All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. May 9, 2022 at 7:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Fezzari
  2. May 9, 2022 at 7:44 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
  3. May 9, 2022 at 8:13 AM
    mtskibum16
    mtskibum16 Well-Known Member
    PNW
    2019 Tacoma DCSB TRDOR 4x4 Quicksand
    Man I have a set in the garage I haven't tried but maybe I need to.
    Is that the 100cc One Up pump? My old pump/mount doesn't fit on the Following and I've been meaning to get something new. Just been rolling the dice with no inflation for a couple months.
  4. May 9, 2022 at 8:33 AM
    evenslower
    evenslower Well-Known Member
    Not mounted to my frame but I’m digging the 100cc and EDC tool integration. Just stuff it in my pack but works well and the multi tool is actually useful. It’ll see frame mount duty on a bike packing trip later this year.
  5. May 9, 2022 at 8:37 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    Nice. I have one in my backpack with a co2 canister at all times. the head of the pump doubles as a co2 inflator so, everything you need is right there, short of bacon strips but I have. separate system for bacon strips and valves and stuff. Very compact, very nice. I don't have it connected to my bike though.
    SenatorBlutarsky likes this.
  6. May 9, 2022 at 8:47 AM
    str8edgMTBMXer
    str8edgMTBMXer Well-Known Member
    Central Ohio
    2021 SR5 DCLB; midnight black metallic
    i hear ya...every trail we have here in Central Ohio - which is not much - is under water!!!
    man...lots of fat luv in the recent pages!!
    I only have plus bike (OG Surly Krampus), but wider is definitely more fun...even out of the snow!!!
    Gunshot-6A[OP] likes this.
  7. May 9, 2022 at 8:48 AM
    mtskibum16
    PNW
    Carrying a pump and CO2/inflator always seemed unnecessary to me. What am I missing? Only real advantage I can see is seating a tire bead that won't seat with with a pump. But if you lose a tire on the trail you probably lost sealant and potentially even have tire damage and need a tube anyways. At least with this setup you already have the inflator so adding a CO2 canister isn't too heavy, I just never understood the need for both.
  8. May 9, 2022 at 8:53 AM
    ginseng27
    '17 DCSB OR
    not enough.
    it's just so much quicker and easier to fill the tube/tire. Ironically, I don't like pumping the pump just to fill up the tire so.....yeah.
  9. May 9, 2022 at 9:08 AM
    mtskibum16
    PNW
    So then why carry a pump at all? Since I needed a new inflation device I was recently thinking all this over. I was tempted to just buy an inflator and skip the pump completely?
  10. May 9, 2022 at 9:17 AM
    ginseng27
    '17 DCSB OR
    not enough.
    because the co2 only gets you so far in some tires. the pump helps top off the pressure.
    Gunshot-6A[OP], abacall and dwphoto like this.
  11. May 9, 2022 at 9:28 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I’m really liking the PNW grips. Can’t say I’ve tried a ton of brands as I’ve always just run Ergon. So far I’d say I like the PNW just as much if not more.
    Yes that’s the 100cc. I really the Oneup tool ecosystem. I’ve got the bottle mount pump holder dealing on both my bikes. For most my rides I just swap the pump and dakine hotlaps from bike to bike and ride without pack of kind.
    abacall likes this.
  12. May 9, 2022 at 9:49 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    C02 is faster. Pump is unlimited air assuming the pump doesn't explode...
    That said.
    CO2 is dead to me after 2 canisters and a plug didn't fill my tire and left me walking 5 miles back to the car and missing an epic downhill.
    Granted it was mostly operator error...I'll go for the slow sure method.
    Another L for CO2
    The waste. Unless you are making tweaker art of course...
    East Jesus( yea go ahead and google it ) back in 2015
  13. May 9, 2022 at 9:53 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Can anyone recommend an affordable ( under 1,000$) reliable e bike ? Looking to use one as a commuter to work. The ride is about 4 miles to get there, with some big hills.
  14. May 9, 2022 at 9:55 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    This may have been mentioned already and I missed it, but one of the best sources for inexpensive namebrand jerseys is actually Rocky Mountain ATV/MC:
    https://www.rockymountainatvmc.com/riding-gear/jerseys
  15. May 9, 2022 at 9:56 AM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    nice!... Bike and truck gotta match!
    That assegai out back all the traction! I might suggest picking up a DHR2 for the back and saving the Assegai for the front. Assegai was great outback on the downs, but def pretty sluggish as far as rolling resistance.
  16. May 9, 2022 at 10:01 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Can confirm you should really carry a pump. Had to air up twice when a tube I was given had a hole in it, so that canister was wasted. Had to find someone with a pump I could use. Also carry the bigger CO2 cartridges. The smaller ones don't have enoughu umph for larger MTB tires
  17. May 9, 2022 at 10:01 AM
    mtskibum16
    PNW
    By hotlaps do you mean the little gripper frame pack? Where do you install it on your Following? There is really limited real estate on the Evil bikes. I'd love to be able to ditch my hip pack for shorter rides. With the One Up pump/tool and a tube on the frame I could do it without being too worried.
    Those have kind of been my thoughts on the CO2 I just have no first hand experience to back it up.
    backcountryj[QUOTED] likes this.
  18. May 9, 2022 at 10:31 AM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    If everything goes great...Co2 is best...
    For some reason in my life most of the time things don't go great..
    levie125 and abacall like this.
  19. May 9, 2022 at 10:40 AM
    mtskibum16
    PNW
    We're literally carrying these things for the instances when things don't go great, so the infinite reliable air of a pump has always made most sense to me. But I guess if I have a pump with an inflator it's a nice option to be able throw in a CO2 canister and have best of both on hand.
  20. May 9, 2022 at 11:02 AM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I've had the same experience as others, where a CO2 canister failed to inflate a tire/tube and I was stuck walking out or begging others for inflation devices. I now only carry a pump because it can't run out of air.
    You can carry a bacon strip plug kit in the OneUp EDC too. https://www.oneupcomponents.com/products/edc-plug-pliers-kit
    I highly recommend swapping out the bacon for the Stans Dart though! I've seen that thing seal a serious sidewall slice in a buddies tire, where there was no way bacon would've worked.
    You could buy an e-bike conversion kit and convert an existing bike if you've got one. I've seen good kits for ~$500...
