All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Feb 23, 2022 at 3:21 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    well, allah works in mysterious ways.
  2. Feb 23, 2022 at 3:21 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    so does stans wheels it seems
    abacall, Pugga and vorkuta775[QUOTED] like this.
  3. Feb 23, 2022 at 3:35 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Did you re-tape the rim? We all know sealant doesn't last forever, but often times rim tape can be the route of mysterious tubeless air loss as well. I could never imagine going back to tubes.
    flash5twelve likes this.
  4. Feb 23, 2022 at 3:40 PM
    mrtonyd
    Tony
    Colorado
    i know i retaped back in november. dont remember if i retaped it or not after that
    levie125 likes this.
  5. Feb 23, 2022 at 4:04 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    It’s just the track that goes at the front of the bed with a rocky mounts fork mount in it. I cut 1/2” off either side of the track and lay it on the bed floor whenever I load my bike.
  6. Feb 23, 2022 at 4:21 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    can your friend come ride my bike?
    mrtonyd[QUOTED] and levie125 like this.
  7. Feb 23, 2022 at 4:26 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    :barf:
    I think I've been "saved" enough in my lifetime. I'm good. I think.
    LOL. true gifts needed for the afterlife. Don't forget your bike. ;P
    abacall likes this.
  8. Feb 23, 2022 at 4:33 PM
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    I went once a few years ago for the Old Fools jam. It was super fun. Another fun indoor place a couple hours away is the Wheel Mill in PA. We did both places on the same trip.
    disconnected[QUOTED] likes this.
  9. Feb 23, 2022 at 5:06 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    If I didn’t recently buy XTR clipless a month ago as well as Nukeproof Horizons last May I’d try those ride5 pedals.
    unfortunately I didn’t order when I had chance to get them for $190.
    These things are skinny flat no pun intended, and super light from pics I’ve saw on Instagram. https://ride5dev.com/collections/pedals/products/6061-t6-flat-pedals
    vorkuta775[QUOTED] likes this.
  10. Feb 23, 2022 at 5:19 PM
    vorkuta775
    Texas
    tesla truck
    Those are nice too. Super skinny too. I have some composite Chester's they work for now. Those oil slicks are 180$ too. poof
  11. Feb 24, 2022 at 4:40 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    Oh ya, I know the Wheel Mill. It’s relatively close to home.
    MTB58, mrtonyd, paleh0rse and 4 others like this.
  12. Feb 24, 2022 at 5:07 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    I may go tomorrow. Friday is usually my snowboard day, but the weather has been crappy. Rays looks to be 2 hours away. I’d be coming from Pittsburgh.
  13. Feb 24, 2022 at 6:32 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    I know you've had the gaggle respond already, but I'm going to throw in my .02 as well.
    I had a very similar situation. Wheels are freaking weird sometimes. Personally, this process has worked, many times.
    -Tire off
    -Tape off
    -Clean the entire rim bed with alcohol so it's like new
    -Check carefully for any burrs, or material sticking out of the rim bed or wall, take your time and look for possible failures
    -Retape with high quality tape, edge to edge, two times around overlapping 1/4 of the wheel
    *Make sure the tape is very well pushed down, with as few air pockets as possible, take your time, stretch the tape as needed (I sometimes use a hair dryer to get the tape warm and pliable)
    -Throw the tire on carefully not to scratch the tape
    -Throw a tube in, and seat the tire
    -Pump the tube to 40 psi (check rim specs) and let it sit overnight
    *This usually lets the tape completely seat and gets rid of any possible air escape
    -Pull the bead on one side, pull the tube out
    -Pop in a NEW tubeless valve
    -Reseat tire, pour in 4 oz Orange Seal, install core, reinflate
    I know it sounds like a process, but it's the normal procedure plus a couple extra steps. It has worked every single time. I've found burrs on my AL rims, tape that was messy, had air pockets, or not wall-to-wall and leaked, valves that were not seating well, sealant boogers that were stuck, etc...
    IF this doesn't work, check spoke tension. I've heard of weak tension allowing rims to bend and allow tiny burps of air come out while riding. I've never had that happen, but I check tension monthly.
    backcountryj and paleh0rse like this.
  14. Feb 24, 2022 at 8:17 AM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    Sorta bike related (there is a rack in the video). Just installed the DIR harness. It turns off the license plate light when the truck is in reverse to reduce glare. It makes a difference when I have my rack folded as it reduces the glare returning from the rack. 5-10 minute install.
  15. Feb 24, 2022 at 8:43 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    $150 for pedals is a mockery, $250 for pedals is a crime. :der: I'm stickin with the Oneup composite for $69 until the new Shimano composite for $55 are avil. :crapstorm:
    DarthPow likes this.
  16. Feb 24, 2022 at 8:55 AM
    DarthPow
    glad someone else feels this way.
  17. Feb 24, 2022 at 8:55 AM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    +1 on what @abacall posted about installing a tube after re-taping a rim. I used to have a lot of bubbles and leaks, especially since I have narrow 19mm inside width rims which provide little surface area for the tape to seal. Since I started putting in a tube overnight (or longer, if I want to ride) I’ve had zero leaks after re-taping.
    abacall likes this.
  18. Feb 24, 2022 at 10:10 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    It is a shame, unfortunately it's just market competition. I wouldn't spend that much on a flat pedal I know i'm going to smash on rocks.
    JerryBear likes this.
  19. Feb 24, 2022 at 10:22 AM
    DarthPow
    since when does market competition drive prices UP? Unless they're just competing to see how much they can get people to spend, and be happy about it. I really don't see the "performance benefit" of $175-250 pedals over a pair at $75-100, maybe even $125.
    Gunshot-6A[OP] likes this.
  20. Feb 24, 2022 at 10:23 AM
    mrtonyd
    Tony
    Colorado
    none of my pedals have been over $30 and theyre all crap.
    maybe i need to buy some of these
