All Things Bikes and Tacos! (...and every vehicle imaginable)
Discussion in 'Sports, Hobbies & Interests' started by Gunshot-6A, Aug 10, 2016.
  1. Oct 24, 2022 at 2:57 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    wait...what? this is news to me. my understanding was they wouldn't blur the lines between forks. :Facepalm:
    lolol. classic. "who names these colors?!"
    Hah! Buddy of mine has a fox 36 and put a set of fox 40 decals on it.
    whitedlite[QUOTED] likes this.
  2. Oct 24, 2022 at 3:06 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Likely not an error, i just bought one from them for 600, same fork but 2020 model. They snatched up a bunch of stock from Ibis apparently. Comes shipped without OEM packaging from Fox.
  3. Oct 24, 2022 at 3:29 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    It's what they badged/stickered the Fox 40 as when they first made it in 29er form. Looks like they've just gone back to Fox 40 and added a 27.5/29er option.
    113tac likes this.
  4. Oct 24, 2022 at 4:04 PM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    Wait, really?! I thought this was just a typo...
  5. Oct 24, 2022 at 7:32 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I’ve got to say, this bar is really innovative. It could be a staple in bike fittings to show the rider the difference.
    It could be used for rental purposes, heck it’s almost worth owning and always having to test bar widths for different bikes over years.
    Go in with friends and let it be a group bar for when someone get’s a new bike etc…
    https://www.pinkbike.com/news/tech-...ustable-width-bar-and-dual-diameter-stem.html
    113tac likes this.
  6. Oct 25, 2022 at 5:30 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    So 5Dev apparently offers a Superboost option for their cranks now which I don't remember seeing in the past. Anyone run these? I'm so lost in the numbers behind fitting a crankset on my Pivot Switchblade (Superboost & Sram DUB BB).
    barelfly likes this.
  7. Oct 25, 2022 at 5:47 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Sram dub is just the spindle diameter so if you have sram cranks you can keep the same bottom bracket as going with the Ride5Dev "Dub" cranks.
    Superboost is confusing because it says the BB width and q-factor are the same but the chainline is different. I'd think if you run a non superboost crank you would need to run a special chain ring to get the right chain line.
    Pivot_Super Boost Plus_INTL.pdf (bicycleretailer.com)
    Sram's crankset manual says you need some different spacers for Superboost compared to regular boost, not sure if this applies with the Ride5Dev cranks if you go with their superboost option. I'd probably hit up Ride5Dev and see what they say about setup because I would assume if you go with their superboost option you can use standard bottombracket spacers and chain ring.
    dub-mtb-and-road-cranksets-and-bottom-brackets-user-manual.pdf (sram.com)
    Sram's manuals are super helpful in my opinion, makes everything nice and clear compared to other manuals I've seen haha.
  8. Oct 25, 2022 at 6:49 AM
    neatoneto
    CT/Mass
    Thanks man! Yeah that second link from Sram about spacers and spindle length was uber-helpful. I emailed 5Dev a little while ago to ask about spindle length. Looks like Superboost needs a PF 92mm spindle "width"
    113tac[QUOTED] likes this.
  9. Oct 25, 2022 at 7:14 AM
    Gunshot-6A
    Conner
    Everett, WA
    Looks like it was only in 2019 badging (release year), so I guess it was deemed too gimmicky to continue.
  10. Oct 25, 2022 at 8:11 AM
    113tac
    Stephen
    Northern Virginia
    Bottom Brackets are so confusing haha. All superboost Sram cranks will have a wider width to accommodate different BB Widths. Then you just use the spacers to take up the slack.
    My question would be, how many spacers do you need to run and whether you need a 0,3, or 6MM offset chainring. I would assume a regular 3MM but I have no idea haha.
    To throw a wrench in the mix, it looks like The WAO Arrival uses superboost (157x12) but recommends a regular boost crank with 3mm offset chainring.
    The best answer might be to find someone with your bike and ride5dev cranks and see what they run haha.
    neatoneto[QUOTED] likes this.
  11. Oct 26, 2022 at 8:13 AM
    113tac
    Stephen
    Northern Virginia
    So I ended up splurging a little and getting the Ride NF pants, I think @whitedlite saved the day again with the coupon code he posted a while back.
    I've got one ride in coolish weather, maybe low 50s/high 40s with a solid wind. They were pretty perfect that evening. Rode again yesterday at the new skills park in town in the 60s, pretty solid there too. I'm a fan so far. Haven't ridden with kneepads yet but there is plenty of room for kneepads, they also don't look like clown pants without kneepads haha.
    I think I would probably rock these up to 70* at the bike park. Definitely not doing a trail ride with these above 60 though, maybe not even above 55 haha.
    levie125 likes this.
  12. Oct 26, 2022 at 8:20 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    werp, paleh0rse, abacall and 10 others like this.
  13. Oct 26, 2022 at 8:30 AM
    113tac
    Stephen
    Northern Virginia
    Sick edit! You guys crushed it for sure. I've been wanting to visit knoxville but definitely want to more now haha
    honda50r[QUOTED] likes this.
  14. Oct 26, 2022 at 8:31 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    the beginning trails are just in a city park? not a bike park with limited access (only during opening hours?)
  15. Oct 26, 2022 at 8:36 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    If it’s a night ride I’ll ride in them below 70, if it’s daytime it has to be below 55 or at a downhill park.
    That sunlight heats you up rather it’s actually hot.
    Did the coupon work for you and when did you use it?
  16. Oct 26, 2022 at 8:40 AM
    113tac
    Stephen
    Northern Virginia
    Yeah that sun definitely matters, especially this time of the year where you can wear shorts in the sun and pants in the shade haha. We won't have any shade here in a couple weeks though.
    The coupon did work, It was the end of September that I used it. Took like a week for them to get here.
  17. Oct 26, 2022 at 8:43 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Not a city park. Our system is similar to Kingdom Trails in that it incorporates about 25 private land easements. Available to ride 24/7
  18. Oct 26, 2022 at 8:44 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    That's the goal!
  19. Oct 26, 2022 at 9:17 AM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
  20. Oct 26, 2022 at 9:24 AM
    Kenstogie
    Ken
    19 SR 2.7 4x4
    Fwiw I have what appears to be an identical stand different name brand but probably both from same factory in china….,it has been fine for my home use.. which is about the 10-15Xs a year I use it.
    [TACOMA][QUOTED] likes this.
