All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Jun 28, 2022 at 7:59 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    posting too many deals making you guys spend money lol.
    To be honest this would probably be interchangeable with the 1up since it has the slots on bottom of the tray. Also, it looks like it’s one solid tray so it may be able to be taken off and used on roof racks as well.
    113tac likes this.
  2. Jun 28, 2022 at 8:21 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Yeah idk but I should be able and sell my current Kuat I got for free and have an even nicer free rack
    whitedlite[QUOTED] likes this.
  3. Jun 28, 2022 at 6:40 PM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    First bath in weeks besides simple drivetrain cleanings.
    first time checking a hanger. Of course checked axle torque first
    and the sunset near the top at oak mtn. Super lucky to live near a trail system that you can ride after rain or during if you dare. Given you gotta know which trails are appropriate .
    Darkstar4u, drizzoh, PhoS and 16 others like this.
  4. Jun 29, 2022 at 4:18 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    The day I buy I derailleur alignment tool is the day I know I've made it
  5. Jun 29, 2022 at 4:55 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I literally just ordered a second hanger tool this morning for traveling. Once you buy one you'll use it all the time.
  6. Jun 29, 2022 at 5:42 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    It's a very quick job, not sure how much better or smoother it will make shifting, but if did feel great on the stand last night.
    I will say I'm having to check b tension about once every 2 weeks or so. People that say set it and forget it are lying or they have some good threadlocker on that screw.
  7. Jun 29, 2022 at 5:57 AM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    I havent ever adjust b-screw unless im going through everything or replacing something major.
  8. Jun 29, 2022 at 6:18 AM
    evenslower
    evenslower Well-Known Member
    Same, generally initial install and maybe a tweak shortly afterwards if I didn’t get it quite right the first time. Odd
  9. Jun 29, 2022 at 6:36 AM
    abacall
    abacall Life's too short
    Phil
    UT
    2020 VooDoo DCSB OR
    Absolutely love that bike. I hope they'll sell frame-only in the future.
    I'm fixing the b-tension only when I need to replace a derailleur/hanger (shimano 12spd). But I DO need to get an alignment tool, been on my to-dos for a while.
    BTW: If anyone's been eyeing some OneUp gear, they have a 20% code right now: SUMMER22
    Gunshot-6A[OP] likes this.
  10. Jun 29, 2022 at 6:44 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I'll take that thank you :thumbsup: They haven't renewed my pro deal but I reckon this is better than nothing
    abacall[QUOTED] likes this.
  11. Jun 29, 2022 at 6:59 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    Adjusting a b-screw every two weeks is not right. Something else is going on. They really are, for the most part, set it and forget it.
  12. Jun 29, 2022 at 7:01 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
  13. Jun 29, 2022 at 7:16 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    Yep. I wax....and I tell everyone to!
    That's a pretty good guideline. Shows it's not as daunting a task as some may think. The initial setup and cleaning a new chain is the most work...from then on it's super easy.
    My system goes like this:
    -Brand new chain gets four or five washes in mineral spirits to get the new-chain-gunk off. Pour the old spirits into a jar to decant...then you can pour it back into an old jug, filtered through a coffee filter, to use again.
    -Give chain one more bath in alcohol or methyl hydrate.
    -Mix your wax. I use 1lb parrafin, 5g PTFE, and 1g molydenum disulfide
    -Put wax and chain into crock pot
    -I usually keep an eye on it. The moment that the wax is fully melted I pull the chain(s) out. I have a few nails on the end of my workbench to hang them from
    -Once cool break the hard wax up a bit and install
    -On narrow-wide chainrings especially you'll need to run the chain in a bit until it's running super smooth
    -Give the chain a quick wipe after your ride. I usually just use a dry rag but you can use a rag dampened with alcohol. You don't need to go crazy though
    For a refresh of an already waxed chain I typically just toss back into the crock pot. If it's real dirty I give it a quick boil in water and a rinse in alcohol first.
    All this sounds like a lot of work but it really isn't once you have things set up. I also keep at least two chains per bike to cycle through. This way I can do everything in a batch. I'll go three to four weeks and then put all the chains into the wax at once. Doing that I can clean and wax six to eight chains in five minutes or so.
    I keep an electric kettle with an old pot and the crock pot in the garage. I hang all my chains up on the wall. I have each section labelled ie; "dirty gravel" "clean mtb" etc to keep them all organized. Once a chain is dirty or needs waxing I just pull it off, hang it with the dirty chains, and throw a fresh clean chain on. Done in seconds.
    113tac[QUOTED] likes this.
  14. Jun 29, 2022 at 7:21 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    The benefits of efficiency and reduced wear are obviously awesome but the absolute best part is that you can ride a chain for a few hundred kilometers and then just grab it with bare hands and not have any dirt or black schmutz all over you.
    Gunshot-6A[OP] and 113tac like this.
  15. Jun 29, 2022 at 7:23 AM
    113tac
    Stephen
    Northern Virginia
    thanks man, that's super helpful! I've been having good luck with my current lube but wanted to try wax since people have always said it's a good thing haha. I will probably order some wax today. Parts for my AXS setup have been rolling in over the last couple of days haha
    DingleTower[QUOTED] likes this.
  16. Jun 29, 2022 at 7:27 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    I should also add that I use Squirt to touch up a chain if needed. Any waxed based lube should work well.
    I did a 100km gravel race on Sunday with some mud and wet spots. Had to run a few kilometres because the mud was so bad it would pack up on the wheels and frame so much the wheels couldn't turn. Here's my drivetrain at the end:
    EdgemanVA and 113tac like this.
  17. Jun 29, 2022 at 7:39 AM
    113tac
    Stephen
    Northern Virginia
    dang that's pretty clean! I've been getting out on the gravel more the last couple months and I've definitely noticed my drivetrain not being happy with how dusty it has been. I'm just super excited to be upgrading to 1x12 on my gravel bike haha
  18. Jun 29, 2022 at 7:50 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    When you use wax - how quickly does a wet environment wash it away? I use lube because it does get wet from time to time in New England, but have been quite curious about wax lately.
  19. Jun 29, 2022 at 8:08 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Start at the shoulders, work to the ankles
    #SoAero
  20. Jun 29, 2022 at 8:14 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    This is the downside to wax for sure. It won't do as well as a traditional lube in the wet.
    I started waxing while living in Nova Scotia on the coast and still preferred it. A single ride in the pouring rain will do in a chain. A few river crossings may do in a chain as well. But...with a traditional lube after a ride that wet you'll usually have to degrease and lube anyway (unless you're the type who just keeps adding lube) whereas the wax you just take the chain off and throw a clean one on. Dirty one goes into the crock pot again. If you're doing a super-long ride in the rain you will likely be better served with a traditional lube however.
    guitarjamman[QUOTED] likes this.
