for next few days now.0AEA1BE6-5C71-414B-91DC-7DC87238938D.jpg
  2. Feb 21, 2022 at 1:32 PM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    I don’t ride my bike. I just detail it.
  3. Feb 21, 2022 at 1:52 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I have a Sram 8 Spd cassette that is worn. Can I replace it with an 8 Spd that has a little bit different gearing? My old one is an 11-32. Is going to an 11-34 or even 11-40 possible with the same chain and derailleur?
  4. Feb 21, 2022 at 2:29 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    might be off topic but are there any veteran organizations or groups that MTB? anyone know of any? I know the WWP does a annual one in FL.
  5. Feb 21, 2022 at 2:38 PM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    Those that ride the good stuff in Santa Cruz would know exactly where this is.
    MTB58, dman100, LeFreakyBone and 6 others like this.
  6. Feb 21, 2022 at 3:27 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    That is dependent on your derailleur's specs. 11-34 is likely possible, but it won't work with 11-40 since that is from a different era of parts.
    tacoma04[QUOTED] likes this.
  7. Feb 21, 2022 at 3:56 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    34. Probably fine.
    40. Probably not fine.
    You may need something like a Wolftooth RoadLink to make a 40t work.
  8. Feb 21, 2022 at 4:04 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    annadel?
  9. Feb 21, 2022 at 4:28 PM
    flipnidaho
    Yes sir! I normally try to no-dab, non-stop 2 Quarry but wasn’t even close today.
  10. Feb 21, 2022 at 4:34 PM
    man_on_an_island
    man_on_an_island Active Member
    Wisconsin
    2016 Tacoma sr5
    ill have to check Block 15 out. Moving out there towards the end of the year.
  11. Feb 21, 2022 at 4:46 PM
    BalutTaco
    Where are those trails? I usually park in the neighborhood hit up the canyon trail to the lake. sometimes hit up Marsh trail - South burma ( that trail got soo fked up) h
  12. Feb 21, 2022 at 6:21 PM
    tacoma04
    Bruce
    Tennessee
    @SoCOTaco & @DingleTower
    Thank you for your responses. So the issue with the 40 is the derailleur not being long enough, correct? Would the Wolftooth be a patch for not getting a new derailleur or is the Wolftooth an acceptable mod?
    Thanks again!
  13. Feb 21, 2022 at 6:34 PM
    flipnidaho
    To get to 2 Quarry, ride up towards the horse staging parking lot and climb up the fire road. You will see 2 Quarry bear off to your left after a bit of climbing. At the top of 2 Quarry, connect with Marsh and then left on Lawndale. There are a bunch of non-inventory singletrack off of Lawndale that are worth exploring for a bit of adventure. At the end of Lawndale (watch out for the drop into the parking lot), make a right to climb up the road, left on Schultz to pick up the trail again. Head towards Ridge and finish either on South Burma or Live Oak from the lake. Good for 20+ miles and about 2500+ feet of vert.
    BalutTaco[QUOTED] likes this.
  14. Feb 21, 2022 at 6:47 PM
    SoCOTaco
    Mitchell
    Lakewood, CO
    It's not about the cage length, it's about what the derailleur is designed to handle. They all have a max rear cog size and range they are designed to handle. 8 speed is older stuff, so there's only so much modernization that can be done. I'm using a Wolf Tooth Goat Link on the GF's gravel bike, but it's for a 10 speed gravel setup. I'm not sure how well it would work with older 8 speed stuff, as I don't think it was engineered with that intention.
    EDIT: After looking at the WT site, it is designed for 10/11spd Shimano and won't even mount to your SRAM setup.
  15. Feb 21, 2022 at 6:51 PM
    tacoma04
    Bruce
    Tennessee
    Thanks. It sounds like it is not worth the effort for this old bike.
    SoCOTaco[QUOTED] likes this.
  16. Feb 21, 2022 at 7:07 PM
    flipnidaho
    If you're in the Bay Area and need work done on your truck, look up Milo and Jeff at Milogen Fabrications in Milpitas. They were able to fit me in with short notice to install the ECGS bushing. AND, they also ride! Milo rides an Evil Insurgent and Jeff rides a Levo SL. Santa Cruz ride in the morning and ECGS bushing install in the afternoon. Today was a good day.
    MTB58, iriddler, neatoneto and 6 others like this.
  17. Feb 22, 2022 at 4:37 AM
    evenslower
    evenslower Well-Known Member
    As said above it’s not the cage length. The issue is the upper derailleur pulley needs to be able to clear the largest cog. Sometimes you can “fudge” it a bit and crank the adjustment way out to get enough clearance to go a little beyond what the manufacturer recommends but not too far beyond and performance suffers which gets irritating.
    Nothing wrong with a 34t big cog if you’ve got a double/triple ring up front, which with 8sp setup I’m guessing triple. If you’ve already gone to a single setup just go with a smaller front ring if you need to get lower gearing.
    Regarding the WT goat link, it doesn’t work with SRAM which I think you said you had as stated by @SoCOTaco.
    Slightly older bikes get tricky with compatibility as bike tech changed rapidly from about 2000 to 2015 or so.
    tacoma04[QUOTED] and SoCOTaco like this.
  18. Feb 22, 2022 at 4:52 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    Yep.... I missed the Sram part. You're likely SOL for a 40.
    Should have no issues with 34 though.
    tacoma04 likes this.
  19. Feb 22, 2022 at 6:56 AM
    tacoma04
    Bruce
    Tennessee
    @evenslower & @DingleTower
    Thanks for the info. I need replace the old Sram cassette. It is worn pretty good. The derailleur is a Shimano Deore. It is a triple up front, but I really only use about 6 different gear combinations. I never use the large gear up front and only have one use for the smallest gear up front. Thought I'd investigate simplifying things since it needs replacing. Maybe go with one ring up front and change the numbers in the back. But don't want a big PITA working on an old bike, lol.
  20. Feb 22, 2022 at 6:56 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Monster Cross in Virginia over the weekend (Pocahontas State Park). My heavy steel bikepacking rig probably wasn't the smartest choice, but it did the job.
    I didn't die, get frostbite, or come in dead last. I'll count that as a win.
    Rumpled, 113tac, RockiesTaco and 7 others like this.
